No photos = didn't happen - you know the rules Pat 🤣, no TEA teasing here☕
Taking half decent pics takes time, you know...
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
Ok, some TEAsing with photographic evidence. Part of today's haul was a little HP 8654A 10~520 MHz Signal Generator
![](https://photos.smugmug.com/Electronics/HP-8654A-Signal-Generator/i-QkJHcs2/0/65587790/X2/HP%208654A%20Sig%20Gen%20Front%20operating-X2.jpg)
It needs some cleanup (getting the modulation working required some switch exercising), and the attenuator feels like it's missing the proper detents, but at first brush it appears to be functional.
![](https://photos.smugmug.com/Electronics/HP-8654A-Signal-Generator/i-rLNMSHc/0/23408215/X2/HP%208654A%20Sig%20Gen%20400%20Hz%20amplitude%20modulated%2050%20MHz%20signal-X2.jpg)
And finally the power supply board. The really good stuff is hiding inside the cast aluminum housing in the foreground. and I'm not ambitious enough at the moment to open THAT up.
![](https://photos.smugmug.com/Electronics/HP-8654A-Signal-Generator/i-Wdp8NvS/0/b733db70/X2/HP%208654A%20Sig%20Gen%20A3%20board%20top%20half-X2.jpg)
It's now five AM and I should have been asleep hours ago, so I'm hitting the sack. Tek stuff later today.
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
-Pat
