Seems that some of you missed an interesting discord session ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
Some of us had to leave.......talk of horny gun toting goths was just too much handle.
I am constantly impressed by the vast deviation of topics generally
This morning's "run away" fleabay offering is a 20kV scope probe:
https://www.ebay.co.uk/itm/393523504276"Up for sale is a used Tektronix P6015vHigh Voltage probe and compensation box for high voltage probe. The probe has been overstressed due no no oil and would need an overhaul before use but all the part are present. The compensation box is in very good working order and still has calibration seals over the adjustable pots
A refurbished probe like this would cost over £1000"
This morning's "run away" fleabay offering: https://www.ebay.co.uk/itm/393523504276
![](https://i.ebayimg.com/images/g/95cAAOSw0YhhIRZl/s-l1600.jpg)
Oil ?
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Freon was the recommended insulation agent.
I am constantly impressed by the vast deviation of topics generally ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
Did I earn the title of honorary redhead ?
You're far too sensible for that title
As a British I wouldn't include automobile and seal in one paragraph. 😄
Just remember the leaky seals at the top of our cars are perfectly compensated by the rusty holes at the bottom to let the water out again.
Weren't seals a ingredient in British cars once upon a time...? ![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
... or was it a breeding program...?
We used to have quite a few British cars on New Zealand roads until they were all destroyed by rampaging elephant seals (and general decay)
What is it with you Yanks having toggle switches that flick up for ON ? ![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
I guess it's because we like to aggravate the rest of the world just like we thumb our noses at the metric system.
Seriously, it seems normal and natural. All my factory built equipment is like that and our wall switches are the same.
It's not just the north americans who do this. It is standard for toggle switches on aircraft. The reasoning is that accidental operation to ON is less likely. This is because things fall down not up.
I was about to agree re the switch direction in the USA- but thought if I was a pilot (and I am not) if I was flying I imagine there are lots of switches that I wouldn't want to accidentally switch off eg fuel pumps etc.
For me the biggest argument for the down-off is I imagine that in an emergency it may be slightly quicker.
Yeah, sorry but I had a rather pressing HR problem to help sort out, hopefully it will be resolved Wednesday with justice being done, but knowing from previous experiences, it won't, they normally do not do "U" turns because it shows them in a bad light. Once upon a time I recall they used to be called Personnel Dept and back then they seemed to be more on the employee side rather than the bosses.
I don't do the mantis thing, I don't like them raw
I don't do the mantis thing, I don't like them raw ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Hmm, well, I still don't fancy being cooked either, what is wrong with horniness, resting and repeating then
Mod 122C too...it is also an exceptionally stable instrument. I have a 577D1 as well, and it takes a couple hours before it is fully stable. I also have a second Type 575 with Mod 122C, equally as clean, but it's not so good functionally. I will be getting to it in the repair queue, possibly this winter when it's more fun to have toob gear heating the lab. ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
Wow...two pristine 400V 575 ... and me just a crusty 200V one. Oh well... still so happy to have at least one example of the beast, regardless of specs or condition !
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
577 only one I saw for sale here was a year ago and teh guy wanted 2500 Euros for it... not even powered up / 100% unknown condition, yeah right !!!
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
I also gather these are a nightmare to work on, have plastic bits that break, and known weak points on unobtainium parts.. can't remember the specifics but quite scary especially given the price of the thing !
![Scared :scared:](https://www.eevblog.com/forum/Smileys/default/scared.gif)
My 575 was only 150 Euros, 15 times cheaper than a 577 and it's all bullet proof stuff, or fairly easy to repair at least. It's a boat anchor after all, it does come with its advantages...
Oil ? ![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
No one over here will be able to get Freon, unless they find some old stock, the later P6015A version uses
silicone compound according to the Tek datasheet.
I've seen complete sets of that HV probe go for less than the start price, even one locally that came with complete with a scope & cart.
The seller clearly doesn't understand ePay terms, as they have listed it as
used which implies that it is fully working, which it clearly isn't
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
, could it even be cleaned??? They would have to pay me to take that away.
No one over here will be able to get Freon, unless they find some old stock, the later P6015A version uses silicone compound according to the Tek datasheet.
The seller clearly doesn't understand ePay terms, as they have listed it as used which implies that it is fully working, which it clearly isn't
Without the freon I think the probe can only be used safely up to approx 6kV.
Tek wiki gives 13kV, but your right, that one would probably flash over long before getting to 6kV.
https://w140.com/tekwiki/wiki/P6015David
Just so, but the residual amount in mine looks a little like an oil.
I'm sure putting the guts of that probe into the dishwasher would remove all the carbon deposits and make it perfectly safe to use. Wouldn't it?
I keep looking over at my 720A now and wondering about smd caps dammit!
[/color][/size][/b]
Stop wondering then, just crack it open to check for them, and make some nice pictures for us in the process, that goes without saying !
