I don't suppose you have either (a) a spare secure X clamp you'd be willing to part with, or (b) the means/ability to make an stl file so I could print my own?
Yes it's a problem for me too ! Two of meters came with no clamp, they got lost. You just don't find any parts for theses things. Only part I found, once, was a rubber holster. That's about it.
So I can't give you one, but I can send you one for as long as you want, to model it (I applaud your braveness), as long as you think of returning it to me when you are finished with it !
Never mind, just read your last post. Any idea why they stopped using it? The case still has the notches in the side to locate it.[/color][/size][/b]
Offer still stands, meter would look so much better with the clamp !
Think long term the only good solution is to wait for a red MX20 as this one did have the clamp. Was also the lowest spec meter of the lot, so likely to have been the most sold hence easiest to find used, as well as being the cheapest.
I have no idea why they removed the clamp either ! It makes no sense as it takes away a key element of their ASYC design, then when you see they removed it on all BUT the MX20 for some reason, you add inconsistency to the mix !
Honestly it just baffles me, it really looks both silly and inconsistent. I - just - do - not - get - it....
