Quick update on the 2 Avo 8 Mk V meters I picked up this morning. The leads are in a pretty bad way, hopefully a good clean will improve them, but the probes have had it. One meter was in a near perfect leather case, the meter had a rattle when I got it home, opened it up and a little screw and washer fell out. Tested the DC volts and the meter reads a little low, further investigation reveals some damage to plastic movement protection shell, and it seems some plastic bits may be caught up in the meter movement as the meter is not linear. Need to investigate that more.
The other meter had a sticker on the side stating it had been serviced by Megger, who own Avo and that one checks out perfectly OK and still had the factory applied seal intact following its service. That does not mean to say it's free from faults, when they reassembled the meter, failed to correctly align the meter assembly with its plinth
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
and as a result has obscured the top of dial markings as you can see in the photo, 4,5 and 6, so this needs a little fettling. Otherwise, both meters are in good condition cosmetically and all the switches and cut-outs function correctly, and battery compartments are in original condition.
More info and photos as I get to grips with them.
