Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18870761 times)
Carl_Smith and 105 Guests are viewing this topic.
Offline Cymaphore
« Reply #97350 on: August 12, 2021, 05:05:35 am »
I'm friends with a bunch of the people who make UTC(SP) and distribute it to the country as "Swedish normal time" (although it's still UTC on the wire, of course).  They scratch the smiley from above. 100ns is a lot of deviation to them.
When I first saw that, I read it as Swedish Fish Time. :-DD
I think I like it better that way... :o
One round of Surströmming for everyone! Don't be shy! Once you smell it, your perception of timezones will surely shift. Nanoseconds, Centuries, end of the universe and existence, with Surströmming it all becomes one.
The following users thanked this post: Zucca, BU508A, mnementh, factory
« Reply #97351 on: August 12, 2021, 05:34:01 am »
C-tick of approval. Painless apart from the paperwork  :-+
You really do need a haircut Bean !  :P
Monday for us.  :scared:
Hate needles despite having given many 100's to livestock.
Don't you have any livestock shears that you could lend to bean?
-- looks sideways at the repair queue and the dog clippers that need cleaning
Rats around in the shearing gear box.....
If we can call Bean an old ram then we would use the wide comb otherwise for old goats we use the fine narrow comb but they are best run on a slow shearing machine as they can get hot and the Bean would likely flinch however the wide comb also presents risk of cuts to the skin if not setup correctly....pick your poison !
You hold him and I'll give him the trim so he obviously needs.  :-DD
« Reply #97352 on: August 12, 2021, 05:53:44 am »
Damm cheating Kiwis and their wide combs  :-DD
I do own a set of clippers and have decided after maybe 25 years I need a new set so I have had a set of Wahl Battery ones on my evilbay watch list for the last month. The keep going out of stock and well it's winter so HoHoHo  >:D eBay auction: #284371112392
« Reply #97353 on: August 12, 2021, 06:40:16 am »
Sort of for Cerebus but also for me and or others I guess some additional PhysicaliTEA.
So still impressed with the Engineering on a budget. Closer cleaning and inspection then re assembly and measuring of the bits this afternoon. Threads after desludging and a proper clean are well formed and smooth. Surface ground parts have an excellent finish on them in particular given the price point.
Now onto the measurement bits. Initial measurements were of the three main bits individually and were all within 0.1mm in general so +-0.05mm or +-0.002".
Parts clean and dry fit on the initial rebuild then I will strip it backdown and grease and oil the appropriate bits. Looking at how this was likely machined is the base was flipped upside down and surface ground on a mag chuck against the lower ways so under it is very close to flat and it moved on the surface plate fairly evenly. Then the first stage was assembled and back off to the surface grinder again. The Red numbers are the assembled deviation so very close to taking out any deviations in the milled surfaces between.
Top slide was then installed and then I suspect a final grind to finish. With a little playing with the gibbs and depending on the slide position it seems to sit at around +-0.1mm or about +-0.004" I will recheck it with some oil on the ways but I doubt it will change that much. Depending on the Mag chuck and care/speed of the final grind this could have been improved but again for a price driven item more than acceptable. If I was seriously in need of it being flat then a box of beers and a visit to the surface grinder for a minor tweak would get it even closer if needed.
So very far from horrid tough rugged and way better than most drilling and even light milling needs with a little tweaking of the drill/mill head to it.
Initial Source https://www.aliexpress.com/item/1005002899550007.html?spm=a2g0s.9042311.0.0.47434c4dhrCD0I
Likely European source with the addition of a Rotary stage  :-// https://www.aliexpress.com/item/1005002446969669.html
The following users thanked this post: Cerebus, mnementh, Mortymore, cyclin_al
« Reply #97354 on: August 12, 2021, 06:47:58 am »
Not one to lower myself to posting Reddit links in here but this one is slightly hilarious.
https://www.reddit.com/r/facepalm/comments/p28v2f/seriously_though_what_was_she_expecting/
The following users thanked this post: Cerebus, BU508A, med6753, mnementh, Specmaster, Kosmic
« Reply #97355 on: August 12, 2021, 06:51:05 am »
BC would be jealous  :-DD
The following users thanked this post: mnementh, Specmaster, bd139, factory
« Reply #97356 on: August 12, 2021, 06:56:02 am »
At least he wasn’t doing it on his bed  :-DD
« Reply #97357 on: August 12, 2021, 07:06:00 am »
" Clarksons Farm "
I'm actually aghast at TV companies continuing to work with that man. Pompous git. From the trio, the only one (whose screen persona) I can stand is May. As indicated by the parentheses above I might be bloody well fooled by what is shown and what is not.
Middle son has a Top Gear addiction, so am forced, as Good Dad, to watch episodes. We've long since run out of the ones where there's only May.  :scared:
« Reply #97358 on: August 12, 2021, 07:10:55 am »
Some TWT porn for your viewing pleasure. I like how simple these 490 series amplifiers really are. The RF goes in the front panel, goes through the TWT, and comes out bigger. That's it.
Like you, IIRC, I'm not certain I know why I want one, but am pretty certain I feel some desire. Mmm, Watkins-Johnson RF gear.. Nearly always 3-digit serial numbers or less, full-on milspec build quality, insane performance, very unclear service history (as in who bought it, where did they use it, et c.) , and mucho desirable.
Edit: I'm mostly doing RF hobby at 2m and 70cm, with a bit of HF, so is not even my frequency range preference. Still.
« Reply #97359 on: August 12, 2021, 07:33:52 am »
Holy shit. Facepalm is right.  :palm:
« Reply #97360 on: August 12, 2021, 07:38:32 am »
Meanwhile on qwertee:
Types of TEA:
Ok, seems that this one is especially for the TEA-Dwagon.   ;D
« Reply #97361 on: August 12, 2021, 07:44:10 am »
Gonna be 96 F (36 C) here today. And as typical in Summer my monthly electric bill nearly doubles. I'll gladly pay it to be comfortable. Funny to hear Bean describe his Aussie Winter. That's not Winter my good man. This is Winter......  ;D
The following users thanked this post: Cubdriver, Specmaster
« Reply #97362 on: August 12, 2021, 07:47:10 am »
Types of TEA:
If there's a t-shirt showing the "TEA" being thrown into the harbor I'd wear it.  :P :P :-DD
« Reply #97363 on: August 12, 2021, 07:49:55 am »
Me and my Facial Hair were outside in a T-Shirt this afternoon cleaning the XY Table up in the psuedo Sun of winter. Not a bad day locally  ;)
The following users thanked this post: SeanB, mnementh, bd139
« Reply #97364 on: August 12, 2021, 07:55:56 am »
Here you go...
https://www.amazon.com/Coffee-Black-Tea-Harbor-T-Shirt/dp/B07PG9JV2V
Starting to agree with Americans here as I'm drinking black coffee now. Whatever next   :-DD
The following users thanked this post: BU508A, med6753, mnementh
« Reply #97365 on: August 12, 2021, 07:56:36 am »
Maybe I should have a t-shirt printed with this on it? What do you think?  :-DD
The following users thanked this post: Brumby, BU508A, mnementh, wolfy007, bd139, beanflying, Andrew_Debbie, cyclin_al, BILLPOD, Peter_O
« Reply #97366 on: August 12, 2021, 07:57:32 am »
Types of TEA:
https://pixels.com/featured/28-boston-tea-party-1773-granger.html?product=regular-tshirt
Feel free to add some Tek 547 of your choice to the picture...
 :-DD  :-DD
« Reply #97367 on: August 12, 2021, 08:04:36 am »
Prefer some half and half in mine but NO sugar.
« Reply #97368 on: August 12, 2021, 08:12:21 am »
If there is a higher resolution available of this picture, then yes.
Go for it!  :-+ :-DD
« Reply #97369 on: August 12, 2021, 08:19:53 am »
Some decades back hunting Bambi in mid NI NZ we came across the camp of an old bushman and were invited to stay the night. A real character and great host was Punchy Wallace whom was mostly self sufficient in his tarp bivy and we were fed well on his venison and pork hocks boil up.
Next morning started with tea then after a couple while yarning 50/50 tea and coffee and a couple more later onto just coffee !  :o
About 11am and we were thinking of making tracks and the lid got popped of his first quart beer bottle of the day !
We knew from the day before sherry was next and still a good few miles from camp so we legged it outta there only to return later as promised to empty our camp larder as thanks for putting us up on our last night in the bush.
Memories......
Only recently heard the old guy had passed some 10 years back.  :(
https://www.poronui.com/poronui-history-punchie-wallace-rip/
http://www.fishnhunt.co.nz/forum/YaBB.cgi?num=1277446611/0
« Last Edit: August 12, 2021, 08:46:45 am by tautech »
Offline McBryce
« Reply #97370 on: August 12, 2021, 08:26:43 am »
https://www.dx.com/p/creative-aircraft-gyro-support-car-air-outlet-mobile-phone-support-mouse-navigation-universal-bracket-2746652.html
OMG... this has to be the height of something... and the nadir of something else. It is the "connected age" equivalent of a propeller beanie; a dash-vent smartPwn holder with decorative propellers.  :o
There is just a universe of fail here; starting with the egregious pointlessness of it all, leading to the inevitable incapability to perform its basic function and finishing with the fact it is designed such that it will place spinning propellers right over the touchscreen.  |O
And somebody got paid to design this fucking thing. :palm:
So you go out and buy a fancy new BMW with a 3kW HVAC system that can blast you with all the cool air you could ever want... and then mount some piss-ass Chinese fans in front of the air outlets??  :wtf:
McBryce.
« Reply #97371 on: August 12, 2021, 10:04:15 am »
Not as bad as this C$%P
www.ebay.co.uk/itm/392394629135
If you are lucky it will only lower the performance of your car and not shed bits of metal into your engine  :palm:
The following users thanked this post: bd139, cyclin_al
« Reply #97372 on: August 12, 2021, 10:37:08 am »
Got 5 minutes to post this so will do so now. Woke up at 5AM this morning for some reasons. Couldn't sleep so at 7AM I decided I'd sort out a calibration issue I have.  In this case the Fluke 87 doesn't agree with the rest of my meters since I got it which are all bang on the same reading. This is a rarity and I will put it down to the previous owner futzing with it potentially. The cal manual says it should match the source of 3.500 to +/- 1 count. I'm not too bothered about absolute accuracy for my needs but relative accuracy is important so I've chosen to just cal against my existing meters.
Before
Quick wiggle of R21. Joy to the older Fluke 87's which don't have software driven cal - just two pots and two trimcaps :-+. Job done:
Voltage source here was my PL320 but next time I'm using the E3630 and a 10 turn potentiometer as a divider to get some better stability and resolution.
The following users thanked this post: PA0PBZ, xrunner, Vince, BU508A, med6753, mnementh, capt bullshot, wolfy007, ch_scr, tonyalbus
« Reply #97373 on: August 12, 2021, 11:00:38 am »
If your 87 drifted that far off it would really surprise me. I agree with you that the prior owner used an inaccurate source to "calibrate it". I've never had to touch the trim pots on mine.
« Reply #97374 on: August 12, 2021, 11:54:59 am »
 :-DD :-DD :-DD
It comes to something when someone is stupid enough to physically cut through the instructions that say:
(My own 'spicy pillow' recently extracted from an iPhone.)
What, so "cut" doesn't equate to "puncture", "crush" or "disassemble" in this genius' mind?
I begin to have some sympathy for the writers of those warning texts that I find annoyingly verbose and over-prescriptive. Perhaps we need to move to AvE style "Not for use by fuckwits." labelling. The problem there being that fuckwits are usually the last to acknowledge that they are fuckwits; sort of the ultimate Dunning-Kruger effect.
Do not fold, spindle or mutilate.
