I pulled and tested all the transistors on this vertical board. They are all OK.
![Phew :phew:](https://www.eevblog.com/forum/Smileys/default/phew.gif)
But the two output transistors (not shown) to the deflection plates have definitely gone tits up. As I mentioned earlier they are on order.
![](https://imagizer.imageshack.com/v2/xq90/922/Rizynz.jpg)
Then I discovered that the Type 1A1 plug-in wasn't passing a waveform to the mainframe. That's weird, that plug-in worked in the Type 535A. So I plugged in the Type 1A2 plug-in and that works.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
OK, just for giggles I sprayed deoxit on the 1A1 connector. That did the trick. And then I verified I have a good waveform through the entire vertical circuit and stops at the blown vertical output transistors. So once they are replaced the vertical circuit should be good to go.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
