The parcel was that HP 53132A 225MHz Universal Counter that I've been expecting.
So, the eBay description for this:
Condition: For parts or not working :
Seller notes: “Readout is bright and visible. Passes self test upon startup. No cables or accessories included. Comes with a power cable. May need to be calibrated. I was told this is working without issue, but I'm not a technician and able to test this further than self test. AS-IS. No returns. Very clean and nice condition.”
The vendor was careless with their shutter speed when photographing a
multiplexed display, so it turned out looking like this:
When it should look like this when it has no inputs and is sitting idle after the self-test.
So I reckon that put a bunch of people off.
It was listed BIN at $449.10 USD and after a few days in my watch list I got an offer for $350USD. "Passes self test" thinks I, can't be too bad, I'll take a punt.
So, $350 USD plus $98.30 USD '
priority' USPS carriage and I'm off for $448.30USD in total. That came to £339.54 GBP by the time it had hit me. Add £68.71 customs including a £12 handling carge from Parcelfarce, and I'm out of pocket for £408.25. Not a bad price if it's fully working and in as good condition as all the photos suggested. A bare, no fancy options, 53132A seems to go for closer to twice that. Excluding the usual "
You think you'll get what for it?" listings the going rate seems to be in the £700-900 bracket.
So, the result? It's fully working and in clean and tidy condition. The VFD is as bright and crisp as new one. But what about that rattling noise?
OK, so remember, no fancy options, and the back panel attests to that:
So, cover off to discover the source of the rattling:
Oh! It's the loose plug from the Ultra-stabilty timebase option 012 that it
doesn't have! (Circa 400 sobs for a working 2nd hand example!)
Sadly the option 012 isn't working when plugged in. But, it's still a bonus and with a bit of diagnosis on the bench I may even get it working. So far I've just tested it in situ and with it plugged in the meter comes up, but the timebase is clearly kaput - the 10MHz output on the back gives a wavering signal in the loose region of 15kHz. Next step will be to put that on the scope and see what's there. After that it's get the option card out, hook up 3, possibly 4 power rails (-12, +12, +5 and an apparently optional +9) to bench supplies and see what's what. There are tants on the card, which is always suspicious and might yield a quick fix.
I had resigned myself to having to design and make my own OCXO based timebase for this. Including sourcing at least one obsolete DAC for it. Looks like, with a bit of luck, my job is instead fixing the 'free' option 012 I got. Cushty!
