That was a weekend filled with putting things in tight places and getting things stuck in holes!
Now that everyone's mind is in the gutter... ![Evil >:D](https://www.eevblog.com/forum/Smileys/default/evil.gif)
This continues on top of my issue with the RC part; still need to sort out the screw shaft stuck in the cup.
I got my second COVID shot on Friday afternoon. The after-effect was a sore shoulder and feeling tired.
On Saturday, everything was fine, so I decided to do as @Vince says (but not as he does, according to his posts) and went to work on the outside of the house.
Proof of my efforts and lack of results:
(Attachment Link)
Concrete bit #1 on the left side is accidentally bent when I got stung by a wasp.
Now, I am allergic to bumble bee stings, but no harm in the past from wasp stings. As a pro-active measure I took an antihistamine, which meant I had to quit working since those make a person groggy.
Finished the day sitting around the house with the Epi-pen close at hand. (My first-aid protocol is different from normal, since I live in a rural area without nearby emergency services.) @Med, you can know that I was with you there in spirit for the evening; get well quick! A friend came over in the evening and took care of the wasp nest. ![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
Went back to work on Sunday. The bit #2 is heavily worn down, but at least some progress was made. Some of the aggregate here is granite, which is very hard stuff to drill through.
Continued with bit #3, which suddenly burned itself out.
Later on I realized that the carbide tip on the end is missing; you can see the vacant slot in the photo.
I tried continuing with bit #4 in the same hole where I left off from bit #3. This new bit lasted less than a second before the tip got chewed up. You can also see the drill chuck was no longer able to securely hold the bit. Investigating that is when I realized that the earlier bit is missing a tip and realized that tip must still be in the concrete.
Unfortunately, I am not aware of drill bits meant to drill through carbide steel.
Well done, Murphy!!!
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
Next step is to fill some of those holes with silicone, come up with a re-design, and drill new holes in another location. Not looking forward to this as the initial design involved minimal cutting of pressure treated lumber and now will likely involve custom cutting.
I will be able to get to TEA someday, I hope ?
You clearly need an SDS+ hammer drill. Given the regularity of bargain finds at thrift shops you guys have in the GWN I'm surprised you don't already have one.
EDIT: The tip is likely in many fragments at the bottom of the hole, and you might be able to get them out with a sticky stick, but even if you can't you should be able to just batter your way through with a new bit. You might have hit some rebar, that will make tips overheat and wear down/shatter.
Thanks for mentioning that. I was using a bigger than typical hammer drill (120V, 6A). It is not a SDS+ (I had to google the difference). We have an even bigger Makita that is at SWMBO brother's house; will check this afternoon if that one is SDS+; it could be big enough to be SDS-MAX. If not, then I have an excuse to go shopping. Maybe not, $500+CAD is pretty steep for occasional use. Oh wait, that sounds like TEA
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
Update: I can get a single-battery SDS+ drill reburbished from Makita Canada for $205CAD; only an hour drive away (but close to my office).
No chance of finding that sort of thing in a thrift shop. I suspect certain individuals find good deals where there are affluent neighbourhoods. Those neighbourhoods do not appear to be near here. Also, affluence like that means they can afford to hire someone, rather than buying such a tool. Around here in rural areas, you keep everything ... just in case.
I am absolutely certain there is no rebar. I poured the cement myself. It is a 8" tube footing which does not need that level of reinforcement.
From what I just read on SDS, that has a much greater chance of breaking through as you suggested, at least compared to a regular hammer drill.
I will try the sticky stick idea; if it works it will certainly make things easier.
Thanks!
EDIT: just picked up the bigger Makita and is completely unsuited for this purpose. It has a significant gear reduction so is meant for drilling steel, augers and mixing. Also, there is no hammering functionality.
