That was a weekend filled with putting things in tight places and getting things stuck in holes!
Now that everyone's mind is in the gutter...
![Evil >:D](https://www.eevblog.com/forum/Smileys/default/evil.gif)
This continues on top of my issue with the RC part; still need to sort out the screw shaft stuck in the cup.
I got my second COVID shot on Friday afternoon. The after-effect was a sore shoulder and feeling tired.
On Saturday, everything was fine, so I decided to do as @Vince says (but not as he does, according to his posts) and went to work on the outside of the house.
Proof of my efforts and lack of results:
![Test Equipment Anonymous (TEA) group therapy thread](https://www.eevblog.com/forum/index.php?action=dlattach;topic=81471.0;attach=1233701;image)
Concrete bit #1 on the left side is accidentally bent when I got stung by a wasp.
![Scared :scared:](https://www.eevblog.com/forum/Smileys/default/scared.gif)
Now, I am allergic to bumble bee stings, but no harm in the past from wasp stings. As a pro-active measure I took an antihistamine, which meant I had to quit working since those make a person groggy.
![Indifferent :=\](https://www.eevblog.com/forum/Smileys/default/indifferent0023.gif)
Finished the day sitting around the house with the Epi-pen close at hand. (My first-aid protocol is different from normal, since I live in a rural area without nearby emergency services.) @Med, you can know that I was with you there in spirit for the evening; get well quick! A friend came over in the evening and took care of the wasp nest.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
Went back to work on Sunday. The bit #2 is heavily worn down, but at least some progress was made. Some of the aggregate here is granite, which is very hard stuff to drill through.
Continued with bit #3, which suddenly burned itself out.
![Rant :rant:](https://www.eevblog.com/forum/Smileys/default/rant.gif)
Later on I realized that the carbide tip on the end is missing; you can see the vacant slot in the photo.
I tried continuing with bit #4 in the same hole where I left off from bit #3. This new bit lasted less than a second before the tip got chewed up. You can also see the drill chuck was no longer able to securely hold the bit. Investigating that is when I realized that the earlier bit is missing a tip and realized that tip must still be in the concrete.
Unfortunately, I am not aware of drill bits meant to drill through carbide steel.
Well done, Murphy!!!
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
Next step is to fill some of those holes with silicone, come up with a re-design, and drill new holes in another location. Not looking forward to this as the initial design involved minimal cutting of pressure treated lumber and now will likely involve custom cutting.
I will be able to get to TEA someday, I hope ?
