From the MAKE MY SON STOP WHINGING ME TO DEATH Dept...A few days ago, I took my son thrifting... and he found this set of Turtle Beach gaming headphones in near-mint condition. As they were only $6 and I had fond memories of a similar set of Turtle Beach deep-cup headphones from back in the day, I didn't look too close except to note the USB plug and that the pads were in decent shape before dropping them in the bag as a replacement for his old Logitech gaming headphones, which as you can see are pretty well used up.
When we got them home I realized that they are not a USB headset, but actually a prehistoric all-analog design that just uses the USB for power.
So I set them aside while I finished up the Yamaha Keyboard; I figured if I let the problem percolate a little in the back of my mind, I might come up with a better solution than hacking the cables with 1/8 headphone plugs to go into the back of the PC old-school style.
The power jack was a pretty straightforward panel mount with a small roadbump in that there wasn't room for the nut, so I had to commit a bit of epoxy abuse. Some silicone wire made for power leads on my micro-quadcopters gave me a connection with a little flex, so I don't need to worry aboot stuff breaking loose, while not being a melty PITA to solder direct to the PCB.
After that it was relatively uneventful reassembly; wifey played with it for a bit and liked the feel as well as the default Piano voice, declaring it a good student keyboard, which is good enough for me.
So... back to the headphones... Tracing out the wires in the Logitech revealed that the PCB in the MUTE/VOL Control bug was a perfect place to marry the two together; they'd even thoughtfully labeled the solder pads on both units.
A little heat to wrangle the strain relief off the Logitech cable onto the wire from the TB headphones, and the reassembly was almost painless. I like painless.
Testing the newborn
LogiTurtle Beach HeadPwns on Discord (the delay really helps you tell what is from the headphones and what is in your head) demonstrated that the mic works properly; a little streaming music yielded the awesome sound that made Turtle Beach famous: It's
all in the drivers man.
It's always good to show the kid that quality is quality, no matter how old.
