That said, your lab requires a bench meter because, well, because you seem to want one.
Also consider that you'll probably need a bench multimeter to fix your bench multimeter when it breaks. So really you need two. And if you have two, and they disagree, you'll never know which one is correct. So you really should have three at a minimum. And have you thought about how you're going to calibrate this new bench meter when you get it? You'll definitely be wanting to add a
calibrator to your arsenal at some point (note to self: I could take my own advice on this point). And how do you know the insulation on your probes is up to spec? Better get an insulation tester in there at some point. And however many digits your meter has, is never enough, so you're going to want to upgrade
at some point as soon as possible. And... well anyway, that's enough of that for now. I think you get the picture.
Also, if you value your bank account balance, stay far away form the
metrology section. "Beware, for dragons be there." Spend too much time in
there and you'll soon be buying rubidium standards, cesium standards, GPSDO's, distribution amplifiers for distributing 10mhz signals (something about this story sounds strangely familiar) and FSM-knows what kind of volt-time-nuttery equipment. Fair warning, DO NOT GO IN
THERE.
