Some today arrivals.
Top left: nice Vishay 1MOhm 0.005% resistors (not for me, will forward them to a TEA fellow )
top middle-right: DC-DC step-down buck converter with voltage display
bought here: https://www.ebay.com/itm/313493568554
The rest: a very nice compilation from ch_scr! Thank you!
Some PCBs for the AD587UQ and parts.
Glad it arrived well, here's the help for putting the components on:
Note : where the 2 parallel 100R's reside is the trim for the "farther than the other" AD587.
The one thats off the other way got 2 in series. On the three other ones just one 100R and a bridge for the trimpot was "good enough"
Note 2: The place that looks like it wants to have the 100R SMD trim, needs a bridge. The cut away trace gets the 100R.
(As seen in the picture below) Go figure
Note 2.5: The solder pads for the ferrite beads are a bit short, but you'll find a way to get them on I'm sure
Note 3: "Every solder job looks shoddy, given you magnify enough" ~ proverb of the magnifier salesman
Have fun!
I've drawn a little schematic. To your eyes, does it look correct?
The two parallel 100 Ohms resistors are in my schematic R1, right?
First glance says: except L3's a diode it's correct
Edit says: good job on the davecad
Of course it is a diode, not a choke!
You've mentioned some protection in discord. D'oh!
Btw, this is the backside of the schematices:
On mid of May I've
received four of those nice Vishay 1MOhm resistors. The same day another envelope from the seller (zhoefler, ebay) arrived and I was wondering about that, because I didn't expect another delivery from him. Opened the envelope and found some high voltage capacitors. The invoice mentioned clearly another customer of him in Leverkusen. I called Mr Hoefler and told him, that I got the capacitors of this customer of him and told him, that I will forward them to the guy in Leverkusen. He was very pleased about that and offered me a "little" reward for my efforts. I said: "Yes, thank you, that's very kind from you." thinking, that he will send me some various electronic parts.
Some days later a parcel from Mr. Hoefler arrived. I opened it and found this:
- a Pt100 simulator from
burster präzisionsmeßtechnik in Gernsbach (it was already torn apart when I've received it)
- a modular resistor decade from burster (the 100Ohms module is missing and the 100kOhms module was torn apart)
Wow!
THAT was really a surprise, didn't expect that!
Let's start with the Pt100 simulator. Essentially, it consists of 30 high precision 0.02% resistors and a 30 step high quality switch.
The front, backside of the front, the PCB and a detailed view of the resistors being used:
I haven't tested it yet but I assume, that the switch will be happy about some cleaning.
Next is the burster resistor decade which I do really like for its modular design.
Top view, the disassembled 100k resistors and the backplane:
I've checked the 10k 0.05% resistor module and found a lot of jumping around while wiggling on the knob.
I've opened it and it was clear, where this behaviour is coming from. Really, burster? Attaching directly the switch to the case, where the knob is also being used to lift out the module from the case? I think, the silver contacts are also a problem and need some cleaning.
Module disassembled, side view:
Some detailed views of the switch, a "EBE EMX 1/1 x 11k T=12 Ag"
Have not decided yet what to do with this decade since two modules are missing (the 100Ohm and the 100kOhm one).
I'm a bit reluctant to extract the resistors and use them as some reference resistors, but on the other side I'm not sure, if one can trust those poor switches anymore. Even if cleaning will work, I'm not so sure about the mechanical abuse.
What do you think?
Thank you for watching, hope you've enjoyed this "little" surprise of mine.
