9:00 PM local time on May 25 and nothing's shown up. Worse, eBay's timed out on leaving negative feedback or opening up the complaint process from what I can see. Is there any way to get that re-opened?
Not that I am aware of.
You should be able to find it back and open a case over here: https://resolutioncentre.ebay.ca/
Even if your time has run out?
If you
can get a dispute open or leave feedback, I would like to know!
Of course, if your payment came via a credit card, you could seek redress via the card issuer. You won't be able to leave feedback or have it noted in your eBay profile, but you will probably get your money back. I don't know what happens behind the scenes with a seller who causes this, but I would expect they will not get away untarnished.
My approach on the time limits involved is very firm. I work out when the last day is supposed to be and then subtract
two days from that.
On that day, if there are any outstanding issues, a dispute is raised
REGARDLESS OF WHAT THE SELLER SAYS. If you don't, you're stuffed ... and there are sellers out there that
will deliberately play this game to keep your money.
Should the item turn up later, you can always contact the seller and sort out a means to make good - but you are in the drivers seat. In all the years on eBay, I've had several no-shows and three occasions where I've had very late delivery (ie after dispute and refund) and I've contacted the seller to sort out payment.
