Just finished an upgrade to my old netbook - a ten year old Samsung N150Plus. SSD, 2GB RAM, upgrade from Win7 to Win10Home. Astonishingly, the original battery still has 57% of the nominal capacity left. Funnily, the free upgrade to Win10 still worked. Only problem was that the backlight brightness control didnt work, but that could be solved with some googling and tinkering with regedit.
This will become my travel/lab machine and will also be used to connect to my THS720P (via the nice THS7XX Hard Copy tool written by mrprecision). Since the mic input to the sound card ist stereo, it is also useful for ham radio SDR applications. The nice things are a matte display, quiet fan, 3 USB ports, a decent keyboard and a good quality soundcard. Size and weight make it very portable.
A complete service manual can also be found on the net. Replacement battery for 21€ is on the way, this should give 6 hours or more runtime again.
And now some measurements with hwinfo, to stay on topic:
HWiNFO32 Version 7.04-4480
DG1SMD-N150 ---------------------------------------------------------------
[Current Computer]
Computer Name: DG1SMD-N150
Computer Description: Netbook
Computer Brand Name: Samsung N150P/N210P/N220P
[Operating System]
Operating System: Microsoft Windows 10 Home Build 19042.985 (20H2)
UEFI Boot: Not Present
Secure Boot: Not Present
Intel Atom N450 -----------------------------------------------------------
[General Information]
Processor Name: Intel Atom N450
Original Processor Frequency: 1666.7 MHz
Original Processor Frequency [MHz]: 1667
CPU ID: 000106CA
CPU Brand Name: Intel(R) Atom(TM) CPU N450 @ 1.66GHz
CPU Vendor: GenuineIntel
CPU Stepping: A0
CPU Code Name: Pineview-M SC
CPU Technology: 45 nm
CPU S-Spec: SLBMG
CPU Thermal Design Power (TDP): 5.5 W
CPU Max. Junction Temperature (Tj,max): 100 °C
CPU Type: Production Unit
CPU Platform: FCBGA8 (BGA559)
Microcode Update Revision: 107
Number of CPU Cores: 1
Number of Logical CPUs: 2
[Operating Points]
CPU LFM (Minimum): 1000.0 MHz = 6 x 166.7 MHz @ 0.9500 V
CPU HFM (Base): 1666.7 MHz = 10 x 166.7 MHz @ 1.1625 V [Locked]
CPU Current: 1662.1 MHz = 10 x 166.2 MHz @ 1.1625 V
CPU Bus Type: Intel Direct Media Interface (DMI) v1.0
Maximum DMI Link Speed: 2.5 GT/s
Current DMI Link Speed: 2.5 GT/s
[Cache and TLB]
L1 Cache: Instruction: 32 KBytes, Data: 24 KBytes
L2 Cache: Integrated: 512 KBytes
Instruction TLB: 4 KB Pages, Fully associative, 32 entries
Data TLB: 4 KB Pages, 4-way set associative, 64 entries
Motherboard ---------------------------------------------------------------
[Computer]
[Motherboard]
Motherboard Model: Samsung N150P/N210P/N220P
Motherboard Chipset: NM10 (Tigerpoint)
Motherboard Slots: 4xPCI Express x1
PCI Express Version Supported: v1.1
USB Version Supported: v2.0
[BIOS]
BIOS Manufacturer: Phoenix Technologies
BIOS Date: 04/30/2010
BIOS Version: 01KY.M008.20100430.RHU
UEFI BIOS: Not Capable
Super-IO/LPC Chip: SMSC FDC37M81x
Battery #0 ----------------------------------------------------------------
[General Properties]
Device Name:
Manufacturer Name: SAMSUNG Electronics
Serial Number:
Unique ID: SAMSUNG Electronics
Chemistry: Lithium Ion
Designed Capacity: 47520 mWh
Full Charged Capacity: 27000 mWh
Wear Level: 43.2 %
[Current Power Status]
Power Status: Discharging
Current Capacity: 23490 mWh (87.0 %)
Current Voltage: 11.779 V
Discharge Rate: -8057 mW
Greetings,
Rainer
