Since I'm here, I have been waiting for the right HP 419a DC Null Meter to show up for about 5 years. Finally found one that met my search criteria. It arrived well packaged and even seemed to work properly (minus the 35 year old NiCad's and the mercury null supply cell).
Now the bad, while cleaning up some corostion from the leaky NiCads and making some adjustments, the hot side of the AC power on the non fused side of the fuse eyelet made contact with one of the NiCads and put 120v AC into the +13v line
![Broken! :-BROKE](https://www.eevblog.com/forum/Smileys/default/smiliey_scope_broke.gif)
I found nearly every silicon part on the A2 power supply/chopper blocking amp board fried, all but one 2n3053. So off to search for 2n3053's, some secret PNP HP used that the best I can cross ref came to an NTE106, and 2n3391's. I was lucky and found NOS for the 3053's and other parts. I was please to see no damage to the chopper block or the A4 amplifier board.
It was working again, time to make a NiCad 24v battery and find a replacement for the mercury cell. This unit is really a battery powered device and the power supply is really just a constant current trickle charger for the battery. In normal operation, the power supply is limited to 10mA, in the "Fast Charge" mode 18mA. The meter itself draws about 5mA, leaving 5mA to trickle to the battery, in the Fast Charge mode no power is sent to the meter. I thought about using Li-FePO4 cells but didn't want to add a CV to the unit, so I decided to stick to NiCad's. After all, they have worked for 45 years in this box already. Found 300mAh 2/3 AAA NiCads on eBay with tabs for cheap (like 26 cells for $15 total), the OEM cells were rated at 225mAh, so these should do just fine. Built up the pack, wired it in and it works great. After some testing I decided to use a CR123a lithium cell with a 2.7k series resistor to bring the battery back to within range and show proper full scale. The current draw is about 650uA, so a 1.5Ah CR123a should run for well over 2000 hours. Easy to find, cheep and good long life stability.
Video of the meter in use and just how sensitive it is, you have to pay close attention to Thermal EMF not to trick you with this one.
