Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18113565 times)
0 Members and 101 Guests are viewing this topic.
« Reply #87950 on: April 12, 2021, 10:55:31 pm »
This meal was 2 days in the making...
...and worth every minute just to see the smile on her face.
  ;D
Offline sarge
  • If humans can make it, humans can break it.
« Reply #87951 on: April 12, 2021, 11:05:06 pm »
I am, actually. I have chokes on nearly every single wire in here to help with the interference, and I even have three (!!) wireless access points going on. One of them is the starlink router, and will eventually put the dish directly on my main network. In due time! That said though, the noise floor and overall interference is actually quite minimal, and my SDR's/ham radios don't pick up *that* much noise. If anything, I see more interference from my damn refrigerator than anything else  :-DD
For amusement purposes, you all will probably get a kick out of this, then -
Yes, that's my living room. I'm crazy and I know it.
You're not crazy. One bedroom apartment here and this is my living room.
And it overflows into the bedroom.
I love it  :D
Once I get a bigger boat, I shall continue my collection.
Offline cyclin_al
  • VE3TSD / VA2XAR
« Reply #87952 on: April 12, 2021, 11:08:43 pm »
FFS ...  :palm:
https://www.ebay.de/itm/Goldener-Commodore-C64-Jubilaumsmodell-1986-einmillionster-C64-in-Deutschland/143998258361?hash=item2186f70cb9:g:lvwAAOSwfrNgadV3
Woah!  That is nuts.  Time to go look in the barn at SWMBO's mothers place.  I think I have a stack or 4 or 5 in there, along with at least one C128....
Offline cyclin_al
  • VE3TSD / VA2XAR
« Reply #87953 on: April 12, 2021, 11:16:19 pm »
  • Keeping the streak going ... yet another TEA item ordered as of yesterday. It's an hp 437B power meter.
    eBay auction: #114616655678
    The seller seems to have a stack of them. The price is only $37.50 fully tested. It's the same group I got these two latest hp units from, so I trust the seller now.
    But, of course, that does not include the sensor cable (hp 11730A), or a sensor available wherever you can find them. I'd probably go with the 8481A: -30 to +20 dBm, 10 MHz to 18 GHz. Also need attenuators if you want to measure over +20 dBm, but I have those on-hand. Most I would measure would be ~ +50 dBm.
    So, it remains to be seen, not if, but how badly I will get reamed over those two necessary items. I know they are wanting $79 just for a used cable.
    For the sensor ... ouch.  :palm:
Exactly that.  There was a seller in the Montreal area selling a bunch of those for $35CAD.  I do not see the ad posted anymore.
He also had a set of two with a single cable and single sensor for $350CAD.
(Same seller was selling a couple of HP 5326B; one of which was the one I purchased.)
« Reply #87954 on: April 12, 2021, 11:54:09 pm »
Why did the RAF purchase the C17 and the Airbus A400M? Don't they basically fulfill overlapping roles?
Yes they do to an extent, but they both have different load capacity and operational requirements. The C17 has the largest load space and can carry 69 tons while the A400M carries has a smaller hold and can manage 37 tons and so the A400M is the more resourceful for those seeking to transport items to dangerous locations because of the risk of sucking dirt into the engines on unmade surfaces with the jet engines of the C17.
« Last Edit: April 13, 2021, 07:53:40 am by Specmaster »
Offline nixiefreqq
« Reply #87955 on: April 13, 2021, 12:03:20 am »
I love it  :D
hey....that almost looks like an old stratcom patch on the monitor.
hmmmmm.   maybe 1108th?
free range primate
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #87956 on: April 13, 2021, 12:09:41 am »
I'll be receiving the meter Wednesday. I'll check it out to the extent I can. I can turn on the 50 MHz power reference and measure it with my own gear. If it seems OK I'll see about the sensor and cable. I've located an Ebay seller who has about eight 8481A sensors, and they are all freshly calibrated with the paperwork included.
It's only money - you can't take it with you ...  :-DD
Offline vk6zgo
« Reply #87957 on: April 13, 2021, 01:07:07 am »
Its 24degC outside, I'm drinking a Harp and doing BBQ. Life is good  :-+
Commiserations on it being Harp.  :)
Can you really still get that stuff? I haven't seen that on a pump or even in a can in the UK for years. Given the swill that a worrying number of Britons will drink under the label "lager" it might be surprising that we've given it the cold shoulder, but that we have.
Poms used to drink the most godawful crud------Watney's "Red", anyone?
The absolutely worst that I ever drank was called "Alsopp's" lager, which came in a sickly yellow can, predicting the contents.
The Chandris line ships used to stock up on whatever they got cheapest, from Alsopp's as the worst, through decreasing levels of awfulness, via "Fix"(arrrgghh!), Courage lager (Blecchh!), up to reasonable to good (Oranjeboom, Beck's, VB, etc.).
Coming off the ship in the UK, we were confronted mainly by a desolate waste on the beer front, with a few tolerable, like the aforementioned "Harp", Carling black label, Newcastle Brown, "Ewer's Lager" from Scotland, & a few others.
That was, of course, in the bad old days, pre the "Real Ale" movement!
Offline vk6zgo
« Reply #87958 on: April 13, 2021, 01:13:28 am »
Harp is dead in the UK since tesco introduced “value lager”. Also surprisingly I found out that white lightning, favourite of tramps, is now somewhat respected and the tramps are drinking strongbow ?!???
An earlier generation drank Srongbow back in 1971, as it was pretty cheap, you could buy it in a bigger bottle than other grog, & it fit nicely inside a surplus army greatcoat.
It seems they are just "returning to their roots!"
Offline Kosmic
« Reply #87959 on: April 13, 2021, 01:14:52 am »
Woaa, so many beer snobs. I guess I'm not going to tell you what I drink in term of wine and where I get it.  :-DD
The following users thanked this post: SkyMaster, Specmaster
« Reply #87960 on: April 13, 2021, 01:37:45 am »
I'm a total wine heathen. I like nice sweet red wines; the kind uncle Giuseppe and his wife served with lasagna or cheese and crusty bread. I also like a snort or three of grappa for dessert.* :-DD I have also drunk wine from a box and liked it, so there.
*After that... who cares...?
« Last Edit: April 13, 2021, 01:45:05 am by mnementh »
The following users thanked this post: SkyMaster, Specmaster, Kosmic
« Reply #87961 on: April 13, 2021, 02:05:36 am »
Hey, we won't judge, unless you tell us it's white, comes from Canadian Tire in gallon plastic containers, and would go down well with a certain generation of Austrians.  :)
« Reply #87962 on: April 13, 2021, 02:07:43 am »
I've told you before, its supposed to be drinking champagne from a ladies shoe, not the shoe box.
« Reply #87963 on: April 13, 2021, 02:08:21 am »
Nothing WRONG with variations in a Red. Ice Chilled Lambrusco on a hot day or a full blooded Aussie Merlot all have their place so long as you avoid the $2 chuck versions  ;)
Offline Kosmic
« Reply #87964 on: April 13, 2021, 02:22:30 am »
Well it's blue. They say its windshield washer, but taste delicious. Really dry and robust.
The following users thanked this post: SkyMaster, mnementh
« Reply #87965 on: April 13, 2021, 03:37:00 am »
If I have the lady's shoe in my hand, my lips are gonna be entirely too busy somewhere else on said lady's anatomy. My name is not Al Bundy, and I don't sell shoes. >:D
"And if someone chains a fair maiden outside my cave, it is not my head I'm gonna put in her lap, either..."
« Last Edit: April 13, 2021, 03:39:30 am by mnementh »
Offline KK6IL
« Reply #87966 on: April 13, 2021, 04:03:24 am »
We used an Optimation like that one at Wavetek about 1970 to do AC calibration on their differential voltmeters. Didn't depend on to for a calibrated output voltage but measured with a Holt thermal converter for accuracy. Don't know where you would find the oversized banana plugs for the HV output these days.
Offline cyclin_al
  • VE3TSD / VA2XAR
« Reply #87967 on: April 13, 2021, 04:18:54 am »
My coockie or what it arranges to stay logged in... does not work.. i keep being logged out and when i log in again i am not in this treath again..
any advice on this guys?
I had the same problem .... what worked for me is do not go to page 3496 of this thread.  All the other pages (so far) seem to work except that one.
That was the current page right about the time of the data centre fire...
« Reply #87968 on: April 13, 2021, 04:46:46 am »
 :'( Poor little Gossen appears to be Gonnen .... Overdue by nearly two weeks so I asked for and got a refund. Hope it finds a nice home.
« Reply #87969 on: April 13, 2021, 06:51:41 am »
Think they just imported some UPS staff from here  :-DD
We don't need no stinkin' illegal aliens.....send them back.  :P :-DD
Chuck 'em in the Harbour?
Has proved its worth...
 :-DD
« Reply #87970 on: April 13, 2021, 06:52:51 am »
You're both into green walls!  |O
Pink curtains too ?  :P
Kiss my arse...and ass too.  :P :-DD
Isn't that the dwagon's job?   ;D :-DD
Offline dl6lr
« Reply #87971 on: April 13, 2021, 07:38:10 am »
I guess it had to happen sooner or later. UPS screwed up somehow. The Mouser order got to the Kingston distribution center at 04:00 hours this morning but never got out for delivery. Now tracking says tomorrow (Tuesday).  ::)
This would be comfortable for me. The logistics in DE is a real PITA now. DHL parcel (to be ontopic with my rant: This is a µCurrent Gold):
Announced for pickup on 2021-03-31.
Pickup on 2021-04-06
[...] Hanging around
Prepare for transport on 2021-04-12
Transport to destination on 2021-04-13
So if I am lucky I will receive it this week.
« Reply #87972 on: April 13, 2021, 07:46:49 am »
Ordered at Welectron?
« Reply #87973 on: April 13, 2021, 08:00:24 am »
Hey, did you just steal Meds special brew of wine??
« Reply #87974 on: April 13, 2021, 08:05:19 am »
Well I guess you could say that you've just been FIRED!!  >:D :o
