Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17737733 times)
Robert763 and 125 Guests are viewing this topic.
Offline DC1MC
« Reply #87775 on: April 10, 2021, 10:31:06 pm »
Ok well today’s task went to shit. I was going to start measuring all these crystals. Managed to get nowhere. Went for an amble, did some shopping and generally got sod all done.
Reminder: Discord this UTC evening  :)
I also need to measure the motional parameters of 2-300 crystals, mostly form Golledge and Russia, but I've hit the following snag, the bloody Colpitts oscillator (the one with switchable series cap for determining ser/par resonance) it overloads the crystal (almost 9Vpp  :scared: ) and creates a huge short term frequency instability, and I want to get them into 10-20Hz tolerance pools for my filters, combined with the fact that they're freaking ultra sensitive to temperature (if you touch them with your hand while inserting in the socket, they drift, I needed to use a plastic SMD tweezers) makes life miserable  |O.
Does anyone have an idea of an oscillator that loads the crystal a bit less ?
 Thanks,
 DC1MC
Why dont you measure them in an IEC444 test fixture on a VNA ?
If it needs to be measured in an oscillator, the following caveats apply:
- never overrun maximum crystal power (thats a few ten microwatts, normally). Reasons: Nonlinear effects (pulling), heating,
  in worst case electrode damage, permanent frequency change or death.
- Your oscillator needs limiting. Simple way: Schottky diode from AC base to ground.
  Better: power regulator. Pick off Colpitts output, use AD8307 log detector and op amp regulator to drive base bias.
  Advantage: power level can be accurately chosen and stabilized.
Regards, 73
  Wolfgang DL1DWG
Well, I don't use a VNA and a IEC444 test fixture, mostly because I don't have them ;), and also I have a bit of doubt that NanoVNA clone of a clone of a clone... that I can find around will have the necessary precision for sorting in a 10-20Hz range or better, I may be of course wrong, but this is it, I still don't have any of this.
I new about the the maximum power and overdriving issues, but I've thought that the people publishing these papers already designed these schematics with these considerations in mind, it seems that I was wrong as my mouth fell open when using 12V power supply for the whole test setup I've seen almost 9Vpp on the crystal terminals, I was expecting something like 0.5Vpp or such, no wonder that the drift was crazy.
Anyways reducing the supply voltage didn't change too much and around 5-6V it just stop oscillating with the current components, but just cut it abruptly instead of falling linearly.
I didn't want to  put more capacity in parallel with the crystal and add more thermal instability with the diodes, but the variable biasing idea sounds cool, as the crystals are theoretically identical, even from the same manufacturing lot, it may be possible to get away with a trimmer for a specific lot instead of AD8307, or ?
Any acctual schematic, paper and such will be most appreciated.
 73 de DC1MC
« Reply #87776 on: April 11, 2021, 12:06:51 am »
This pleases me. Quick & dirty power-up with the 15 Dollah CV/CC PSU. Initial draw ~480mA, settled down to ~210mA after a couple minutes & metal can warm to touch. TinySA shows considerable noise floor; this was expected with above PSU. Sitting right at 10.000MHz w/adj at 0.0011V; of course, resolution of TinySA is not exactly intended for this kind of testing other than signs of life as seen here.  :-+
A'aight. Parts for my Fatbike have finally arrived; time to go put the plucking thing back together.
Cheers!
 :-/O
« Last Edit: April 11, 2021, 12:09:03 am by mnementh »
The following users thanked this post: bd139, Kosmic, tonyalbus
Offline Brumby
« Reply #87777 on: April 11, 2021, 12:25:04 am »
For those of us who wanted some OCXO playthings but don't feel the NEED for 10. This seller has a twofor sale reduced for 3 hours more eBay auction: #143779790317 now for the waiting......  :)
You rat bastard.   I stayed away because of the prices for 10 - but now I am waiting on two pair ..... all thanks to you.
Harrumph! *crosses arms and glowers*
See how you ozzies are!!! I posted that same exact listing 2 weeks ago when I bought mine... at the same price!!!  :rant:
*toddles off to nuke a bicycle headlamp*
In TEA years that is lifetimes and likely 30 pages ago add to that the Server Dumpster fire hiatus and my 50+ year old brain .....
And most of all Evilbay recommended it as I looked at the 10 buy listing  a second time :-DD
Mnem - don't feel too badly about that.  Your contribution came in the early days of the exchanges where I had "switched off" to that particular subject.  Bean came along later, when my guard was down .... and now I'm seeing GPSDO references everywhere I look!!
It seems timenuttery is now seeping into my consciousness.    Oh, hell.  :palm:
« Reply #87778 on: April 11, 2021, 12:42:36 am »
Its 24degC outside, I'm drinking a Harp and doing BBQ. Life is good  :-+
Commiserations on it being Harp.  :)
Can you really still get that stuff? I haven't seen that on a pump or even in a can in the UK for years. Given the swill that a worrying number of Britons will drink under the label "lager" it might be surprising that we've given it the cold shoulder, but that we have.
The following users thanked this post: THDplusN_bad, Specmaster, bd139
Offline Kosmic
« Reply #87779 on: April 11, 2021, 01:19:48 am »
Yep quite easy to find over here. Directly imported from Ireland.
They come in those big can (500ml) and fit perfectly in a pint glass.
Offline tggzzz
« Reply #87780 on: April 11, 2021, 08:27:49 am »
It is probably better than some other stuff on that continent; Budwiser isn't good but it positively eclipses Coors.
Whenever I see a Coors all I think about is the CO2 emitted transporting that gnats' piss around. Come to think of it, gnats' piss probably has more flavour.
« Reply #87781 on: April 11, 2021, 08:33:30 am »
Harp is dead in the UK since tesco introduced “value lager”. Also surprisingly I found out that white lightning, favourite of tramps, is now somewhat respected and the tramps are drinking strongbow ?!???
Offline tggzzz
« Reply #87782 on: April 11, 2021, 08:38:53 am »
Or hand cleanser from hospitals.
I wouldn't know anout Tesco; I hate them. A couple of months ago a foolishly bought an "extra special" haddock risotto ready meal for £0.40. On trying it, it fell into the category of Asda ready meals, i.e. "do I want to finish this".
« Last Edit: April 11, 2021, 08:41:16 am by tggzzz »
« Reply #87783 on: April 11, 2021, 08:41:56 am »
Well that explains the signs on the sanitiser dispensers at my local hospital :palm:
Online McBryce
« Reply #87784 on: April 11, 2021, 09:14:19 am »
I didn't know Harp still exists at all. In Ireland it was the beer that only the very oldest Pub guests drank. In Germany the "Under the bridge" / "Down by the canal" and lorry drivers favourite is Faxe Bier and it comes in 1 Litre cans!?
McBryce.
Offline factory
« Reply #87785 on: April 11, 2021, 09:40:35 am »
With the eevblog servers as they are at the moment, that picture and the one from Mnem below your post loaded like the bad old days of the web.  >:D
« Reply #87786 on: April 11, 2021, 09:42:23 am »
Hey at least it did load. All I get half the time is the nginx 502 page.
This is irritating as well because I spend half my day at work making sure no one gets to see that  :-DD
« Reply #87787 on: April 11, 2021, 09:49:58 am »
Yep, Dave changed hosters from one lot of clowns to another lot of clowns for less 502's.  ::)
And it seems they can't be stuffed working weekends to get things sorted.
« Reply #87788 on: April 11, 2021, 09:52:38 am »
That’s not the hosters. That’s the config and architecture.
Usually a bunch of php FPM processes that serve pages. In front of that is the nginx reverse proxy. The FPM processes are dying or throwing errors. nginx is reporting that to us as 502’s. That’s entirely above the colo’s responsibility.
I’m not sure what the traffic is like but I suspect this is not enough capacity or too much capacity being used by the forum.
« Last Edit: April 11, 2021, 09:56:49 am by bd139 »
Offline Brumby
« Reply #87789 on: April 11, 2021, 10:46:12 am »
The forum, driven by its users, uses just the right amount of resources.
We would never dump excessive loads on a server - would we!   ::)
Offline tggzzz
« Reply #87790 on: April 11, 2021, 11:04:39 am »
Dr Phil Hammond[1] noted the joke was that pre-covid people nicked the hand sanitisers to drink, but a year ago they nicked them to use.
[1] a local GP, of "Struck off and Die", HIGNFY, and "MD" in Private Eye fame. Worth seeing his standup stage show; if you sit near the front be prepared to be part of it :)
Offline factory
« Reply #87791 on: April 11, 2021, 11:05:13 am »
Reasonable priced hp 428B with probe in the US for anyone interested (US only).
https://www.ebay.com/itm/203343622823
Forgot to post this last week, job lot of vintage boat sinker grade TEA (in the US) including; a hp 738BR, 200SR, 739AR voltmeter calibration set (and yes hp did offer these three together in a rack as K02-738BR, first one I've seen for sale), Genrad capacitor measuring rack, Fluke 760A meter calibrator and another rack of cal standards? from Optimation Inc that I don't recognise.
https://www.ebay.com/itm/353436335733
« Last Edit: April 11, 2021, 11:09:35 am by factory »
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #87792 on: April 11, 2021, 11:08:43 am »
ONLY if needed, would we do that. In no other circumstance otherwise, as we always try to conserve bandwidth because we are not the only users here.
 :-DD
« Reply #87793 on: April 11, 2021, 11:31:16 am »
No such signs here that I've seen. I guess our drunks are smarter or perhaps they can't read. And that is surprising considering one of our favorite past times is to sue people/companies. After all, we need printed in plain sight "coffee is hot"  :palm:
Online Robert763
« Reply #87794 on: April 11, 2021, 11:51:07 am »
And the flip side is you can buy "rust stain remover" that contains hydrofluoric acid  :palm: :scared:
www.amazon.com/Whink-1281-10OZ-Stain-Remover/product-reviews/B000LNQNM0?reviewerType=all_reviews
Offline Kosmic
« Reply #87795 on: April 11, 2021, 11:54:06 am »
Yes we got a lot worst. But it's principally me being lazy and only went to the convenience store near my place where choice is limited.
« Last Edit: April 11, 2021, 12:08:50 pm by Kosmic »
« Reply #87796 on: April 11, 2021, 12:08:44 pm »
Want some true American piss in a can with a dash of CO2?
Genesse Beer from Rochester, NY. This was (and still is) the cheap stuff when as kids all you wanted was to get shit faced on a budget. Taste was purely secondary.
« Reply #87797 on: April 11, 2021, 12:10:10 pm »
I think I would rather drink the HF loaded Drain cleaner than most of the Beers mentioned above  :P
Seriously too  :wtf: does Amazon think letting that sh1t be sold on a website to the Mass MORONS as a customer base is a reasonable thing  :palm:
« Last Edit: April 11, 2021, 12:12:03 pm by beanflying »
« Reply #87798 on: April 11, 2021, 12:12:28 pm »
They wouldn't sell us anything alcoholic when i was a kid. Fireworks, dangerous chemicals yes, but alcohol no.
So we bought cartons of apple juice, bags of sugar, bread yeast and bottles of cheap soda and made our own  :-DD. If you boil all the preservatives out of the apple juice it makes fairly good alcohol. Enough to get shitfaced on :)
« Reply #87799 on: April 11, 2021, 12:16:49 pm »
Yes, finding a store willing to sell or get someone of age to buy was always problematic but we found a way.  :-DD
Edit...back then legal drinking age in NYS was 18 (now 21) and I did get served in a bar once at 17 no questions asked.
« Last Edit: April 11, 2021, 12:20:38 pm by med6753 »
