Okay Apple nerds... I'm calling for a lifeline here.
2 questions: First, did Apple use RAID on these older MacPros from the factory? Or did they only do that with a separate RAID controller? MacPro 3.1, dual 3GHz Xeon with 4 750GB SAS drives
If I have a spare HDD lying around... what would be the gotchas for trying to install winblows to that HDD? Lots of very confusing info and fanboying over the merest suggestion of such a thing; even tho we all know these are essentially DOS boxes perverted to a "higher" purpose.
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
One tiny bit of hope from a random site splashdown stated it was easy... you just need a SATA optical drive connected to one of the HDD ports inside the machine, as Windoze10 iso won't boot from IDE, and you can't make the machine boot from USB without MacOS/Bootcamp Assistant.
So, as it seemed relatively painless, I tried this... and what I got was:
Machine tried to boot 3 different times, each time with the boot chime, I assume from other drives before the one I had plugged in with a (older, small enough to fit on a 4.7GB disk) Windows10 iso on a SATA optical drive.
On 3rd attempt it spins up Win10 to full speed and sounds like it's reading for 20-30 seconds; then stops and shuts down. A few seconds later it attempts to boot from the drive again, spinning it up for 20-30 seconds before stopping, shutting down, making the boot chime, and trying to boot from the Win10 disk again. It will continue looping like this as long as I don't shut it down. It sounds like WALL-E waking up in my living room twice a minute.
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
There is never any video of any sort; I've tried 4 different video cards, but none have a Mac-specific FW aside from the NVidia card I know is dead from testing in my PC.
So far, this is the closest to actual signs of life I've gotten from this machine. Specmaster, you may now point and laugh at the old fat dwagon who insisted that optical drives all belong in a landfill.
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
So... lifeline please. Is there something ELSE I can try, or am I pretty much boned unless I can resurrect that NVidia GPU so I can see preboot UI?
![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
