Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18836348 times)
abeyer, 6h8c and 32 Guests are viewing this topic.
« Reply #85775 on: March 20, 2021, 11:54:26 am »
Spot on. The 3478A just carries offset and scale calibration values per range in the NVRAM to do a y=Mx+c type transformation in the MCU.
« Reply #85776 on: March 20, 2021, 01:15:17 pm »
I wish it was that. Wouldn’t be having this discussion now then  :-DD.
A point to note though with some of the instruments. The 3478A and most closed case cal units tend to have the ability to read the cal ram over GPIB when cal is enabled. Part of a more detailed cal process, and full check out of the instrument, is comparing the last recorded cal data with the current one to make sure no one has futzed with the meter or any calibration issues are hardware failure related.
Yes, this is the case with the TTi 1906, it is not adjustable from the front panel.
« Reply #85777 on: March 20, 2021, 01:20:03 pm »
Ooh nice  :-+
No discord tonight. My mother had a cardiac ablation done yesterday so I’m over there this evening until late. Seems to have worked though so far.
Good News but aging Mothers are still a nuisance   :-DD  :-+ Might see if I have the urge to wet the bed and need to get up for Pain pills and Coffee in the morning....
Yeah :( just carted my mother to the hospital in an ambulance.
:(. Hope all goes well.
Yes, agreed. Hope all goes well.
I had a terrible nights sleep. After pretty much pain free yesterday the spasms returned with a vengeance last night. Still hurting a little this morning and can't sit here for long periods. I doubt I'll be on Discord later today.
Sorry to hear that, strange though, how most things always seem to get worse in the night, even common colds get worse at night  :palm:
« Reply #85778 on: March 20, 2021, 01:28:41 pm »
Incidently just rewatched Dave's video on the 3478A and from 10:30 on he talks about the battery backed RAM and if you disconnect the battery or short it out you will lose the calibration constants  and will then need to spend more money then you paid for the meter to get it traceable calibrated once again. So in his view, having a meter calibrated does indeed involve having adjustments made to the meter to return it to the design specifications again and not just verifying and noting any drift that the user should take into account when using said meter. So Dave and I both share the view that calibration is not a case of checking against references and recording the differences, but actually includes making the necessary adjustments to make the meter reflect the references applied to it.
I think if you asked Dave for his current perspective (not 2013 Dave) and in particular after visiting the Keysight Cal Labs several years later you will get a different answer. In the case of the 3478A, 34401A etc they all have a 24 Hour spec. IF one or more ranges don't meet this spec and only IF you agree after being notified they will perform an adjustment on that range or ranges. The only other time an Adjustment would be done would be if the OWNER requested it.
If it meets the 24 hour Spec then it will be issued a Certificate of Calibration.
Ok, perhaps I should have used the term re-calibration? It was always I thought the last step of production of test gear even if adjustments were able to be carried out via trim pots, digitally or selecting the final value of a part, that was all done in the calibration dept of the production process?
« Reply #85779 on: March 20, 2021, 02:11:34 pm »
Time nuttery commences. 5384A arrived. Good condition  :-+. Has HP issued sealed stickers on it so probably untouched inside. These units are RIFA free fortunately so shouldn’t need any work.
Oscillator out of junk box being tested. Tear down later. Need to go shopping and for my daily sanity walk :(
Not going to my mothers now as my sister is over there so will be on discord after all.
The following users thanked this post: BU508A, med6753, mnementh, Specmaster, ch_scr, factory, mansaxel, Kosmic
« Reply #85780 on: March 20, 2021, 02:25:28 pm »
That is nice little counter  :-+
Offline Saskia
« Reply #85781 on: March 20, 2021, 02:35:06 pm »
bought one of those 3prong unobtainium HP power cables today.
Apparently the 716 absolutely requires it and I do not have any intention to rip it apart and do dremel work on the case.
The following users thanked this post: mnementh, bd139, ch_scr, factory
« Reply #85782 on: March 20, 2021, 02:40:31 pm »
Ongoing scam, today: Advantest R6581
https://www.ebay.com/itm/402757154444
Offline Saskia
« Reply #85783 on: March 20, 2021, 03:10:27 pm »
ok, lotsanews
- got chewed out by my boss for being online yesterday
- will get chewed out on monday for fixing what those infrastructure assholes fucked up during patching today (systems down ...)
- will get the update for my notebook (+32GB RAM + 1TB SSD) on Monday. Will also get a mem expansion for my T460 backup notebook
- argument with Hubby. Want a Pogo 1,2,3 or 850. Can't afford a Pogo 40
- would sell the British car I have or trade for a Pogo 3
- Atari 800 is working. Boot error from Disk Drive. Contacted Seller. "oh, this is expected, the disk is blank"  :palm: why did he not include an effing boot disk ... (I have none, I thought at least a boot disk came with that critter)
=> into storage with that thing
- have potential customer for my Shadow pinball. Will let it go for 3500 - 4000 € ... we'll see
- had to buy a new freezer and a new fridge yesterday. The old fridge is showing a puddle of water which is never good.
- Hubby bought a few knives instead of participating in the fridge funding. Oh well.
- need to put 3 batteries onto the charger.
- need to flip at least 3 PCs
- need to to my next tax declaration. BTW for German colleagues: if you are using TaxMan they have a new call home copy protection. If you install it on more than 2 PCs it will self destruct. Unfortunately this is the best tax software for private folks / sbos out there.
- got a few PSUs the past couple of days. 2 Corsair RM550x, 1 Corsair RM750x (already installed and running), 1 Corsair HM850 Platinum ... (not yet opened, spare). Also got that 3070 installed. Need to tweak the mining rig a little, but currently it covers for one salary (Hubby's) which is gonesky due to his health condition.
- next tasks: get my Motorbike set up, fix up my Expedition (engine issues, airbag warning light, ...)
« Last Edit: March 20, 2021, 03:17:11 pm by Saskia »
Offline McBryce
« Reply #85784 on: March 20, 2021, 03:35:50 pm »
The Atari 800 doesn't need a boot disk unless you want to access disks, which you obviously don't need to do at the moment because you don't have any.
McBryce.
Offline Runco990
« Reply #85785 on: March 20, 2021, 03:44:55 pm »
I perf boarded an oscillator together for mine.  Was a simple job.   :-+
Aaaand then I promptly proceeded to run it from my external rubidium standard anyway!  But I KNOW it's IN there!
« Reply #85786 on: March 20, 2021, 03:52:31 pm »
Thanks for the reminder! I must get on with building a distribution amp for my Meinberg GPSDO. Having 10MHz on tap is soo convenient.
« Reply #85787 on: March 20, 2021, 04:11:02 pm »
Looks like Murphy's imps are out in force today. Best wishes to all with unwell mothers... I would give anything to hear mine telling me off one more time... *sigh*
Today's misery is much less important; however all-encompassing nonetheless: Somehow, I've killed the motherboard on my PC with the move to a new case. That'll teach me to try and save a buck and upgrade at the same time.  :palm:
So far, I've isolated the fault to a power rail in the VRM for the AMD Chipset... my worst fear is that it is the PCIe controller itself, rather than one of the I/O ports buggered. Chances of warranty are probably nil; MB was bought at Micro-Center in the US. |O+
"thank you sir, may I have another...?"
« Last Edit: March 20, 2021, 04:24:10 pm by mnementh »
« Reply #85788 on: March 20, 2021, 04:13:04 pm »
Similar plan. I’ve ordered some OCXOs from China. Will do a board for this one once I’ve cracked it. Board probably get here before the OCXOs do  :-DD
May grab a Leo Bodnar GPS reference on pay day as well.
I am good at a few Hz resolution here for my needs but it’s nice to know for sure  :-DD
Tearing it down for inspection now.
« Last Edit: March 20, 2021, 04:16:02 pm by bd139 »
« Reply #85789 on: March 20, 2021, 04:14:02 pm »
That’s what killed my Athlon XP I had years ago  :-DD
Good luck on fixing it though. I don’t envy the situation.
My corp Dell is being swapped out on Monday so I’m using my own kit again. I might accidentally not have the time to switch to this new one.
« Reply #85790 on: March 20, 2021, 04:28:39 pm »
Yeah... another aspect of the old saw aboot how "No good deed goes unpunished." ; should've just put my old GPU in the boi's old HP and told him it was now a gaming rig. :palm:
Currently stripping down the MB one item at a time to see if the short across that rail goes away; confidence is not high.
 |O
Offline Saskia
« Reply #85791 on: March 20, 2021, 04:30:43 pm »
how did that happen ?
Is it an Asus board ? If so you might get in touch with Asus directly, they normally have repair centers that actually fix stuff.
« Reply #85792 on: March 20, 2021, 04:38:26 pm »
Still evaluating.
2-year-old X570 Aorus Pro WiFi MB. Not likely gonna get warranty, except maybe factory-direct. Will look into it.
"Life is hard. Fortunately, it is also short." ~козак proverb
Offline Saskia
« Reply #85793 on: March 20, 2021, 04:41:10 pm »
normally 3 years factory, pickup / drop off by courier, turnaround 7 - 14 days. Been there, done that ...
« Reply #85794 on: March 20, 2021, 04:42:51 pm »
Joy to UK. Busts within 6 years: replacement via retailer.
Offline Kosmic
« Reply #85795 on: March 20, 2021, 04:52:00 pm »
My god, is it that hard to package something?
Last week I found a really decent Fluke 5200a for sale. Was in good shape and the seller accepted my offer. Shipping was a bit expensive but I figured the seller would at least do its job correctly considering the amount I was paying.
Just received this  :palm:
The box is way too small and the instrument was floating inside. Its important to specify that the weight of the instrument is around 53lbs.
A little bit of small bubble wrap between the handles and that's all. The sides and handles of the instrument was directly in contact with the box. So not much protection there.
The back handles and the frame absorbed most of the impacts during the trip.
On of the massive aluminum handle is badly bent.
A lot of plastic holder are broken.
The Transfo module is all twisted.
Metal parts are bent all over the place. I probably need to disassemble everything.
Started as a simple project but now I would need to do metal works and replacing plastic parts with the 3d printer   :--
« Last Edit: March 20, 2021, 05:06:55 pm by Kosmic »
The following users thanked this post: BU508A, med6753, mnementh, Specmaster, capt bullshot, bd139, ch_scr, syau
Offline Saskia
« Reply #85796 on: March 20, 2021, 04:53:45 pm »
the idea was to check if the disk drive was indeed working.
WIthout boot disk or any software or knowledge about the Atari that is somewhat difficult ...
I confess though that currently I am too tired to read any FM.
Offline Kosmic
« Reply #85797 on: March 20, 2021, 04:59:14 pm »
Miraculously the front panel and front handles are still in good shape.
The following users thanked this post: Cubdriver, med6753, Specmaster, capt bullshot, syau
« Reply #85798 on: March 20, 2021, 05:12:48 pm »
I’d expect it for free after that shit show. As for can anyone package stuff properly? Yes me. But I’m never in the receiving end. Perhaps I should send myself stuff so I’m not disappointed  :-DD
The following users thanked this post: BU508A, mnementh, Specmaster
Offline Kosmic
« Reply #85799 on: March 20, 2021, 05:21:55 pm »
Yes, case was open yesterday, full refund received already.  :-+
« Last Edit: March 20, 2021, 05:24:00 pm by Kosmic »
The following users thanked this post: BU508A, mnementh, Specmaster, bd139, beanflying, factory, mansaxel, syau
