Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18113125 times)
0 Members and 89 Guests are viewing this topic.
Offline 2nOrderEDO
« Reply #85700 on: March 19, 2021, 03:13:17 pm »
Looking at the service manual, I was able to find the replacement parts for the front and rear bezels in ebay, but those are for the HP3577B. Please, can someone confirm that these are equivalent? In the service manual these parts appear with different codes for the 3577A (front: 5020-8807, rear: 5020-8808) and 3577B (front: 5021-8407, rear: 5021-5808)
If the part number is different they would probably not fit on your 3577A. Normally if the part number is different, the part itself is also different.
Also, does somebody know if Keysight is still selling parts for this instruments? it seems that this frame/chassis is used in many other HP/Agilent instruments. I would prefer to buy it from them than from ebay.
Keysight is selling parts but the HP3577A is really old. I would be surprise if they still have parts for this instrument. You could contact them but ebay is probably your best bet.
I have to disagree, the later frames will almost certainly fit. They might have minor differences, the worst likely to be metric threads rather than imperial (you could check the prt number of the fasteners for the A and B models). Many keysight parts have later numbers but are still usable.
Keysight still list the later frame
https://www.keysight.com/my/partDetail/5021-8407
About $90
Well it's a gamble. Might fit but it's not exactly the same part.
Personally, since it's probably aluminum, I would simply try to use those brazing rods to repair the frame.
https://canadaweldingsupply.ca/products/blue-demon-triple-play-brazing-rod?variant=14453377925164
The frames are common across many instruments. The part number is likely for a minor production change or maybe colour.
Hey, thanks to all who replied for your suggestions and nice ideas.
For now I will try to get the front panel bezel and the side handles from Keysight. It seems that modern 5U front handles are compatible (model 1CN005A), so I will try to order both parts from Keysight directly. I may try to repair the broken frame with one of these brazing rods, after replacing it with the new one, for the sake of science. I will post how it goes, but it will take some time, since I will have a move soon.
« Reply #85701 on: March 19, 2021, 03:19:03 pm »
Hey all, am I crazy to consider spending over £4,000 on a 53230A -KEYSIGHT TECHNOLOGIES - Frequency Counter, 10Hz to 350MHz, 12 Digits, 14 mVrms, 53200A Series (https://export.farnell.com/keysight-technologies/53230a/universal-counter-350mhz-12digit/dp/1843579)??
It's going to be the first Frequency counter on my bench, and I'm looking at getting a few 10Mhz references... consider this my start into high-accuracy time-keeping fun. It's just downhill from here right?
Probably  :-DD
What are you using it for?
Is it paying work or hobby?
It's a nice counter and looking at your declared location I'm guessing there is not much choice in used. It is however a big chunk of change for one instrument. You should be able to get a used 5370B or SRS counter for a lot less. A lot of the real Time Nuts are not even using traditional counters these days. A microchip PIC based time interval counter costing a few dollars will give you lots of good data to play with if statistics are your "thing". Google PICTIC
Link http://www.ko4bb.com/doku2015/doku.php?id=precision_timing:pictic
« Last Edit: March 19, 2021, 03:22:56 pm by Robert763 »
« Reply #85702 on: March 19, 2021, 03:32:20 pm »
Just a quick question
Was Charles Goodyear the very first Tyrecoon ever?
Asking for a friend.
 :-DD
« Reply #85703 on: March 19, 2021, 03:38:07 pm »
 :-DD
And there you go Brits. Kiss my ass.  :o :P :-DD
« Reply #85704 on: March 19, 2021, 03:45:45 pm »
Not with rented lips.  :-DD
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #85705 on: March 19, 2021, 03:48:02 pm »
Put on aluminium knobs. I now declare it audiophile grade and shall raise the price trifold.
The following users thanked this post: Zucca, BU508A, med6753, mnementh, capt bullshot, cyclin_al, syau, tonyalbus
« Reply #85706 on: March 19, 2021, 03:50:50 pm »
Anyway, without further delay. Here's what is sitting in the back of the CR-V. A Type 547. And the reason the panel it is sitting on appears slightly elevated is because the full size round rubber thing with the spike in it is under there. Doesn't fit properly because it only has enough room for the temporary round rubber thing which is currently mounted on right rear. New full size rubber round thing is on order and will be here Monday.
More info on the 547 later. Also attached is the original CL ad.
The following users thanked this post: Cubdriver, BU508A, mnementh, Specmaster, capt bullshot, bd139, ch_scr, beanflying, cyclin_al
Online tggzzz
« Reply #85707 on: March 19, 2021, 03:55:29 pm »
Where do you keep your ass? In your stable?
Or are you referring to your complete self?
Hint: we have an arse, and an ass is a donkey or stupid person.
https://www.oxfordlearnersdictionaries.com/definition/english/ass
« Last Edit: March 19, 2021, 03:57:04 pm by tggzzz »
« Reply #85708 on: March 19, 2021, 03:59:53 pm »
 :P :P
Offline McBryce
« Reply #85709 on: March 19, 2021, 04:00:03 pm »
All this talk of tyres is tyring.  :P :P :-DD
I always have to laugh when Americans try to "correct" English speakers on their spelling! Here's one for you:
On labour day I went over to my humourous neighbour to borrow his coloured tyre guage.
McBryce.
gauge*
 :popcorn:
I never claimed I could spell, but I knew there was a "u" in there somewhere.  ::)
McBryce.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #85710 on: March 19, 2021, 04:01:12 pm »
Nice score, Mike!  Hope your back gets to feeling better so you can get it inside.
-Pat
The following users thanked this post: med6753, Specmaster
« Reply #85711 on: March 19, 2021, 04:07:32 pm »
This one's just for you, BU508A>:D
More cheap "Dupont" connectors... This time, since the wire is only 26 gauge, I used the smaller crimp slot. Excellent crimp, and both terminals fit in the shell perfectly without any post-op fuckery required. I now have power for my new redundant CPU temp gauge. :-+   That doesn't make the crimps any less cheap crap, of course.  ;)
agitate...? moi?
« Last Edit: March 19, 2021, 04:14:04 pm by mnementh »
« Reply #85712 on: March 19, 2021, 04:10:58 pm »
 :P :P
 >:D
Offline Saskia
« Reply #85713 on: March 19, 2021, 04:21:05 pm »
future salami :)
The following users thanked this post: McBryce, mnementh
Offline Mr. Scram
  • Display aficionado
« Reply #85714 on: March 19, 2021, 04:26:50 pm »
This chip shortage sucks. >:( At this point not just parts, but entire product categories are out of stock. Can't design around that.
« Reply #85715 on: March 19, 2021, 04:27:26 pm »
I was looking today at this beauty:
So in order to get closure i dug deep into my pockets ad bought the 250 watt model  :) here:   https://www.aliexpress.com/item/4000512825009.html
Bwahahahaha!
Good choice. I have two; one for quick & lazy power, and another set up as a cheap & cheerful ATX load tester.  :-+
*back to The Sleevening*
« Reply #85716 on: March 19, 2021, 04:45:50 pm »
Hmmmmm
@Specmaster:
You mean, the tyre of med6753 is going to be retyred, then? :-DD
How did BU508A feel after med's CR-V drove over him?
Tyred and exhausted.
The following users thanked this post: BU508A, Specmaster
« Reply #85717 on: March 19, 2021, 04:52:48 pm »
I just realized with all this agitatin', I forgot to congratulate you on your new enheavyment, med. Excellent find. :-+
Eat it in good health!
 :popcorn:
« Reply #85718 on: March 19, 2021, 04:54:24 pm »
 :-DD
Well..... we can't miss can we, after all, according to the lady cop, it glows in the dark  :-DD :-DD
« Reply #85719 on: March 19, 2021, 05:18:45 pm »
Mini rant: Kubernetes is Pandora’s box incarnate. No one knows entirely how it works. No one knows entirely what it does. But the outcome is nearly always mayhem and chaos. Much like “The Cube”, it is written by lots of people who independently concentrate on their little bits of the machine unaware of each other and the sum of the parts resulting in the destructive potential for the cumulative pile of mistakes in each part. From synchronising state across several partitions, through Rube Goldberg chains of events, struggling through eventual inconsistency and landing on mutant vocabulary they have succeeded only in removing understanding and determinism from computing. When all hell breaks loose you cannot reason about fixing it because of the inane complexity because you can’t communicate the problem nor rationalise it due to the non determinism.
At this point I am going to sit back, buy test gear to play with and watch it all fucking burn and hope I get paid to pretend I give a shit.
If this is entire thing means nothing to you then you are lucky bastards.
And med, nice score. Even if it cost you a tyre ;)
The following users thanked this post: Zucca, BU508A, med6753, mnementh, ch_scr, mansaxel, cyclin_al
« Reply #85720 on: March 19, 2021, 05:24:56 pm »
-Pat
He should get himself a hand-truck, with some of those little round rubber things on it, perhaps even of the stair-climbing variety. Or perhaps it's better to just go straight to the Zimmer frame.  :)
« Reply #85721 on: March 19, 2021, 05:28:48 pm »
I've realised I never oughta go close it. Sooner or later a multiuser operating system with several processes coöperating in a common namespace will be the thing again. Or I'll run FreeBSD jails if I have to. On top of bhyve.
« Reply #85722 on: March 19, 2021, 06:17:24 pm »
Karma is good to me after that rant. I just bought a 3478A to match the 5384A  :-DD
The following users thanked this post: BU508A, med6753, ch_scr, mansaxel
Offline McBryce
« Reply #85723 on: March 19, 2021, 06:28:13 pm »
 :-DD
I knew a guy who made a tyre out of 365 used condoms... He said it was a Goodyear! :D
McBryce.
Apologies, possibly the flattest Automotive joke I know.
Offline Saskia
« Reply #85724 on: March 19, 2021, 06:35:32 pm »
while we are at it ...
1197552-0
Now to enhance communication ...
1197556-1
but always
