There is good, there is fabulous, and there is good enough.
Agreed. But it depends highly on the definition of what is
good enough.
In my case it means using good or very good tools. In my younger days I've destroyed things because
of not using proper tools and I badly regretted it every time. And then this has becoming a personal
approach of mine: use ALWAYS the proper tool and MINIMIZE the danger of destroying something.
Consequently it doesn't matter to me, if, for example, the connector is simply for a PC speaker or if it is
for something important/expensive etc.
To quote Scotty:
https://getyarn.io/yarn-clip/ff8609de-278d-48bf-8c0e-036749f825deI know, that there are situations, where you don't have the proper tool at hand and then you have
to decide carefully, if it is okay to mess around or if you are getting the right tool for the right job.
Example: when I changed in our house the main power supply cable (5x 16mm²) my Knipex 97 53 14
wasn't capable for the job (crimping ferrules, max. size 10mm²) so I ordered a Knipex 97 53 04 which
can do up to 16mm². Never regretted the purchase, even though I haven't used it since then. But for sure,
one day I'll do.
I don't need fabulous with a stoopit PC speaker or RESET switch wire; good enough is... good enough. I am more than capable of evaluating whether a crimp is good or bad; the tool doesn't change that, it just makes a good crimp easier.
I presented this so that other people with similar knowledge could make an informed decision about a readily available tool that might get them out of a jam. I think that knowledge is just as important as choosing the right tool for a job.
Yes. Essentially we aren't really discussing the quality of the tools being used, we are discussing our
different approaches on how to do a job
good enough.
I disagree aboot the idea of this tool harming KNIPEX in any way... it simply is not the same market. People looking at this tool are not going to be buying KNIPEX unless they find they really enjoy the kind of work this tool makes possible. Those people are going to buy upwards when this cheap tool wears out, probably sooner once the hassle of triple-checking every crimp starts to cost them real time & money. For those people, the cheap tool often serves as a gateway drug.
If you look at how many variants there are of it out there, it is obvious that the similarities are entirely due to the nature of the tool, not attempting to look like any particular brand.
Perhaps. But then, why must the design look like as Knipex?
As I've said many times... The best tool is always the one you have when you need it.
And that is why I have most of my tools stored in these really nice Dewalt TSTAK boxes.
Sturdy, easily to carry around, handy, easy access.
https://www.dewalt.com/products/storage-and-gear/tool-storage/tstakExample setup:
Knowing aboot things like this means a person can have a lot more tools when they need it, not wishing they had it. It also means that folks like you, who have good reason to choose the best, can point to my review with line item reason for reason to recommend a tool that costs literally 15 times as much.
In my opinion it is not only the price of the tool itself. If you are using a cheap tool and destroy something,
then it will cost you lifetime and effort to fix it. That's not worth it to me. And if I have only proper tools,
then I don't need to think about the quirks etc. which probably may come with a cheap one.
To me, it is that simple.
Cheers,
Mounty
