Hi again folks,
![Test Equipment Anonymous (TEA) group therapy thread 1196486-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=81471.0;attach=1196488;image)
![Test Equipment Anonymous (TEA) group therapy thread 1196490-1](https://www.eevblog.com/forum/index.php?action=dlattach;topic=81471.0;attach=1196492;image)
I was able to score an HP3577A, it looked really well in the pictures (see below) but when it arrived (from the US to Switzerland) it had a crack on the bottom right corner of the front panel bezel. The crack can't be seen when the instruments is laying on the bench, but the front panel has deformed a little bit in the corner. The rear panel bezel also has a small hit. Functionality wise, it passes all self-confidence tests and I plan to tear it apart to the last piece for rectifiying the front panel, recaping electrolytics, fan replacement, changing the EPROMs to EEPROMs, etc.
![Test Equipment Anonymous (TEA) group therapy thread 1196482-2](https://www.eevblog.com/forum/index.php?action=dlattach;topic=81471.0;attach=1196484;image)
Now guys, I want to take advantage of you knowledge, so some questions follow:
Looking at the service manual, I was able to find the replacement parts for the front and rear bezels in ebay, but those are for the HP3577B. Please, can someone confirm that these are equivalent? In the service manual these parts appear with different codes for the 3577A (front: 5020-8807, rear: 5020-8808) and 3577B (front: 5021-8407, rear: 5021-5808)
Also, does somebody know if Keysight is still selling parts for this instruments? it seems that this frame/chassis is used in many other HP/Agilent instruments. I would prefer to buy it from them than from ebay.
Are the bezels made of steel or aluminum? Maybe I can repair the crack on the front bezel with one of this metal-epoxy glues sold as "cold welding".
I also plan to install the front handles, since the thing weights 28 kg (62 lbs) and I want to be able to move it a little bit more easily. Would any 5U front handle from HP/Agilent work? The one the service manual specifies (5062-3991) look very familiar to the new versions. Are they compatible?
![Test Equipment Anonymous (TEA) group therapy thread 1196482-3](https://www.eevblog.com/forum/index.php?action=dlattach;topic=81471.0;attach=1196484;image)
![Test Equipment Anonymous (TEA) group therapy thread 1196486-4](https://www.eevblog.com/forum/index.php?action=dlattach;topic=81471.0;attach=1196488;image)
![Test Equipment Anonymous (TEA) group therapy thread 1196490-5](https://www.eevblog.com/forum/index.php?action=dlattach;topic=81471.0;attach=1196492;image)
Any advice you may have is welcome!
