In a sane world, that would be the
only salient point. But the difference here is economies of scale vs marketplace, I'll wager.
The G1200 is aimed at the school student/hobbyist/gizmo addict; a much larger market than the USB one intended for professional/semi-professional use. As a result, the G1200, etc can be produced very cheaply, even including a mostly superfluous 5-7" LCD (that costs a few dollars in bulk) compared to a USB only model that will be marketed to a much smaller, more technically savvy market.
Sadly, you can get a better camera and a better elevator and a LCD you don't need, and still pay less simply because the device can be produced in larger quantities per run.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Just out of curiosity, how much did you pay for yours/which model? I see a number of different USB-only AndonStar models at a huge variance in prices.
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
![Tweak :-/O](https://www.eevblog.com/forum/Smileys/default/smiliey_cal.gif)
