We should offer him a senior membership in the TEA forum:
I say no to that, he is just another variation of an audiophool.
He's not that bad. At least he's fixing and appreciate TE. Yes, he is not using them as it was intended and he is doing some mods sometimes. Personally, as long as it's not going in the garbage it's fine with me.
I don't have an issue with what he's using them for, as you say, it's not going in the garbage, but he has other stuff like voltage and current calibrators, power supplies etc that he admits is not of any use to him. Things like signal generators he can use, and I'm fine with that, but he knew that some of the gear he collected was not going to help to make music, that what I object to.
Similar thought here. He is using most of the equipment and definitely mis-using it, but I do not see any blatant abuse of the equipment.
He did not give any indication of what he is going to do with the gear that he has no use for.
There could be a win-win in here somewhere.
If he sells the things he has no use for into the TE community, then we can get the TE back to where it belongs and in doing so provide some funding for his museum.
