*eeeep!* fly away, fly awayyyy!!!
Sorry... lemme get some wipes and I'll clean that right up...
no, the irony is not lost on me.
Spinning a glider is a known way to lose altitude fast. Daughter puked after spinning down from 4000ft to circuit level.
Normal pre-solo training typically has you doing three multi-turn spins starting at 1500-2000ft; don't enter the 3rd spin below 1000ft. Powered pilots absolutely can't believe it.
Here's a buttock-clenching "low energy" landing. See if you can guess where the airfield is, then skip through every 30s to see if you got it right
Scariest thing for me, was losing the tow at 400ft (my fault, didn't check the thing properly).
Luckily, I was just the student!
The Instructor, whom I had heard described as "being able to fly a hayshed", landed us safely.
The big Jarrah & Marri trees at the edge of the field looked bloody close, though!
I gave up learning gliding, as I was on shift work, & sailplane pilots are a migratory species.
It got a bit old to turn up at the usual "cow paddock" on the alternate Sundays I had off from work, only to find everybody had decamped for Narrogin, or Cunderdin, both 100 plus km away!
It really was a "cow paddock" ----the Cessna towplane often ended up with cow poo "under its armpits!"
