Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17500144 times)
_rushin_or_draggin_ and 131 Guests are viewing this topic.
Offline tautech
« Reply #83250 on: February 20, 2021, 11:40:31 pm »
What you don't want to see on your United Airlines flight 328 from Denver to Honolulu:
(It landed safely.)
You're not kidding, I bet there was a few soiled pants on that flight when it landed.
Yes of course as the public have no idea how hard pilots need train for these types of failures and as it can be seen there's no apparent damage to the airframe or control surfaces and therefore a 777 is perfectly safe to operate with just one engine however landing distances become greatly increased without the full reverse thrust that 2 engines can generate.
Offline factory
« Reply #83251 on: February 20, 2021, 11:55:26 pm »
A quick teardown, this radio uses a lot of those Mullard/Philips AF11x series transistors that have a bad reputation of failing with tin-whisker related shorts, despite this I haven't had any trouble with them yet.
Where, them mighty hard to spot ?
In the tin cans ?
I've added some arrows to the AF series transistors, there are four AF117 according to the circuit diagram, something doesn't add up as all the other listed types are in different packages and I see five of the AF117 size.
« Last Edit: February 21, 2021, 12:10:01 am by factory »
The following users thanked this post: tautech, capt bullshot
Offline srb1954
  • Retired Electronics Design Engineer
« Reply #83252 on: February 20, 2021, 11:59:26 pm »
(It landed safely.)
The flames are bad enough but what is more alarming is the severe vibration.
If I was looking out the window at that engine I would be thinking that it's going to fall off at any moment.
Offline factory
« Reply #83253 on: February 21, 2021, 12:02:21 am »
Sort of TEA related (has a voltmeter built in), I posted a pic of my shed radio (a Danish made Sailor 16T) a while ago and someone on here was interested in seeing inside it, well I've finally had enough of the voltmeter under-reading and decided to adjust it.
Here is the problem I have, with an external supply set for 9V I get a reading of approx 8V of the built in meter.
Having a look at the circuit diagram they used a 10kΩ resistor in series with the meter with no provision for adjustment, it's on the power switch (arrowed).
A decade resistor was used to determine what value could be added in parallel to give a better reading, I came to the conclusion the best compromise was 83kΩ, I used a 120kΩ & 270kΩ in parallel across the original resistor.
All back together with fresh set of 6 D sized leak-tubes.  :D
I have never before come across a radio which has NW on its dial and range switch, WTF is that then?
Sorry I haven't a clue, I couldn't find anything on the NW band, maybe it's obsolete or been renamed?  :-//
Offline tautech
« Reply #83254 on: February 21, 2021, 12:07:45 am »
In the tin cans ?
I've added some arrows to the AF series transistors, there are four AF117 & one AF101 according to the circuit diagram.
:-DD Ain't it funny how they did stuff back then !
No wonder they were hard to recognise.
Offline factory
« Reply #83255 on: February 21, 2021, 12:12:24 am »
It was intended for marine use, hence they are all held in place.
I've corrected the previous post as the other transistors type use different packages, but I see five AF117 sized transistors.  :-//
Offline tautech
« Reply #83256 on: February 21, 2021, 12:16:27 am »
Or they hadn't evolved from point to point construction to being able to properly route a PCB.  ;)
« Reply #83257 on: February 21, 2021, 12:18:31 am »
Re: Electronic loads: After having the parts to build one on the shelf for like 5 years I bought one of those:
https://nl.aliexpress.com/item/4000580653360.html?spm=a2g0s.12269583.0.0.35ff2d2832gPfP
CV, CC, CP and CR, 220V/20A/150W, color display, bluetooth, app. 25 eurobucks, No idea how they make money on this  ;)
Seems there are two versions around:
I have had one of the earlier versions for a couple of years now even then there was several obvious cloned versions of the 150W Load. Unless you need to do any hardcore load testing over time one of these teamed with a logging Multimeter or two makes a lot more sense then spending a lot more for 'features'.
« Reply #83258 on: February 21, 2021, 12:19:16 am »
(It landed safely.)
 >:D
Offline vk6zgo
« Reply #83259 on: February 21, 2021, 12:25:05 am »
In the tin cans ?
Easy for those of us who were around, Sonny!     ;D
« Reply #83260 on: February 21, 2021, 12:26:09 am »
https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/msg3473896/#msg3473896
I took a long look this morning at bang-em-good's current lineup; they've def upped their game in that corner since the last time I searched electronic loads with them. Lots of links in my post above.
*couch-tuber time widda boi*
Offline vk6zgo
« Reply #83261 on: February 21, 2021, 12:27:14 am »
Philips did that with their early transistor portable radios, too.
Offline tggzzz
« Reply #83262 on: February 21, 2021, 12:29:05 am »
(It landed safely.)
Worse would be from Honolulu to Denver :)
The simple matter-of-fact captain's report that really caught my imagination was a 1989 incident where an engine detonated. To me it is much more terrifying and a much greater fear of airmanship than Sullenberger's landing in the Hudson - when other pilots reproduced it in simulators, they all failed and would have dieduuu.
The captain gave a leture at NASA Ames Research Center as a form of therapy, and I first saw this transcript on usenet: https://yarchive.net/air/airliners/dc10_sioux_city.html
They made it into a not very good film, which completely failed to get over the rather important small details. One that stuck in my mind is that afterwards in the hospital the captain completely failed to recognise the third pilot who came into the cabin to help control the aircraft - because he never looked at his face while they were flying.
Offline tautech
« Reply #83263 on: February 21, 2021, 12:30:42 am »
In the tin cans ?
:P back at ya !  :)
So as you were around back then how long was it before you recognised long leads on those transistors for example might be counterproductive to low noise sensitivity ?  :popcorn:
Offline Neomys Sapiens
« Reply #83264 on: February 21, 2021, 12:46:17 am »
I have two electronic loads: A Zentro ELA 40/40D (40 V/ 40 A, 200 W) and a TET 60 V/ 100 A. Alas the latter is dead, and there's absolutely nothing to find about it. I opened it once and and looked for something to measure, like a supply voltage, when suddenly both supersonic wind tunnels sprang into action, startling me to death. :o Still, it didn't work. And even after looking for half an hour, I hadn't find a way to disassemble it. My relationship with mechanical engineers is a bit strained. ;)
Ein MASCHINENBAUER ist ein Landwirt nach dem Erwerb des ersten selbstfahrenden Arbeitsgeraets!
The following users thanked this post: capt bullshot, Ero-Shan
Offline SilverSolder
« Reply #83265 on: February 21, 2021, 01:00:28 am »
The vibrations are likely why everything fell apart in the first place.  Wonder if there is an "engine vibration monitor" in the cockpit?
Offline vk6zgo
« Reply #83266 on: February 21, 2021, 01:21:07 am »
(It landed safely.)
Much nicer to see something like that just after takeoff, instead of in mid-Pacific!
On the subject of looking out the window & being a bit disturbed, I recall, back in 1968, looking out the window at the wing of a Viscount & being a bit worried that the riveted panels seemed to have largish gaps, rather than sitting flush.
I put it down to a jaundiced view of the Viscount, compared to the Fokker F27 I had been travelling in previously, which had a short take off distance & a fairly spectacular climb rate for an airliner.
With the much bigger & older beast, I was surprised by how long it took to reach operating height.
About when the flight attendants were normally handing out "munchies" & pouring coffee in the F27,the Viscount was still groaning & moaning to gain height.
With nothing else to do, I returned to gazing out the window, & apart from the rough looking constuction of the panels, compared to the Fokker, noted a large amount of wing flex.
"Don't be sillly!", I told myself, it just looks different, not necessarily worse!
Sadly, a couple of months later, on the same route, that aircraft "fell out of the sky"--------& yes, a wing fell off! :o :o :o
« Reply #83267 on: February 21, 2021, 03:06:51 am »
(It landed safely.)
Wow, that no mechanic caught the signs when the rivets are literally popping out...
I imagine some techies are sweating now, about answering questions about an engine vibrating itself to death after they just gave it the All Clear...
« Reply #83268 on: February 21, 2021, 03:55:26 am »
But deregulation has nothing to do with it at all.  :palm:
Nothin' to see here folks; move along, move along...
Offline 25 CPS
« Reply #83269 on: February 21, 2021, 04:34:03 am »
You have now, my old Beckman 310 has a 22MΩ input impedance for Vdc (warning 2, 20 & 200 Kelvin Ω ranges may trigger  :-DD);
The newer Wavetek (took over Beckman) HD160B isn't 22MΩ, but still has the 1500Vdc range as the older meters do.
I agree with hooking the probe on before power-up, something Shango066 does on many TV resurrections to monitor the HT voltage (a common problem area with ancient TV's) while bringing them up with lamp-limiter and/or variac and while capacitors are reforming.
Cool.  I figured there had to be at least a few meters out there with 22 M\$\Omega\$ input impedances out there otherwise nobody would've bothered making accessories like that probe that depended on that characteristic.  It's just not one I've encountered before.  Everything I've run across has either been 10 M\$\Omega\$ or the really, really high impedances on some of the ranges that HP/Agilent and similar bench meters have.
Woah, I completely missed that part. I found some specs online and they were talking 10M. I guess it was the model HV321-10. 22M is weird. I don't think I even seen a meter with a 22M input impedance.
I double checked my meters and I'm SOL so I'm going to let it go.  I wonder if that probe's eventually going to end up with someone making a quick decision to buy it based on price but then finds out the hard way once it arrives and they try to use it that the readings are all off if their meter doesn't happen to be correct for it?  I just have the sneaking suspicion that someone out there's going to end up disappointed.
Offline capt bullshot
« Reply #83270 on: February 21, 2021, 08:35:41 am »
Looks like one of these that have only one transistor to dissipate the load, and their spec equals the transistors spec @25°C. Doesn't take much effort to toast them.
The KP184 at least has 6 transistors to dissipate 400W, so I'd expect it to stand longer ...
« Reply #83271 on: February 21, 2021, 08:37:16 am »
Would someone like to explain to a thicko (me) what is the actual difference between a 75 \$\Omega\$ and 50 \$\Omega\$ BNC and would I tell them apart?
Easy with a new toy like capt bullshot has got....a VNA !  :-DMM
To spot that difference, one must have $$$ cal kit and cables, too ...
Offline tautech
« Reply #83272 on: February 21, 2021, 08:39:18 am »
Only for accurate measurement as you will still see the differences.  ;)
« Reply #83273 on: February 21, 2021, 08:45:27 am »
What does the "distortion" actually look like, if it is only the connector that is 75 ohm and the rest of the circuit is 50 ohm?  Does it reflect energy at higher frequencies, or something like that?
Offline tautech
« Reply #83274 on: February 21, 2021, 08:47:18 am »
Larry Major (older larrikin son in Perth) sent a pic of his spa pool pump motor that kept eating impellers as it occasionally ran in reverse rotation ........pretty obvious why.  :palm:
The following users thanked this post: Zucca, Specmaster
