So how many more are we going to add to this list of cars that had a really, really bad design? Showing more examples of a bad idea does not make it a good idea; it just shows there were more than one person who had that bad idea. ![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Like that giant-scale UAV built from hobbyist-grade quadcopter parts and being flown over spectators with firmware that clearly didn't have any failsafe programmed. ![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
That said... obviously I was wrong in that nobody ever did it. I stand (well, sit) corrected. Just because i have trouble believing anyone would make such a poor design, does not necessarily make it so.
I guess this proves what my grand-dad used to say... "There is no idea so bad that someone hasn't tried to make a buck off it."
![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
So what design would you propose to put an automatic gearbox into a compact car with front wheel drive and transverse engine?
Just because you don't like it does not meant it is a "bad" design. It worked an was in production in many models of car for over 40 years so not that bad.
So it needed more frequent oil changes, but no ATF or smelly ggearbox oil and not as frequent as the 3000 mile changes the americans seem to like, believing the marketing hype from Jiffy lube, Midas and the like ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
You just will not let it go, will you? How many such transmissions have YOU serviced under warranty, to manufacturer's specification? Do you even
know how to change the oil on a Toyota...?
The world is FULL of compact cars with transverse engines. That is literally the single most common configuration there is, and most of them do
not recirculate all the filth created by the engine into an automatic transmission.
The thought of what even a thimbleful of engine sludge would do to a modern automatic trans just fills me with dread. To deliberately introduce that kind of contamination into such a transmission is abhorrent for a laundry list of reasons. As you work with aircraft for a living, I know you know the kinds of tolerances I'm talking aboot, so your argument that regular, frequent oil changes aren't important is disingenuous at best.
You're deliberately creating an argument you know is wrong. Oil is cheaper than metal, and keeping it clean is how I've kept cars running past the 250K mark for decades.
If it was a good design, why did they not keep it when they re-released the "little toy car that could...?" Oh right... because nowadays people expect to get 200K out of a transmission, not 60K. And nowadays, 200K on the original drivetrain, from throttle-body to engine to axles to lugnuts, is not unusual. So fuck your childish arguments aboot smelly oil, etc. too. Obviously these modern designs
are better.
FFS man...
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
