This is not Larry. This is Moe. I noticed that the 50 ohm switching paths on both channels were a little noisy. And after discovering how relatively easily those attenuator assemblies could be removed I decided to pull both and clean them. And after reassembly gave the 1MEG compensation a touch up.
And so....Moe on top utilizing that wondrous 1MHz calibrator@50 ohm that tggzzz is so fond of.
None of that 1MEG rubbish. Larry on the bottom continuing the burn-in process utilizing the 5kHz* test signals.
* I expect the purists to recognize and acknowledge that the "k" symbol is lower case and in proper use. After all, you bust my balls when it isn't used properly per current standards.
