Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16730055 times)
Vince, morris6 and 130 Guests are viewing this topic.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #81850 on: February 07, 2021, 10:41:24 pm »
Storm #2 is clearing out - much less snow than the one last week.
-Pat
The following users thanked this post: BU508A, mnementh, capt bullshot, Mortymore, bd139
« Reply #81851 on: February 07, 2021, 10:44:43 pm »
How in the hell did these ever remain flying when they had Lucas electrics?  :scared: :P :-DD
Simples, Lucas weren't as bad as people make them out to be. A lot of the problems were more than likely caused by the car manufacturers themselves.
« Last Edit: February 07, 2021, 11:00:39 pm by Specmaster »
« Reply #81852 on: February 07, 2021, 10:59:04 pm »
That Landy is a clear winner, winner, chicken dinner!
Which you would be able to cook on the firebox.
If everyone had something similar then we would be seeing the possible return of Tuberculous and the infamous pea soup smogs that used to be the norm in the 70's.
I can remember driving a Ford D series truck through those deadly smogs and no word of a lie, in London and other towns and cities, when they were bad, visibility would be down to about 60 feet or 2 bus lengths at most and more people were dieing as a result of breathing that pollution, then there are people dieing today as a result of pollution. I think that there was far more damage to the global warming back then than there is now. Nowhere near as many people burning wood or coal/coke to keep warm and heat water and these days engines are considerably more efficient with MPG and BHP doubled or even trebled in real terms and far cleaner exhausts.
« Reply #81853 on: February 07, 2021, 10:59:57 pm »
Heads up for the UK TE buyers. Don’t buy this: https://www.ebay.co.uk/itm/224343146214
This is the one I sold that blew up  :-DD
Apparently smoke comes out under load.
« Reply #81854 on: February 07, 2021, 11:04:18 pm »
Thats a crap design with the power cord entering via that hot surface. It must get pretty hot to have a warning sign like that applied to it surely  :-//
« Reply #81855 on: February 07, 2021, 11:05:38 pm »
There’s a large gap. Only the top gets hot. The bottom is a red strip across the barrier strip for programming as there are high voltages there.
« Reply #81856 on: February 07, 2021, 11:06:31 pm »
Oh, OK
Online factory
« Reply #81857 on: February 07, 2021, 11:07:11 pm »
If you refunded them, why didn't they return it? Bit dishonest if they are selling it and you did refund them.
Edit: Added that seller to my blocked bidder list.
« Last Edit: February 07, 2021, 11:36:25 pm by factory »
« Reply #81858 on: February 07, 2021, 11:15:56 pm »
I refunded it and said they could do with it what they pleased. If that’s selling it, up to them. I am somewhat done with HP supplies  :-DD
I am retaining a singular TTi PL320 at the moment and that’s it.
I have a 6205b with bust range switch on channel A soon if anyone is interested (UK only). I have yet to locate a suitable box for it though so might be a while before I can send it.
« Last Edit: February 07, 2021, 11:17:58 pm by bd139 »
Offline Cubdriver
  • Nixie addict
« Reply #81859 on: February 07, 2021, 11:18:27 pm »
They're load resistors, enclosed in a little box that hangs of the rear of the supply.  The mains cord ducks under them and is fed into the rear of the enclosure in the same place it is on the other, similar supplies in that series.
-Pat
Online factory
« Reply #81860 on: February 07, 2021, 11:20:05 pm »
I've also been working on the donor board from Sphere for the 5243L, the original had the same photo-resistor plate corrosion problem as the 5248M giving multiple numbers lit at the same time.
All the resistors & transistors in the green box were removed & replaced with the correct parts as the original had.
On testing it initially had some ghosting of other numbers, but in the time it took me to have a look through the manual it had corrected itself, guess it just needed some use. Still need to relabel the board with the correct part number.
There is at least one problem still to fix, the heater control circuit for the crystal oven, it doesn't turn the heater on at all.
And it needs the wiring loom modification to allow use of later plug-ins.
« Last Edit: February 07, 2021, 11:26:34 pm by factory »
The following users thanked this post: Cubdriver, BU508A, med6753, mnementh, bd139, Kosmic
« Reply #81861 on: February 07, 2021, 11:37:25 pm »
Signs of life. Quick power up, most of the soft buttons seem to work, relays click in and out and drawing about the correct current.
Double shot Coffee then see if it is a dead display or find the manual and play with the contrast maybe ??? So far better than expected for the few pesos.
The following users thanked this post: med6753, bd139, Kosmic
Online factory
« Reply #81862 on: February 07, 2021, 11:41:03 pm »
-Pat
I wonder if the smoke smell from the ePay one is a RIFA problem or the smell of hot dust from those power resistors.   :-//
« Reply #81863 on: February 07, 2021, 11:41:45 pm »
P.S.: Don't place too much trust in the ability of gas stations to provide your KESSELSPEISEWASSER!
The treatment of steam engine  water supplies is a complicated matter. You want just the right amount of chemicals in your water, and since you're not condensing but just "topping up" (to the tune of several cubic metres per day for most engines) all the time, there are some interesting points:
  • You really, really will want to be sure to be able to top up. If boiler water levels sink to below firebox roof, you have a boiler explosion coming, sure as RIFA.
  • Thus, your treatment must be economical, and at the same time adapted to the local chemistry at the watering point.
  • Some machines can't deal with the steam from such plants, like steam turbines. Both the Reichsbahn turbine trials and the SJ/NOHAB engine were equipped with condensers and a closed feedwater system.
  • Same applies in desert situations, a condenser has been the solution for some desert lines. Good luck running a condenser in 35°C..
« Reply #81864 on: February 07, 2021, 11:48:08 pm »
Dinner would taste of WD40 and moss though.
No, you don't use WD40 on a steam engine. You use proper steam oil.
Offline vk6zgo
« Reply #81865 on: February 08, 2021, 12:06:00 am »
I don't think they did use Lucas equipment!
Obviously, I wasn't around during the Battle of Britain, but looking at old copies of "The Aeroplane", & other publications of the period, I have the distinct impression that such stuff was made/designed by a different, specialist, manufacturer.
Lucas may have made some parts under contract, like many others did, however.
Joseph Lucas always struck me as having a hubris problem, & were sure they were the best, in the face of mounting evidence that they were not.
I think that is the only explanation as to why they didn't just buy some Bosch stuff & reverse engineer it to find out what that company did right, & Lucas did wrong.
The Solex & Zenith carburettors so beloved of Brit carmakers in the 50s are another example:-
The Stromberg single barrel downdrafts used by Holden were simple, rugged, & reliable, in fact, there was a thriving cottage industry in Oz, back in those days, rejetting Strombergs & fitting them to "Pommy" cars, to replace the fiddly, fussy OEM carbs.
« Reply #81866 on: February 08, 2021, 12:51:09 am »
ON THE BENCH TONIGHT: Making the World's Tiniest PCB!   ;)
That's it right there... two whole holes worth of 0.100" pitch perfboard. Why? To support that hair-thin bit of hardened brass wire off one of these Ardu vibration sensors so I can install it in my favorite T12 soldering iron handle. That wire is actually the other end of a tiny coil spring; it is uber-brittle and will snap off flush at the slightest wiggle.
This PCB serves as a base so I can solder pigtails of more workable soft enameled copper wire on it. Add a little Kapton tape as insurance, then bundle the whole thing up in heat-shrink and we're good to go for another year or three.  :-+
Oooohhh... it is so nice not having the damned thing go to sleep all the time while I'm using it; almost like using a different soldering station altogether.  8)
*tssssst....*
« Last Edit: February 08, 2021, 01:00:06 am by mnementh »
The following users thanked this post: Specmaster, Kosmic
« Reply #81867 on: February 08, 2021, 01:03:51 am »
They may have used CAV which was the commercial division of Lucas making primary diesel injection pumps and electrical bits for buses, marine craft and trucks IIRC there was also another company called SIMMS who did similar.
« Reply #81868 on: February 08, 2021, 01:26:03 am »
Dunno if CAV was around back in the 40's but certainly in the 70's when my TK Bedy was built with a 100A 24V CAV alternator and diesel system.
Offline SilverSolder
« Reply #81869 on: February 08, 2021, 01:48:41 am »
I once had a great chat with an elderly gentleman who worked for Lucas in that period.  He explained that the Lucas men knew what they were doing, but they were asked to crank out production on ancient and well worn machines that couldn't maintain precision.  This meant that good designs ended up being badly implemented, as well as bad designs being chosen simply because the old machines could make them.   He put it all down to lack of investment and lack of respect for the engineering profession by the British upper class at the time.
Online Kosmic
« Reply #81870 on: February 08, 2021, 01:54:11 am »
Got a new voltnut toy and it's a Keithley :scared:
A deal popped on ebay and I couldn't resist. Bought this Keithley 182 nanovoltmeter to replace my Keithley 181. They both use the same connector and leads so it's an easy upgrade for me. Compared to the 181, the 182 has a little bit more resolution and less noise. It's also more modern and got more filtering, buffering and triggering options.
I removed the shield over the analog section to take this shot. The meter use the LM399 voltage reference like many other 6.5digits meter.
Close up on the input section of the PCB. This is where the magic happen. The input resistor is crimped and then screwed to the board to limit thermal EMF (only bare copper to bare copper contacts).
My old nanovoltmeter will soon start its voyage to the bay.
« Last Edit: February 08, 2021, 02:07:52 am by Kosmic »
The following users thanked this post: PA0PBZ, xrunner, BU508A, med6753, mnementh, Specmaster, Mortymore, ch_scr
Online Kosmic
« Reply #81871 on: February 08, 2021, 02:21:52 am »
I shall look out for a quiet one!  :-DD
Hp was selling a conversion kit at some point. My guess is that it was simply some wires and a aluminum plate that fit the hole in the back.
Kosmic,
Do you have more information about this change?
What exactly was the purpose - intention?
Regards, Frans
I don't know the reason. Probably to lower production cost and eliminate failure points.
Some pictures of my 3456a with the fan:
The fan main purpose of the fan is to cool down the digital section of the meter (the analog section is isolated). And on that section the only thing that can generate heat is the big transistor mounted on a tick bracket connected to the aluminum chassis. The transfo can probably produce a little bit of heat but that's generally not a problem.
I think they inherited that design from the 3455a and then realized they could drop the fan by moving the heat source outside the enclosure. It's mostly speculation from my part but I think it's plausible.
« Last Edit: February 08, 2021, 02:33:48 am by Kosmic »
The following users thanked this post: med6753, mnementh, FransW
« Reply #81872 on: February 08, 2021, 05:38:19 am »
NE1 got a service manual  :palm: Fluke 105B Scopemeter. I do have the User manual.
Most soft switches seem to work as the relays click in and out. Main rail to the LCD is -29.3 against a labelled -30 so should be close and not the cause. +5V rail seems fine too. That little board was sitting partially off like that too when I took the shield off and the rear case is trashed (10-12 bits) so it has had a significant thump at some stage. Local DOD sticker shows it as being in the Leopard Fleet so wonder if there was a Tank involved  :o
The only service manual I could find that is remotely close is the older PM 93-97 Philips branded range which is still a similar layout and topography but a very different series of Chips and display so not a lot of use. https://www.cl.cam.ac.uk/manuals/pm93_95_97_fluke_93_95_97.pdf
More playing tomorrow.....
Edit - Tried the Software and it won't install in compatibility mode as it looks for the actual OS when the installer runs  :palm:
« Last Edit: February 08, 2021, 05:44:32 am by beanflying »
« Reply #81873 on: February 08, 2021, 06:07:11 am »
Time to break out the Flir bean ?
« Reply #81874 on: February 08, 2021, 06:09:27 am »
Still on my wish list  >:D
