FPGA card running stable for 28 hours straight now under full load ...
(yes, mining Ethereum, I did not have any other readily available bitstream).
But that means it works.
Just a couple of parameters:
Clock 505 MHz, chip temp about 50 C, HBM about 61C VCCINT at 0.9V and about 50 - 60 A, total power consumption 110W.
Hashrate about the same as a 3060TI which is clocking somewhat higher (1700 MHz).
as I said: have received the board files and will start setting up vivado for that.
Have ordered one of the unobtaineum RTX3070 and will look at the CUDA stuff later on.
Next steps: start working with my Zedboard Dev system and get pynq to work.
Then check if I can do some image recognition with that board ...
