New EEV DMM BM786 arrived today 😁
It is a bit bigger than the GW121, has a similar feel, the only slight oddity is that the batteries (3xAAA) load into a small plastic carrier, which then slides into the DMM. See photos below, carrier has been rotated 90 degrees away from its insert position so you can see the batteries.
Comes with the nice pliable Brymen silicon leads, and the auto ranging is quite quick as is the buzzer function.
In a couple of days I will try and make/post video about it, but there is only so much that you can say about a DMM!
