Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16913231 times)
factory, Vgkid, Vince and 101 Guests are viewing this topic.
Offline Saskia
« Reply #79350 on: January 11, 2021, 07:31:47 pm »
@Zucca I just found an LTE router (Zyxel) here. Want it ?
Offline tautech
« Reply #79351 on: January 11, 2021, 07:36:23 pm »
Saskia
Got a NIB ASUS B85M-G mainboard here DOA.
Any tips to make it go ?
PM as/if required.
TIA
Offline Zucca
  • EE meid in Itali
« Reply #79352 on: January 11, 2021, 07:40:20 pm »
Funny enough I am running a Zysel vmg1312-B30A, but no thanks.
In my next home I will not have any problems I hope.
Offline Zucca
  • EE meid in Itali
« Reply #79353 on: January 11, 2021, 07:42:44 pm »
Offline Saskia
« Reply #79354 on: January 11, 2021, 07:43:58 pm »
do you have a POST card that you can shove into that thing ?
https://www.ebay.de/itm/TL611-Pro-PCI-E-LPC-Motherboard-Diagnostic-Test-Analyzer-Post-Test-Debug-Cards/164324895237?hash=item264286ea05:g:FhQAAOSwhHVfLEfB
remove battery. reset cmos. put in known good ram. check if any pins in the socket are bent. Are U using the correct CPU ? (socket 1150, may be obvious, but you never know)
check voltages on the various rails, 5V, 12V, 3.3V, 1.5 V for the RAM
if those are correct: you may need a mobo diag card. (see above, look for TL611 or similar). You may also want to have a table of the post codes.
Offline Zucca
  • EE meid in Itali
« Reply #79355 on: January 11, 2021, 07:50:09 pm »
Here we go Sakia
should I press the buy button or you have any other better suggestions?
PS: I am so TEA wasted.
« Last Edit: January 11, 2021, 07:52:42 pm by Zucca »
Offline Zucca
  • EE meid in Itali
« Reply #79356 on: January 11, 2021, 07:54:15 pm »
I think I belong here.
Welcome, we all know where is the entrance.
Yet nobody has found an exit from this place.
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #79357 on: January 11, 2021, 08:01:49 pm »
Quite funny you decided to show up now. Just dusted of a stack of Datron and watching some of your content right now ;)
LOL, I purchased my Solartron 7075 from you last year... noticed that when I checked out your eBay store :-)
Cheers Scott
Offline tautech
« Reply #79358 on: January 11, 2021, 08:06:23 pm »
Thanks for the pointers.
Back story:
Was bought for a new build and I fitted it into a mini tower box with 16G of new RAM and i3-4170 1150 CPU and given to my PC tech mate to install all the nice FREE SW he has  ;) and configure it all as my main W10 box.
120 GB SSD plus a 1 TB spinner onboard graphics etc  :blah: nothing fancy.
When he got the bloody thing it never fired up and fearing that I might need it in a hurry we bought another MB ....not as good but it got it going. Couldn't get another B85M-G at the time and as I'd never booted it don't know if it was DOA or I'd zapped it with static during the build.  :-//  >:(
Done a few builds before and never had problems so grrrrr !
So MB sat on the shelf back in its static bag and in OEM box for a couple of years and now I see you recovering MB's I thought I'd ask for any tips.
« Reply #79359 on: January 11, 2021, 08:07:17 pm »
"What's that Skip? You've seen some old test equipment in the back of a barn?"
You left the important part off, "Of you go Skippy and I'll follow"  >:D
Oh, I did didn't I?
« Reply #79360 on: January 11, 2021, 08:11:48 pm »
« Reply #79361 on: January 11, 2021, 08:26:33 pm »
Speaking of German muppets, my building management team is also contaminated:
and yes they deserve some measurements... 65.2C hot water temperature at the third floor?  :bullshit:
Not sure, what the problem is, in my  bathroom I'm having 64.0°C
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #79362 on: January 11, 2021, 08:41:05 pm »
I know ;)
I assume it arrived well? I tend to have my butcheeks clenched when I send stuff that far away...
Accidently, I have a number of GPIB modules for them. I removed them from most units because they caused issues, so I assume they're bad but if you want one you can have one for the cost of shipping.
The following users thanked this post: TheDefpom
Offline Zucca
  • EE meid in Itali
« Reply #79363 on: January 11, 2021, 08:46:41 pm »
The problem I always burn my hands when I turn on the hot water. It's annoying.
I'll be danmed, I never lived in my past  40 years of life in a home where the water was so hot.
Normally I perfer about 50C.
Offline Saskia
« Reply #79364 on: January 11, 2021, 09:08:02 pm »
@Zucca it is meant to be >60 to kill off any germs (legionellas)
This was the card I was referring to. I am using it to check if the voltages are there. In modern mainboards it will not necessarily display the POST codes though.
@Tautech an old Haswell board may not be worth the effort. I'd throw out the battery and reset the cmos as it most likely got corrupted. You may want to check the mosfets for any shorts though, those are a common cause for failures.
The following users thanked this post: tautech, Zucca, mnementh
« Reply #79365 on: January 11, 2021, 09:14:46 pm »
I'll be damned, I never lived in my past  40 years of life in a home where the water was so hot.
Normally I prefer about 50C.
What Saskia wrote. (below what I'm quoting) You should be grateful that your landlord does their part on purging legionella. Our geothermal pump makes extra hot water once a week to solve the same problem.
Online factory
« Reply #79366 on: January 11, 2021, 10:09:31 pm »
Well done... some excellent electron-tracking detective work there. Nice to see all that ionized gas ionizing as intended, instead of however-the-eff it felt like. ;)
 :clap:
Well the 5325B crystal oven heater resistance is lower than what the manual states (60Ω to 80Ω, I suspect it may have shorted turns.
And it gets better, I don't know why I missed this in the 5325A, a previous owner had toasted the inputs and then guessed the value of the 100kΩ resistors, than toasted them some more.  >:D
« Last Edit: January 11, 2021, 10:12:11 pm by factory »
The following users thanked this post: med6753, mnementh, Specmaster, bd139, Kosmic
« Reply #79367 on: January 11, 2021, 10:50:54 pm »
factory: I must admit I'm enjoying watching your HP porn rather than owning it and arguing with it myself  :-DD
The following users thanked this post: med6753, mnementh, factory, syau, AVGresponding
Offline vk6zgo
« Reply #79368 on: January 11, 2021, 10:56:54 pm »
Roadtrip @Med @Nixiefreq others? eBay auction: #293945475353 Only a few miles and some snow likely to be in the way  >:D Some other goodies from the same seller too....
Also a stash of HP feet  :-+ eBay auction: #363037725383p
That Scope-mobile fills me with "Teklust"!
Another strange thing came to me---------how come that I used to continually find many more of those feet in the "odds-n-sods" box than could be justified by the number of  rack mounted things from HP in each site? (If they were used on a bench, they would still need them).
Also, why didn't I nick them, while I had the chance?
They probably ended up in the dumpster! :-\
Offline Brumby
« Reply #79369 on: January 11, 2021, 11:17:43 pm »
You were a muppet.
*Sad face*
« Reply #79370 on: January 11, 2021, 11:25:19 pm »
Well that's the thing about what you see in porn, it looks exciting but if you try it yourself you sprain something, bruise something else, dislocate another part and end up exhausted, disappointed and covered in goop.
Offline Brumby
« Reply #79371 on: January 11, 2021, 11:30:19 pm »
Next time, keep the cover on to contain the Rifa shrapnel.
« Reply #79372 on: January 11, 2021, 11:39:53 pm »
 :clap:
Gee...and I thought I had problems with Gorillas running loose in Tek scopes. hp Gorillas take the cake.  :o :-DD
Offline Brumby
« Reply #79373 on: January 12, 2021, 12:36:47 am »
....... I got a´n Nvidia Quadro 4000 for 30 bucks ... Should be fairly usable for some CAD at home with its 16GB of memory.
Now I'm truly green with envy.
« Reply #79374 on: January 12, 2021, 12:41:45 am »
OK .... I've done it.  NanoVNA and TinySA ordered, together with a test/demo board kit.
Now waiting on that slow boat........
(I'd blame Bean and Mnem for inciting this action on my part - but they'd both probably wear that badge with pride.)
The Tiny SA looks good but my old Eyes would like a larger screen  ;)
