An update on the repair of the battered Racal 9839 UHF frequency meter, all the IC's are OK, but it turned out six of the number tubes were faulty, most of those required more than 250V on the Megger to get a faint glow, one required more than 500V, a few of the leads have some rust where they meet the glass seal, making me think the neon inside is contaminated with air.
Luckily I had purchased a few spare five digit boards years ago, when they were still reasonably priced, I re-tested those boards yesterday using the connector I had made up, one of those tubes was also faulty.
Six of the good tubes were de-soldered & fitted to the 9839 board, as well as the missing IC's, I removed the IC sockets & repaired the damaged traces at the same time.
After cleaning the board & refitting it, the counter is now fully working on the 40MHz to 560MHz range. And mostly working on the 10Hz to 60MHz range, but the sensitivity seems poor, I'll clean the connectors & pot tomorrow to see if it can be improved or if there is a fault.
The highest the Racal will count is around 574MHz.
