Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17529604 times)
70bytes, Vince and 100 Guests are viewing this topic.
« Reply #77175 on: December 11, 2020, 07:38:55 pm »
The covers have been cleaned. Internal all it needed was dusting out with a brush. We now have trigger. The wire that was broken was the internal vertical amplifier trigger pulse. Explains why no trigger.
Lots of dirty pots/switches to be dealt with. Preparing a BOM for re-cap but I won't do that until next month.
Going to let it cook for a while. I thought I heard 2 snaps like the HV is arcing over so I need to keep an eye out for that.
Loving that blue-green trace. Reminds me of Oculus 585.  ;D
The following users thanked this post: xrunner, Zucca, Cubdriver, mnementh, Specmaster, wolfy007, Kosmic, syau, 0culus, BILLPOD
Offline Mr. Scram
  • Display aficionado
« Reply #77176 on: December 11, 2020, 07:39:07 pm »
No limit but you have to prove that you aquired them before 2018. You need 3 because you can't claim less then £30. If you did buy a lot and tried to get a payment for them and they found out it would be fraud as well as a weapons offence.
Hence the naughty list I mentioned. No guts, no glory!  ;D
« Reply #77177 on: December 11, 2020, 09:25:03 pm »
Nice one, med.  :-+
In this case I'd recommend an ear.   :-DD
« Reply #77178 on: December 11, 2020, 10:06:42 pm »
Mouser arrived. A modern 8,2 µF capacitor is very small compared to the prehistoric one in the 410b, which I of course coulda seen from the various recap subthreads in here, just under the blue paint.  I'm going to start with the new wiring loom, though.
« Reply #77179 on: December 11, 2020, 10:36:52 pm »
Looking good with the 503. Watching with interest.
Finished GTA V and Watchdogs Legion this evening. Bucket list slowly reducing  :scared:
« Reply #77180 on: December 11, 2020, 10:56:38 pm »
It's been on for a few hours now and no additional issues observed. Other than possibly 2 snaps shortly after power up which might have been the HV arcing over there haven't been any more weird noises. The roll off in the vertical noted earlier is actually the calibrator waveform itself. I applied my test square waves and they are perfect.
 For now it's going to just cook and see if anything pops up. No calibration or compensation will be done until after re-cap is completed next month.
Edit....and the only place the cabinet gets warm is directly over the 6DQ6A Beam Power Tube. The rest stays cool. So I can see why no fan was installed.
« Last Edit: December 11, 2020, 11:00:10 pm by med6753 »
« Reply #77181 on: December 11, 2020, 11:02:00 pm »
If the 6DQ6A is being used as a switch, hard on or fully off, it should not get too hot. Needs to have a big enough cathode to provide all those electrons so still needs to be a power tube.
« Reply #77182 on: December 11, 2020, 11:17:53 pm »
I don't think it's switching on and off like a true SMS supply. The 30kHz oscillator feeding it is a sine wave so it's on all the time basically functioning like a Class A amplifier. Therefore, she gonna get warm. But the tube is built for it. It has a plate dissipation rating of 15 watts.
« Reply #77183 on: December 11, 2020, 11:50:38 pm »
Toughen up play GTA Online and avoid the modding skum next  >:D Or Red Dead is on special this week  :-DD
« Reply #77184 on: December 12, 2020, 12:11:18 am »
I just go on killing sprees in GTA online and end up getting headshot until I leave the server  :-DD
« Reply #77185 on: December 12, 2020, 12:48:01 am »
The intense concentration required to be gamer for some reason overloads my pea brain and gives me a headache. Even the original 1st generation pong.  :-DD
« Reply #77186 on: December 12, 2020, 12:59:02 am »
The Type 503 has differential inputs so 5kHz triangle wave on the left input, 5kHz sine wave on the right. That strange resultant waveform again. The weird math that I forgot what you guys called it.
Tomorrow all the switches and pots get a good cleaning.
« Reply #77187 on: December 12, 2020, 01:00:26 am »
MWMWMW mode !  :P
Offline wolfy007
« Reply #77188 on: December 12, 2020, 02:27:34 am »
Man that 503 looks sweet!
« Reply #77189 on: December 12, 2020, 02:31:57 am »
Wait... what...? I thought that was what the game was all aboot...?  :-DD
Oh, and plowing cars you'll never be able to afford into other cars you'll never be able to afford... >:D
« Reply #77190 on: December 12, 2020, 02:37:11 am »
Found this in my inbox; sorry there's so little time left, but some nice prices on Zalman cases for another couple hours... for those who can get to a Fry's.
https://www.frys.com/email/201211_471142/promocode/8407744#9994946
Promo Code is 8407744 in case it doesn't show up in your browser.
 :popcorn:
« Reply #77191 on: December 12, 2020, 04:24:13 am »
Okay... for those who actually live the iLife... is there some unbelievably simple, should be obvious even to a lobotomized prizefighter, "Why are you even bothering...?"
 solution to put a shortcut icon on the desktop of your iPud/iPwn to a specific folder on iCloud?
Because the solution I found using the Shortcuts widget is infuriatingly recursive and completely non-intuitive. |O
*toddles off to ded, dreams of family videos dancing on my head*
« Last Edit: December 12, 2020, 12:49:27 pm by mnementh »
Offline 0culus
« Reply #77192 on: December 12, 2020, 08:17:57 am »
Okay... for those who actually live the iLife... is there some unbelievably simple, should be obvious to a lobotomized prizefighter, "Why are you even bothering...?"
Closest I know is to add it as a “favorite” in the files app. Long press on the folder icon to get the context menu.
Also I will not be around discord later on as I have other plans.
« Reply #77193 on: December 12, 2020, 09:28:23 am »
X-Y problem. This is the Y bit i.e. the proposed solution. What’s the X bit, the problem you are trying to solve?
« Reply #77194 on: December 12, 2020, 10:18:15 am »
Solutions looking for problems? Sounds like typical government.  ::)
« Reply #77195 on: December 12, 2020, 10:59:34 am »
It's all those ancestors fuelled only by spuds and Poitín, it leads to a state of mind where the words 'tomorrow' and 'mañana' take on a sense of burning urgency.  :)
Offline Zucca
  • EE meid in Itali
« Reply #77196 on: December 12, 2020, 11:35:32 am »
From my dad's lab in Italy.
Old stuff, crusty!
Do you smell that too? ahhh old electrons....
The following users thanked this post: bd139, Ero-Shan, tonyalbus
Offline Saskia
« Reply #77197 on: December 12, 2020, 11:38:22 am »
Ok, trying to sell my 2 last PCs ...
quoted on ebay classified:
ryzen 5 3600x, 64GB ram, 512GB SSD, Asus X570, 850W Corsair PSU, Zotac RTX2070 =>1200€
Question: last price ? ....
Question: price ok, will you ship to Scotland
-> umm nope.
scam ? most likely.
What do you think ?
« Reply #77198 on: December 12, 2020, 11:49:54 am »
Possible. Also too far for me to go and kick him in for you if it is  :-DD
« Reply #77199 on: December 12, 2020, 11:50:34 am »
Old stuff, crusty!
That is a bit crispy and in a bad way! Looks like it is a nice instrument though.
