Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17558888 times)
AVGresponding, factory, Robert763, wkb and 39 Guests are viewing this topic.
Online BU508A
« Reply #76225 on: November 27, 2020, 08:59:33 pm »
7603N PSU re-cap, round 2. New set of tools ready to do battle.
What happened about the desoldering station you've asked for some weeks ago? :-//
Honestly, it makes me shivering seeing this soldering gun next to some electronics and pcbs.   :scared:
Online bd139
« Reply #76226 on: November 27, 2020, 09:02:35 pm »
That’s the same iron in saw someone at the local radio club desoldering LPF toroids with. Properly fucked up the board.
BUT it depends on the user not the iron.
« Reply #76227 on: November 27, 2020, 09:05:34 pm »
Even the el-cheapo Chinesium ones are such magic it is simply insane to forego the force multiplier they are.
Offline Saskia
« Reply #76228 on: November 27, 2020, 09:11:52 pm »
Well that was flipping quick (pun intended)  :-DD
30 minutes after initial offer for 130. Now you can get better stuff for similar money, but I am not complaining
Online factory
« Reply #76229 on: November 27, 2020, 09:38:30 pm »
Finally getting somewhere with the HP 5248M, bit tired tonight but will explain more tomorrow.  :-+
The following users thanked this post: xrunner, Cubdriver, BU508A, med6753, mnementh, Kosmic, AVGresponding, tonyalbus
Online bd139
« Reply #76230 on: November 27, 2020, 10:48:39 pm »
Ok completely off topic rant. Star Trek Discovery is a rancid sack of shit, dragging out personal relations and emotions into a bunch of poorly thrown together special effects with no story pitch or technical goodness at all. Everyone is sick and broken either physically or mentally and the acting is worse than the extras on the worst episodes of TOS. Rather than waste my time on such excrement I'm going to punch myself in the balls for 45 minutes as a far more productive waste of my time.
On topic, finally used some test gear today. The Fluke 25. To test a PC CMOS battery. I'm not doing well on the TEA front recently unfortunately. I managed to miss two auctions in a row as well. Bah humbug  >:(. One day...
The following users thanked this post: BU508A, mnementh, Specmaster, FransW, tonyalbus
« Reply #76231 on: November 27, 2020, 10:59:12 pm »
Yeah; it's kindof like they tried to Anime-ify the ST:TOS movies and condense them all down into single-episode doses. I mean... I'm adept at "suspending disbelief"; especially for the sake of Star Trek. This show strained even my capacity to set aside common sense. |O
I mean seriously... riding the interstellar network of mushrooms with a giant deep-space Tardigrade as your navigator...? Seriously...?!?
« Reply #76232 on: November 27, 2020, 11:06:12 pm »
1000x this. I would not be afraid to use that gun in that scenario myself; I know that I am the temperature regulator on these and they have a Hi/Lo trigger to help with that.
But only in this kind of situation; where you have massive heat-sink copper fill and you're trying to desolder half a ton of lead from half a ton of copper and/or aluminum tabs. I'd waste lots of solder and lots of flux making sure the tip was over-tinned just right and I could get in & out quick, and I'd have my big Mandingo 25mm bore solder-suckers... both of 'em... primed before I apply the heat.
But that's just how I'd dewitt. :-//
No dragon flame allowed. NO!!!
« Reply #76233 on: November 27, 2020, 11:38:42 pm »
I didn't get around to ordering one so I went with the brute force method.
An update, all the caps are removed. The board survived. Just some minor scuffing upper left from the dremel. So everyone can calm down.  :-DD
Tomorrow install new caps.
« Last Edit: November 27, 2020, 11:58:14 pm by med6753 »
The following users thanked this post: BU508A, mnementh, bd139, tonyalbus
« Reply #76234 on: November 27, 2020, 11:47:19 pm »
 :phew:
Nothing else to add.  :-X
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #76235 on: November 28, 2020, 12:02:16 am »
Now those are parts for real men - real men fixing real machines!  :box:
« Reply #76236 on: November 28, 2020, 12:05:43 am »
The Weller had just to right amount of heat to deal with heat sinking from those caps. And there's no heat damage or lifted board pads. I performed continuity checks especially on the plated thru holes and they are all good. So I should have no issues once the re-cap is done.
I know...famous last words.  ;D
« Reply #76237 on: November 28, 2020, 12:20:15 am »
Real men would have real soldering irons !  :P  :-DD
The following users thanked this post: xrunner, Specmaster, Neomys Sapiens
Offline nixiefreqq
« Reply #76238 on: November 28, 2020, 01:27:10 am »
like my old mans' iron.
takes about 20 minutes to warm up......but lots and lots of thermal mass.
edit 200 watts.
« Last Edit: November 28, 2020, 01:34:37 am by nixiefreqq »
free range primate
« Reply #76239 on: November 28, 2020, 02:03:06 am »
I love you man... but that is EXACTLY the result I feared when you first said "hacksaw".
Before you go to solder in the new ones, I suggest you get your rosin ready, and that you loosen then retighten the nuts at the bottom of the tip on that gun. Will make all the difference in the world in how it works.
Good luck my friend,
*crosses toes, tail, wings and claws*
« Reply #76240 on: November 28, 2020, 02:17:45 am »
The scuffing of the board is minor and in no way will affect anything.
I'm not using the Weller to solder in the new caps. It's back to the Hakko.
« Reply #76241 on: November 28, 2020, 10:52:33 am »
And continuing this morning......
Building up the capacitor adapters then installing the replacement capacitors to the adapter. A total of 7 need to be done. Then install on the PSU board.
The following users thanked this post: mnementh, Specmaster, Kosmic, tonyalbus
Online bd139
« Reply #76242 on: November 28, 2020, 10:53:38 am »
That board is going to look very sparse afterwards.
Online Brumby
« Reply #76243 on: November 28, 2020, 10:58:45 am »
Improving the ventilation is always a good thing.   :D
The following users thanked this post: Specmaster, wolfy007, FransW
« Reply #76244 on: November 28, 2020, 10:58:58 am »
Yep, the replacement caps are about 1/3 the size of the originals.
« Reply #76245 on: November 28, 2020, 11:00:57 am »
Some versions of the 7603 have a fan and other versions don't. This military version does not.
Online bd139
« Reply #76246 on: November 28, 2020, 11:04:36 am »
More room for the fluff to escape when they’re cooked in a few years  :-DD
« Reply #76247 on: November 28, 2020, 11:11:11 am »
True.  :-DD I think the deciding factor regarding fan/no fan was if the readout board option was installed.
Online bd139
« Reply #76248 on: November 28, 2020, 11:14:15 am »
That’s quite ironic in the way as the readout chips get quite toasty from my understanding. Hmm.
« Reply #76249 on: November 28, 2020, 11:44:49 am »
With nothing TEA to buy lately I've been forced to resort to near-TEA acquisitions. One shiny new metal arse tool cabinet.
I had to giggle when it came to fixing the castors on. These are the supplied M8 machine screws:
Do they really think that four castors attached to a thin bit of sheet metal requires 16 x 8.8 grade bolts, or are these the special chinesium version that has 8.8% of the strength of a normal ungraded machine screw? A quick look-up says that 16 grade 8.8 M8 machine screws have a combined guaranteed load of 337.6 kN (that's 34.4 tonnes or 75,895 lbf, or just under 7 male Indian elephants, or a bit over 4 1/2 London buses). Hmm, bit of overkill, slightly; only by a smidgeon though.
« Last Edit: November 28, 2020, 11:49:54 am by Cerebus »
