got a new phone today and was busy transferring the config from my old one when the Pixel XL battery decided it had had it and called it seppuku time. Tried to configure the new phone (pixel 2 xl) when vodafone decided to kill my fritzbox (ppoe timeout, power cycle did not revive it. Reset to factory defaults did ...
cost me 2 hours of my life.
Not happy.
You and me both. This weekend I was wiring in some more circuits in the machine room, feeding the water cooling fans, solenoids and pumps more permanently, and also adding a branch to my 1:1 mains isolation transformer. I managed to discover that
- My UPS batteries need swapping. They die if the double-PSU computers, routers and switches lose their bypass feed (All dual-PSU machines have one PSU on UPS and one direct) and the UPS can't keep up. It also does not help that I've got too many machines running since I'm trying to migrate to a 10G switch and also remove the old router by configuring the new switch to route as well, together with a very drawn-out process to replace my colo machine with a new one.
- The damn RCCB test switch has a hair trigger! Second outage was killing all power by accidentally pushing the test button while working in the live fuse box.
The first outage did not reboot the present router, but I believe that the fiber CPE glitched enough to wedge the DHCP assignments and I had no outside IP address for some time. And consequently no tunnels (through which I get my real addresses routed) could go up.
The second outage unglitched it all, so it can best be described as mixed blessing. Then perhaps from all mangling with on/off switching et c, the solenoid valve in the water cooler stuck closed, so no circulation was possible. This might have damaged the circulation pump. I'll find out in spring. For now, I'm draining the system, which I'd planned to do anyway, to fit an expansion vessel and replace the pure water with water/alcohol mix to stop freezing if I have a circulation stopping outage. Also, when I've drained that, I can and should drain the pool to winter levels to prevent valves and filter from freezing, which can be expensive.
