Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17746379 times)
0 Members and 71 Guests are viewing this topic.
« Reply #75975 on: November 24, 2020, 02:08:48 pm »
I’ve actually got two at the moment and I can’t do either of them  :-DD  I’m mostly working on “administrative shit” at the moment  >:(
In the decent companies I've worked in, the decent middle managers have been adept at umbrella management deflecting seagull managers.   I've always thought that to be a joyless way od spending your life :)
So what... they've changed the species of bird now? We used to call them the MPs; because they never come out of their pigeonholes except to sqwawk and flap aboot and shit all over everything...
What goes around, comes around again... and again... and again...
« Reply #75976 on: November 24, 2020, 02:16:45 pm »
I assume "MP's" are Magpies?  :-//
Offline McBryce
« Reply #75977 on: November 24, 2020, 02:19:13 pm »
Here you go bd, a cheap fixer-upper for you, with low possibility of schematics!   :-DD
[<SNIP>
Not sure what this is, but I feel it's a Saskia type item:
https://www.ebay.co.uk/itm/Inferred-Heater-Unknown-Item-R4/224246270092
Not sure why it's inferred that it's a heater, but looks interesting.
I'm 99% sure it an infrared illuminator for CCTV. One filter missing. Inferred may be miss-spelling or autocorrect for infrared.
One filter missing. It's not worth £40 never mind £400 now LED ones are available.
I'll confirm and remove your 1% of doubt. It's something like this with the outer case missing: https://www.euport.nl/index.php/accessoires/ir-schijnwerpers/infrarood-schijnwerper-120-graden-940nm-525.html
Half the buildings in an industrial estate will have these around the building for night vision CCTV. Definitely not worth anything close to the asking price.
McBryce.
Offline factory
« Reply #75978 on: November 24, 2020, 02:23:01 pm »
Well that was the easy bit with the HP 5248M, one dead 1853-0001 transistor (Q3) on the A25 oscillator power supply board replaced, luckily I had a used spare from something else. Output now back to +20V with a load test and I reconnected/refitted it to the counter.
Apparently 1853-0001 is a selected 2N1132 (according to the 5065A manual) and 1854-0003 on the same board is a selected 2N1711, if that helps anyone else who needs to replace those.
Still lots more problems to find & fix with this counter, at least it now has a 5MHz & 10MHz output on the back from the 00105 series crystal oven, none of the other selections or the separate 100MHz output are working.
The main input board & six out of the eight display boards are working properly, but it currently only counts in manual count mode with the gate active all the time.
« Last Edit: November 24, 2020, 02:36:18 pm by factory »
The following users thanked this post: Vgkid, Cubdriver, BU508A, med6753, mnementh, bd139, Kosmic
« Reply #75979 on: November 24, 2020, 02:28:44 pm »
Dammit, David... why didja have to go bringing something on-topic into our Tuesday Morning Bitchfest...? :-DD
Management Pigeons. Sorry; thought that was obvious from context.  :-[
Vengeance is Mine, INC... >:D
« Last Edit: November 24, 2020, 02:32:58 pm by mnementh »
Offline factory
« Reply #75980 on: November 24, 2020, 02:38:01 pm »
Sorry Mnem, I was going to post most of that last night but got too tired.  :=\
« Reply #75981 on: November 24, 2020, 02:38:21 pm »
In case you run out of NOS 2N1132 and 2N1711 both are replaceable by NTE128 although may need some tweaking. And it's available via Amazon, at least here in the U.S.
Online tggzzz
« Reply #75982 on: November 24, 2020, 02:47:33 pm »
I assumed "Members of Parliament", since that isn't inappropriate.
Offline factory
« Reply #75983 on: November 24, 2020, 02:51:27 pm »
I haven't got any NOS HP transistors, only used spares.
The TVT book I have gives BC160, 2N2905 or 2SA537 as equivalent types for the 2N1132, I have some new of the first two. And BFY46, BFY68, BSY54 or BSY71 as equivalent types for the 2N1711, haven't got any of those.
Interesting that NTE can replace both the 2N1132 and 2N1711 with one type, which can't be right as one is NPN & the other PNP.
« Last Edit: November 24, 2020, 02:56:25 pm by factory »
« Reply #75984 on: November 24, 2020, 02:54:21 pm »
One of the better points about HP was that if I had been promoted six times I would have been CEO. The reasons the intervening levels were there were obvious and sensible.
ISTR that IBM had 14 layers.
The only management book that is worth the paper is "Up The Organisation"
If I'm promoted four times I'm Director General. That will never, ever happen, mostly because I don't want to, but also because I'm no journalist, and it's only those who get that seat.
The levels above me are more or less removed from reality. As they often are. I am, however, on speaking terms with all of them except the DG; mostly because I haven't had reason to.
Much of the present company is organised along the lines of Qui audet adipiscitur; which means that they who get shit done are rewarded. If your job is to provide a service upon which shit gets done this can be a bit of a challenge, what with the demands of predictability conflicting with the desires of ambitious people..
« Reply #75985 on: November 24, 2020, 02:58:00 pm »
I think the term originally derived from this Org Chart; some variant of which has been making the rounds for probably close to a century. :palm:
The following users thanked this post: BU508A, Specmaster, Neomys Sapiens, bd139, factory
« Reply #75986 on: November 24, 2020, 03:07:47 pm »
Much of the present company is organised along the lines of Qui audet adipiscitur; which means that they who get shit done are rewarded. If your job is to provide a service upon which shit gets done this can be a bit of a challenge, what with the demands of predictability conflicting with the desires of ambitious people...
Whatever the development scenario, one or both of these covers it.  :-DD
 :-/O
« Reply #75987 on: November 24, 2020, 03:15:17 pm »
A lot of such FUBARs since NTE took over the ECG catalog; I'd guess transcription errors by wage-slave data-entry types with absolutely zero knowledge of transistor parameters vs the way ECG documented MCPs in the catalog.  :-//
« Last Edit: November 24, 2020, 03:25:46 pm by mnementh »
« Reply #75988 on: November 24, 2020, 03:16:46 pm »
[<SNIP>
McBryce.
His stuff is never worth the asking price, though I was hoping it was along the lines of an IR target illuminator rather than a more mundane CCTV light source.
As to the inferred pun, looks like I need to telegraph my humour a bit more. Anyone have a good morse key?
« Reply #75989 on: November 24, 2020, 03:23:22 pm »
Sorry... not enuf complete illiterates in here for that to work; you'll have to paint us a picture.  :-DD
*agitating-ily*
Offline factory
« Reply #75990 on: November 24, 2020, 03:34:22 pm »
I can't understand why his pricey stuff keeps selling (OK having the international shipping may help), for example that non-working -hp- 3460A sold for somewhere under £300 (we will never know the actual sold price thanks to ePay's deceit  :-- :--).
eBay auction: #324372745454
« Last Edit: November 24, 2020, 03:36:17 pm by factory »
« Reply #75991 on: November 24, 2020, 03:38:30 pm »
Okay... so when did Android remove "Call duration" from "Call Details"...? This has been essential information instantly available on every cellphone since... well... since they were just cellular phones. |O
The more I use Android10, the more it feels like the "we took everything useful out so now you have to install a app for that" ASSHOLE VERSION.  :palm:
« Last Edit: November 24, 2020, 04:07:24 pm by mnementh »
« Reply #75992 on: November 24, 2020, 03:51:15 pm »
Android is the worst for such fuckery. Not that the fuckery ever even worked to start with.
I am STILL bitter from the week of holiday photos that their pile of shit ate with a corrupt SD card. Turned out it had stopped backing the photos up to google photos as well  :palm:. Bought an iPhone after that. Zero problems (apart from I cracked mine the other day - thank fuck for 28 days of applecare left :-DD)
« Reply #75993 on: November 24, 2020, 04:01:41 pm »
All this talk of transitor subsitution makes me think of TITS  :-DD
For non UK members Towers Internatonal Transistor Selector was the UK equivilent to TVT or D.A.T.A books. Never did work out if the acronym was deliberate or not
The following users thanked this post: mnementh, Neomys Sapiens, shakalnokturn
« Reply #75994 on: November 24, 2020, 04:02:31 pm »
Hold your horses and blaming "the man" again. Perhaps little old peon me made a mistake. Let me go check again. Geez....everything is a fucking conspiracy with you.  :palm:
« Reply #75995 on: November 24, 2020, 04:05:49 pm »
<SNIP>
You used to be able to get an idea by selecting sellers other items, sold items, orderd by price. This would oder on sold price so if sell sold a lot you knew it was no less than the item below it in the list. They seem to have "fixed" that feature.
« Reply #75996 on: November 24, 2020, 04:08:42 pm »
I dunno aboot that... from a seller's perspective, it's a good thing and it's none of your damned business if I was desperate enough that one time to accept a crazy lowball offer on some really valuable item. Just invites all the lowballing lowlifes to inundate you with BS offers, half of which have no intent of actually paying anyways; they're the reason I've pretty much completely stopped selling on fuckBay.
You wouldn't expect to get such confidential information from a IRL auction house; why would you expect it from fleaBay...? Oh, right... because in a previous incarnation they did ignorantly publish such privileged information for a while...  :-\
eBay.
« Last Edit: November 24, 2020, 04:11:12 pm by mnementh »
« Reply #75997 on: November 24, 2020, 04:10:39 pm »
Holy shit, can you believe it. It was ME who fucked up. So sorry to blow your conspiracy theory all to hell.  ::)
2N1132   PNP  NTE129
2N1711   NPN  NTE128
Both are available via Amazon USA.
« Reply #75998 on: November 24, 2020, 04:16:19 pm »
Where the FUCK did THAT come from...? Everybody knows NTE's entire catalog structure and cross-reference was lifted from ECG's catalog... this isn't conspiracy, it's fucking history.
When ECG closed up shop, NTE bought out their remaining inventory, and you often got ECG baggies in your NTE orders. Wouldn't be surprised if you still do with oddball low-demand parts they haven't sold out of yet in the intervening decades. :-//
smeesh. :palm:
« Last Edit: November 24, 2020, 04:29:04 pm by mnementh »
« Reply #75999 on: November 24, 2020, 04:18:03 pm »
How to sub transistors like a pro:
2N1132   -> fuck it BD139 will do
2N1711  -> fuck it BD139 will do.
 8)
The following users thanked this post: mnementh, Specmaster, shakalnokturn, factory
