Hi Spara, coming back to your question in our discord TEA channel:
Do you have a reinforced floor?
No, I don't.
I have a wooden floor. It behaves elastic to my TEA stack still.
In fact my bench is made of two benches back-to-back -that spreads the weight over a bigger area.
If it was that you wanted to know.
I've got raised flooring where I store my TE. Got hold of perhaps 20m
2 complete with short feet, I only had to pick it up. Built a new floor in the inner room of my gara^Hworkshop^Hstorage facility that's got tarmac flooring originally, starting with 50mm styrofoam (flooring grade), then vapour blocking foil, and finishing with 22mm flooring grade particleboard. On this I've tacked (Illbruck PL600 construction glue) the feet, and then a lot of work with the spirit level.
Since the tiles have sheet metal cladding below and linoleum on top around a particle board core I had to develop a method to saw them (because no, nothing ever in a raised flooring project is a positive integer multiple of 600mm in every direction).
I came up with a multilayer method:
- Measure twice. (Or is it four times because there must be two cuts? )
- Hand-held circular saw, set to (thickness of tile - 2mm) from above, ie. through linoleum and most of the core.
- Angle grinder with a cutting disc from below.
- Finish off by rounding the sheet metal jagged edges with a grinding disc and/or a file.
I did ask the installers of such floors how they do it; they replied they're heavy users of small but powerful bandsaws which of course was deemed too expensive..
The load bearing is on the order of 500 kilos per tile, IIRC. Up to the floorboards it's only compression load. You should not drive a car on it, even if it probably would be OK.
My rack cabinet was too high to stand on top of the tiles, so I put it directly on the floorboards, and jacked it up (swapped the adjustable feet for longer threaded-rod ones.) so its door clears above raised level. It contains the heavy stuff which is mostly batteries; i've got ~300kgs of batteries for my UPS, and another 130kgs for a 24V bank to drive small automation stuff and my army radios.
