<SNIP>
Apart from the obvious idiocy here, the failure is not electrical. The lack of a load has no effect on the speed of a BLDC, jut the current. A BLDC is not a I don't think overheating or bad commutaion was the cause of the failure either.
The aluminium rotor bell failed under the G force / fatigue. This resulted in los of the magnets. No electrical failure so far. The loss of the magnets significantly reduces the back EMF which is the main thing limiting the current. Current shoots up and windings fail through I2R heaing.
They are lucky a magnet did not hit someone.
No; the fire was caused by a shorted FET(s). That ESC is toast. The cause of the shorted FET was loss of sync caused by loss of commutation feedback; period. It's endemic to the breed; something that happens all the time.
The guy wants to think his motor was running fast enough to grenade from centrifugal force; much more likely is that the magnets came loose and contacted the stator. This doesn't often happen so uniformly; but it does happen that way occasionally. I've done it.
Well, it's not impossible it grenaded from CF. In our quest for ever-lighter motors with ever-higher torque per gram, obviously manufacturers are going to have to shave the weight from somewhere. Preferably in the moving mass, as fast changes in prop RPM are the core principle of how these things can fly and maneuver so aggressively. That means that the CNC aluminum armature and the ferrous gauss concentration rings (magnet rings) are going to be shaved down to
just a hair more than they absolutely need to be in order to not fly apart under normal usage.This guy is deliberately abusing the motor by running it with no load. That is why this video is sheer stupidity.
[/quote]
There is NO evidence that the ESC has failed or there was a shorted FET. At 100V applied and that power level a FET failure would result in obvious damage.The stator fried because the current went up due to loss of back EMF. High end ESCs like th one in use have protection against commutation errors. If you watch the slow motion part of the video you can clearly see the open end of the rotor bell starting to expand just before it lets go. The rotor pole piece has also bell-mouthed due to centrifugal forces.
[/quote]
But what about the 2 bearings? There has to be one at each end of the rotor, and they would be the first item to fail surely?
[/quote]
As I said look at the slow motion video it is clear the failure started with the rotor bell expanding.
Bearing failure wold cause vibration and eventually allow the rotor to touch the stator. in this style of motor the bearngs are much smaller diameter than the rotor bell so centrifugal force is much less. Also as there is no propeller thar is no thrust load which is the major load on the bearing in normal operation.
I've been playing and working with motors for about 50 years. Started playing with brushless DC motors over 20 years ago. That includes ones alot bigger than fitted to quad copters.
The guys in the video were deliberately going for overspeed failure.
