I orderer some Felder soldering tin wire Sn60Pb40 from Bürklin (a Munich distributor) the other day.
Put it in my virtual basket, made the order only without any hassle. But then...
Reaction I got on the invoice (only): Position set to zero, with an information that the manufacturer set a prohibitive note: This soldering tin wire is not available for private buyers any more, only for companies. ![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
Well, I can only look at classic soldering tin wire now in webshops but can't buy it?! !@#?§#!! ![Rant :rant:](https://www.eevblog.com/forum/Smileys/default/rant.gif)
All other parts I ordered were delivered flawlessly as always..
I've ordered this at 30.06.2020 at Bürklin. Got delivered without any problems:
Bestell-Nr. Artikelbezeichnung Menge Einzelpreis inkl. MwSt. Gesamtsumme inkl. MwSt.
11L4370 Lötdraht, 0,5 mm, Sn62Pb36Ag2, 250 g 1 28,56 € 28,56 €
11L4372 Lötdraht, 0,75 mm, Sn62Pb36Ag2, 250 g 1 24,276 € 24,276 €
11L410 Lötdraht, 1 mm, Sn60Pb39Cu1, 500 g 2 21,063 € 42,126 €
86F8918 Ø 4 mm Stecker stapelbar, rot 15 1,5708 € 23,562 €
86F8897 Ø 4 mm Stecker stapelbar, schwarz 15 1,5589 € 23,3835 €
11L395 Lötdraht, 0,5 mm, Sn60Pb39Cu1, 500 g 1 29,155 € 29,155 €
@URI
Let me know if I can help out, e.g. ordering some stuff at Bürklin.
