First off, to all the Canadians here, happy thanksgiving!
When Mnemnth and I met up for coffee the other day and we were chatting about test equipment and all, I was showing pictures of some of the locally built oddities for which there’s either very little or no documentation out there. Back in late June 2017 I found a listing for an HP 523D counter nearby and I was able to get in touch with the gentleman selling it and dropped by on my way to work to pick it up. It was listed for $40 but while I was on my way there, he decided to give it to me along with this Measurement Engineering Ltd. signal generator free of charge since they’d been listed for several months and since nobody had expressed any interest, were going to be put in his town’s ewaste recycling in a few weeks had I not called.
I brought both into work that afternoon since one of the other guys there enjoys vintage stuff like this and we spun up the HP 523D counter and put the columnar displays through their paces with a handheld signal generator since it was demonstrated working when I picked it up, and took the cover off the MEL. There’s a smudged stamp inside that almost implies a 1939 build year and the style of the cabinet tends to agree but then I wonder if it was made post war out of surplus parts because when I researched the company, there were a a couple archival newspaper articles I found online about how much the company liked moving to Arnorior, which is the location given on the front panel, and this was a post war article. The only other thing I could find was a trademark history that shows the Measurement Engineering Ltd. name and logo were bought by Canadian Stackpole who registered it and then renewed it once, then ultimately let it lapse in 1984. We didn’t attempt to power it up because it clearly needs an electrical restoration but one of the guys at work was saying that it’s like some of the equipment he worked on when he was a new employee that was built by defunct companies that have little or no record that they ever existed online. Not everything is on the internet.
Here are some pictures:
Built in Arnprior, Ontario and last calibrated a very, very long time ago by ITT Canada who may, at one time, have had documentation on this machine.
The top deck shows a tube complement that I believe is all pre-war. When I looked up the introduction dates on the tubes used in this machine back in 2017 when it was first given to me, they were all pre-war with one (forgotten which) that scraped in with a 1939 introduction date. So the tube compliment and the style of the case plus the one fuzzy stamp inside the chassis suggests a build date in 1939, but, on the other hand, that doesn't square with the one newspaper article from the early fifties I found that talked about how Measurement Engineering Limited liked moving to Arnprior as if it had just happened. Without any other information that I could find out there, the build date and approximate age are a mystery. But look at that beautiful four gang tuning capacitor and the transformers and choke!
The underside of the chassis. Those heavy porcelain insulators are beautiful as is the looming job on the wiring. Correct me if I'm wrong but I thought the standard Wein bridge oscillator and Hewlett-Packard (and companies that cloned the HP circuit) used a single lightbulb but MEL's circuit uses two of them so it may not be an exact clone.
This signal generator's been sitting on the shelf in my boat anchor collection since I got it but since having coffee with Mnemnth and showing pictures, I've started to get an itch to pull this off the shelf and do an electronic restoration on it to get it running in a couple of weeks once the autumn yard work is out of the way and it starts getting crappier outside. Is there any interest in seeing pictures of the restoration process?
