Arrivals over the past days here.
two Nuvistors from RCA, type 7895 for my R&S UGZ projector voltmeter
and some koaxial cable strippers. But don't tell Neomys Sapiens, he'll pull me at my ears.
Telegärtner BNC 50Ohm pass-through terminator. Good for 0.5W and up to 1GHz.
I've bought two of them.
Some BNC and SMA stuff, 5m of RG316 cable, BNC to SMA adapter cables.
Some more BNC and SMA connectors and adapters, some 50cm BNC RG316 cables
and the two Triax connectors from China!
Referencedetailed view with higher resolution:
I think, the quality of that Triax connector isn't that bad, but I'm not convinced it is as good as one from Pomona or Amphenol.
I cannot lay my finger on something special, that's just my impression.
Unfortunately, I don't have actually any TE to test it. But if you want, I can do some more detailed pictures of the pieces and maybe also some measures with a caliper.
Now I'm having enough cables, connectors and adapters to build some DIY H- and E-field probes, based on this very nice article from Michael M. Unfortunately it is written in German but I think you guys are smart enough to sort this out.
Link to the PDF documentMichael's homepageFor this, I have bought at the UKW-Tage in Weinheim in 2019 some used semi-rigid cables, which are ideally for this job.
Thank you for watching.
