Arrivals over the past days here.
two Nuvistors from RCA, type 7895 for my R&S UGZ projector voltmeter
and some koaxial cable strippers. But don't tell Neomys Sapiens, he'll pull me at my ears.
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
![](https://i.imgur.com/mAjwuX5.jpg)
Telegärtner BNC 50Ohm pass-through terminator. Good for 0.5W and up to 1GHz.
I've bought two of them.
![](https://i.imgur.com/gh0LDdy.jpg)
Some BNC and SMA stuff, 5m of RG316 cable, BNC to SMA adapter cables.
![](https://i.imgur.com/oH3FyLg.jpg)
Some more BNC and SMA connectors and adapters, some 50cm BNC RG316 cables
and the two Triax connectors from China!
Reference![](https://i.imgur.com/tt66kFB.jpg)
detailed view with higher resolution:
![](https://i.imgur.com/6tDPyqY.jpg)
I think, the quality of that Triax connector isn't that bad, but I'm not convinced it is as good as one from Pomona or Amphenol.
I cannot lay my finger on something special, that's just my impression.
Unfortunately, I don't have actually any TE to test it. But if you want, I can do some more detailed pictures of the pieces and maybe also some measures with a caliper.
Now I'm having enough cables, connectors and adapters to build some DIY H- and E-field probes, based on this very nice article from Michael M. Unfortunately it is written in German but I think you guys are smart enough to sort this out.
Link to the PDF documentMichael's homepageFor this, I have bought at the UKW-Tage in Weinheim in 2019 some used semi-rigid cables, which are ideally for this job.
![](https://i.imgur.com/k3W2wBT.jpg)
Thank you for watching.
