RANDOM MODE:
Just stumbled across this at Homeowner Hell while shopping moulding for a bathroom project:
https://www.homedepot.ca/product/alexandria-moulding-metal-flat-bar-mira-lustre-1-8-inch-x-1-inch-x-8-ft-/1000675915
8 feet of 1/8" x 1" clear anodized aluminum bar stock for ~US$12. Simply fabulous...
What is it that makes you remark on it? Aluminium Warehouse here (not the cheapest nor the best metals supplier) has 2.5m lengths of the same for £8.36 (ex VAT, about $14 CAD, $10.80 USD), £10.03 (inc VAT, $17.10 CAD, $12.96 USD). So it's a fair price, but not an especially good one.
Or is it just that it is shiny?
Cheap AND shiny AND readily available (Home Despot is like Tim Horton's up here; one on every other block) AND thick enough to tap a hole into but thin enough to bend in a bench vise AND just the right size for 1000 uses from brackets to spacers to impromptu heat sinks...
But mostly the cheap and readily available part.
Everything is raw material.
Fair enough, just couldn't see why you'd got excited so easily. Now, if they'd dye transferred My Little Ponies into the wet unsealed anodising I'd have quite understood.
I bought a 1m piece of similar anodised stock from B&Q, the UK equivalent of the Homeless Despot, for a ridiculously inflated price when I needed to make some brackets to tie the box room shelving back to the wall (If BD139 has a 'cupboard of doom' I have a 'box room of doom'). Criteria was similar, must be hand/vice bendable. I was a bit unthinking in grabbing it and of course with bending the anodisation cracked horribly. Not enough to be a mechanical problem, it's sat there for 15 years performing quite adequately, but I know it's sitting there hiding behind all the crap taunting me that I should have known better than to use anodised for something I was going to put a bunch of small radius 90º bends in.
(Annoyingly my spelling checker believes that anodised is a word, also anodized, but not anodisation or anodization.)
