Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18058432 times)
supauser and 49 Guests are viewing this topic.
« Reply #69675 on: September 17, 2020, 07:40:00 pm »
Just ordered a tinySA from a drop shipper here. Place your bets: genuine article or clone already?
I want to get one too but got too many other "irons in the fire" at the moment including another project which should be here Monday. Maybe next month.
« Reply #69676 on: September 17, 2020, 07:44:08 pm »
WD-40 is penetrating oil, not lubricating oil.
 :popcorn:
WD-40 = Water Displacement, Formula #40
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #69677 on: September 17, 2020, 07:45:44 pm »
Not sure; it's probably paraffin. What do you use the stuff for?
Just cleaning metal and removing labels in the garage.
WD-40 is penetrating oil, not lubricating oil. Its purpose is to infiltrate rusty bits to help break them free. It is worthless as a lubricant; it evaporates too readily and the residue can actually cause galling in load-bearing surfaces.
Yes yes I know all that ... why do you think I lubricate anything with it. Did I mention I did? No.
I've had the same can of WD-40 since I quit working as a auto mechanic; really, it has no purpose on a technician's bench.  :-//
You are inferring way too much just because of the location I took the picture.  :palm:
But, to summarize - you do not know the answer to my question?  ::)
« Reply #69678 on: September 17, 2020, 07:49:11 pm »
uh oh.  :o :-DD
The following users thanked this post: xrunner, Specmaster, bd139, TorinoFermic
Online xrunner
« Reply #69679 on: September 17, 2020, 07:51:27 pm »
Nothing is a simple question here ...  :-DD
« Reply #69680 on: September 17, 2020, 07:52:30 pm »
I just chickened out on a -- seemingly complete, ie. with probe and all -- TM 503 / AM 503 combo on the local auction site. Looking at the asking prices on the evil bay, I shoulda' kept at it. It went for 150 €.  Oh, drat.
There will be another.
« Reply #69681 on: September 17, 2020, 07:55:20 pm »
Oooh ouch. Did that have current probe or just the amp?
« Reply #69682 on: September 17, 2020, 07:56:22 pm »
menm mostly had it right:
<35% petroleum base oil (non hazardous heavy paraffins)
https://en.wikipedia.org/wiki/WD-40#Formulation
Online xrunner
« Reply #69683 on: September 17, 2020, 07:59:19 pm »
But I wanted to know if the white component can be removed and still have it be useful for certain applications such as for example removing labels or cleaning metal.
« Reply #69684 on: September 17, 2020, 08:07:18 pm »
Gah today got expensive. New shiny TE arriving on Monday  8)
The following users thanked this post: Specmaster, Kosmic, 0culus, tonyalbus
« Reply #69685 on: September 17, 2020, 08:09:12 pm »
Complete. Probe, adapters, little bag, The Fine Manual, and all.
https://www.tradera.com/item/340196/418090376/tektronix-tm-503-am-503-current-probe-amplifier
 :palm:
« Reply #69686 on: September 17, 2020, 08:09:29 pm »
SDG ?
 :popcorn:
« Reply #69687 on: September 17, 2020, 08:12:01 pm »
SDG ?
 :popcorn:
Correct. Only the cheap ass one  :-DD
 :palm:
Oooooh that burns. That was really cheap!
« Reply #69688 on: September 17, 2020, 08:20:39 pm »
It's only cheap because no one else bid. The winner may have had a max bid many times that on it.  I've  put 3 or 4 digit bids on items that I won for a few pounds.
« Reply #69689 on: September 17, 2020, 08:26:21 pm »
SDG ?
 :popcorn:
And why not after all this is the hackers forum.
« Reply #69690 on: September 17, 2020, 08:29:24 pm »
   ppppppppttttpppppbbbbbllllppppppptttt!
Well, whether it needs that layer of monkey-cum depends on exactly what you're using it for, now doesn't it?  ;)
If, as I guess, it is paraffin... then yes, you can probably filter  it out for a) removing labels and 2) cleaning metals. If your intent is to oil the metal to prevent rust as well, probably best to leave the (presupposed for the sake of argument) paraffin in there, as it will lengthen the time it takes for the residue to evaporate.
Just a dab'll dooya!
« Last Edit: September 17, 2020, 08:32:28 pm by mnementh »
« Reply #69691 on: September 17, 2020, 08:32:18 pm »
SDG ?
 :popcorn:
TBH I might not bother. I don't need more than a couple of MHz at the moment.
Assume the approach is something along the lines of telnet in and frig something on the filesystem?
« Reply #69692 on: September 17, 2020, 08:36:48 pm »
Just in case anyone was wondering just what the typesetting block was set to print, here it is all solved for you.
The following users thanked this post: bd139, nixiefreqq
« Reply #69693 on: September 17, 2020, 08:41:26 pm »
I'm not only suffering from GAS, I'm suffering from TAS¹, too.
Source: Qwertee
¹T-Shirt Acquisition Syndrome
Offline ch_scr
« Reply #69694 on: September 17, 2020, 08:41:45 pm »
Got this PT100 temp probe on ebay today. Hopefully it was just a broken wire that made them chop the cord (it's IP67 so the repair will be intresting anyway). Marketing sheet also says food-safe stainless steel and the ablility to be traceably calibrated so I will just pray the element is still good and that I will be able to shoehorn a new cord on.  :-/O
The following users thanked this post: BU508A, AVGresponding
« Reply #69695 on: September 17, 2020, 09:01:27 pm »
In case you didn't know, this is how the ingredients in WD-40 settle in the can (or in a bottle LOL). You do have to shake the can before use (so it sayeth on the can).
The question is: Can I filter out the "white" stuff, or does the "white stuff" make it more betterer that it would be without it?
Thank you in advance.  :)
MSDS formulation for WD-40
50-60%  Naptha (Petroleum), hydrotreated heavy
<25%    Petroleum Base Oils
<10%    Naphtha (petroleum), hydrodesulfurized heavy
        (contains: 1,2,4-Trimethyl benzene, 1,3,5-Trimethyl benzene, Xylene, Mixed Isomers)
Offline Saskia
« Reply #69696 on: September 17, 2020, 09:11:14 pm »
spent about 1 hour on the phone with Quadral, the manufacturer of those vintage speakers (hand built in 1986 ... whoa ...)
Took out the crossover. While the capacitors still look ok, I cannot tell if they indeed are. Furthermore, the values are not at all what Quadral would want them to be.
They quoted: 130 instead of 70, 47 instead of 56, 1 instead of 4.2, 5.2 instead of 4.2 (all uF).
Now would be a great time to take out the LCR meter and just start checking coils, capacitors and resistors and then adapting the crossover to what they expect it to be.
Which is probably what I am going to do.
*sigh*
If the capacitors turn out to have lost their oompf, it would most likely make sense to replace all of them. After 34 years or so I would expect them to  no longer be up to specs.
Offline factory
« Reply #69697 on: September 17, 2020, 09:16:13 pm »
Yes in the Cattle Market. 20 years ago they had all sorts of stuff. Then the MOD changed the disposal process and it all went a bit weird. Heard a rumour that one of the owners/managers whatever got locked up for dodgy dealing. The burn down in the cattle market fire a few years ago.
I remember H Gee's in Mill Rd in the 80s.
I bought a meter there ti use as my Landie's fuel guage. Fun to think of fuel capacity being measured in Roentgens/hour :)
Gee followed Anchors example and burnt down last year. Ony place to buy components in Cambridge now is the Raspberry Pi shop in Grand Arcade.  |O
I only found out about Anchor Supplies a couple of years ago, I did go there about 6 months before the firework related arson that destroyed six business there, which started in Bed City (caught on CCTV).
They did have some test gear, including meters & a Tek TM50x series frame with modules and lots of parts stripped from various things. I left with a late 60's Tek 141 TV test signal generator & some Mil grade D cells for the shed radio.
Online xrunner
« Reply #69698 on: September 17, 2020, 09:24:40 pm »
Thanks. I think I'll go ahead and filter it just to see how it works. All I really need to do is pour it out carefully into another vessel and leave the white substance behind.
I know, I have too much free time on my hands.  :-DD
Offline nixiefreqq
« Reply #69699 on: September 17, 2020, 09:50:14 pm »
wait! wait!
before you decant the clear stuff we would like to see a pic of what it looks like after you shake it.
remember "SHAKEN, NOT STIRRED"
(how long does it take the white stuff to settle to the bottom......minutes?  hours? months?)
edit  well you did say you had time on your hands.  don't mess with us......this is for science.
« Last Edit: September 17, 2020, 09:52:07 pm by nixiefreqq »
free range primate
The following users thanked this post: mnementh, Specmaster, Neomys Sapiens, AVGresponding
