Dear TEA fellows,
today I'd like to introduce the Rohde & Schwarz UGZ BN 1100 voltmeter.
It arrived today and a first checking revealed, that it needs some repair.
Based on the date-codes I've found I assume that this meter was built
in 1962 or 1963. The price for this meter was in 1963 ca. 6500 DM.
I've looked with an
online calculator and got a result for 1965 of today's ca. 13900 EUR.
This thing was bloody expensive back in the days!
And it's heavy! It weighs around 15kg!
But let's start with the pictures.
This is the front:
Sorry, should have removed the steel cover first.
Here are some examples of the display:
on the left one can see the transition between two digits.
on the right it is obvious, that this meter has a problem. Need to order the manual.
I have disassembled a bit the display and this is the backside (left),
on the right there is a plate showing the manufacturer of the displays.
These light bulbs are the light source for projecting the digits to front. Wow!
Now let's have a look to all sides of this meter.
Top, bottom, back, left, right.
That wiring! This must have been a nightmare to assemble! And there is more in it!
Here are some more detailed views.
on the left, eleven PCBs with lots of Ge-transistors on it. The silver ones are AC124 and they are supposed
to be glued on the pcb. But the glue has become old and brittle and isn't able to stick the transistor to the pcb anymore.
I have removed all the pcbs and put some kapton tape on the backside of them.
Next there are some nice Valvo OA31 power diodes. I think they are belonging to the power supply part.
Next there is the fuse holder with the cover removed (on the right, the thing with the knob on top)
Next a huge amount of relays. Under the white plastic cover there are more relays.
Next, this is something for med.
Nice stand-offs.
Most right, some trimpots. I think they are for adjusting the voltage of the power supply
To quote Sepp Herberger (German football trainer) "Elf Freunde müsst ihr sein."
We have here eleven PCBs, the first four of them are identical.
Top - front side
Bottom - back side
Order: 1-4,5,6,7,8,9,10,11 (left to right)
I have also attached an info sheet which I've found for this meter. Sadly, it's in German.
Thank you for watching, I hope, you have enjoyed this teardown of an unusual meter.
Now I have to order the manual and I hope, that I will get all the Ge-semiconductors.
Edit: some typos
Edit 2:
Got this hint from user Tomorokoshi. Thank you!
Fran at Franlab did a video on the IEE Readout display:
https://youtu.be/0TD_MhPpZKg
Edit 3:
Follow up can be found
here.
