Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16760361 times)
mnementh and 64 Guests are viewing this topic.
Online mnementh
« Reply #67825 on: August 26, 2020, 10:29:44 am »
Quote from: mnementh
Well, not quite. I took it apart because I had already sprayed it with 3 different kinds of contact cleaner at least 5 or 6 times and still intermittent contact. Worse yet, I didn’t actually find anything wrong... but it worked perfectly after I scrubbed and sprayed it with food grade silicone spray lube.
It wasn’t until a few days later when I was editing pix I took during the work that I found the one pic right after I’d removed the plunger clearly showing a tiny grain of sand which had gotten in there. :o
Just proof that sometimes, following a known effective procedure consistently is as important as diag and inspection results.  ;)
In this case, it is my opinion that the switch is made this way on purpose such that it can be serviced this way. I see no good reason not to take advantage of the fact to give it a good scrubbing every once in a while.  :-+
 :-/O
As a rule you should NOT use silicone lubricants on contacts. If there is any arcing at the contact Silicon Dioxide (glass) can form ruining the contact. Some contaminants can also cause silicone to form solid insulating layers on contacts. If you get even tiny amounts of silicone near contacts it can cause issues. One case was the UK Post Office Telephone exchanges (Old Strowager type) where thy had problems eventually traced to the floor polish changing to have silicone wax in it.
A good grease lubricant for contacts is petrolum jelly  "Vaseline". Mixing in a little oil based contact cleaner makes it even better.
I disagree where self-cleaning/wiping contacts are concerned; particularly pots & sliders. 3 decades of empirical experience points to the contrary, and petroleum jelly is flammable (in an arc-flash situation it breaks down creating flammable vapors which can ignite/scorch surrounding plastic), where the microscopic residue from a good food-grade silicone spray is not. Its hydrophobic nature also inhibits issues from moisture in the air.
Use what you choose to; I'll stick with my food-grade silicone. If I'm wrong in that, OFW.   :-//
In this case, if you're worried about the silicone spray (or you don't know which of the dozens of such spray concoctions out there is a good choice), just scrub/flood the thing with alcohol as seen in my pictorial and run it dry like it came from HP.
 :popcorn:
« Last Edit: August 26, 2020, 11:11:58 am by mnementh »
Online mnementh
« Reply #67826 on: August 26, 2020, 11:20:31 am »
PS: One day I would like to know what you think about ECC Ram, I still don't have a clear opinion on that stuff.
Interesting here.
Hoo boy. There's a locked thread just waiting to happen.  :-DD
*currently developing ECC underwear*
« Reply #67827 on: August 26, 2020, 11:28:05 am »
Nice DC Load in the USA (NAWTS):
https://www.ebay.com/itm/224133731707
« Reply #67828 on: August 26, 2020, 11:37:01 am »
Had a problem using my 3478A yesterday.  Wanted to check a low resistance cable, so wired up for 4 wire and got some curious readings.  Tried 2 wire and it was worse.  Checked my cables and tried again.  Still had stupid numbers.  Rechecked cables and shuffled them around.  Still no joy.
Then I hit the front/rear switch..........   :palm:
The following users thanked this post: mnementh, Specmaster, bd139, TorinoFermic
Offline McBryce
« Reply #67829 on: August 26, 2020, 11:37:22 am »
« Reply #67830 on: August 26, 2020, 11:53:06 am »
Yeah, but are you going to get something from China into the US without paying customs duty? Not in the current climate I fear. Probably works out cheaper than a new one from Aliexpress.
The following users thanked this post: BU508A, Specmaster
« Reply #67831 on: August 26, 2020, 12:00:39 pm »
 :-/O
 :popcorn:
Just be certain to treat IPA with the respect it deserves, use only in a well ventilated room, it too is highly combustible and can be easily ignited by a small spark, so you need to be sure that it has completely evaporated before powering up the circuit.
« Reply #67832 on: August 26, 2020, 12:20:21 pm »
Here in the UK there is a good chance that you'll get away without paying import duty, its all down to how the seller declares the item on the customs' declaration paperwork.
Online mnementh
« Reply #67833 on: August 26, 2020, 12:29:58 pm »
(SNIP)
 :popcorn:
https://youtu.be/-0cjCPBiIq4
https://youtu.be/20fbQfsmNKc
Awww... where's the fun in THAT...?!?  >:D
Same is extra-true of silicone spray; even food-grade varieties usually use some form of alcohol as a carrier, sometimes along with toluene or xylene and may even have butane as a propellant!  :o
Of course, we all know that's right where YOU like to play, ya pyro!  :-DD
Can you say BOOM! boys and girls...?
« Last Edit: August 26, 2020, 12:33:38 pm by mnementh »
« Reply #67834 on: August 26, 2020, 12:54:38 pm »
Same is extra-true of silicone spray; even food-grade varieties usually use some form of alcohol as a carrier, sometimes along with toluene or xylene and may even have butane as a propellant:o
I think that's will have butane or some other highly flammable hydrocarbon as a propellant (unless it's really, really old). The only things that don't nowadays are medical inhalers (my asthma inhalers use R134a) and food products - whipped cream in a can uses nitrous oxide, quite what is used in the strange emulsified fat and flavouring cheese simulant known only on the north American subcontinent known as Cheez Whiz I don't know (Tritium? Compressed sewage gas? Some other noxious gaseous waste product?).
Edited: Speeling, or more accurately a complete inability to type straight.
« Last Edit: August 26, 2020, 12:59:19 pm by Cerebus »
« Reply #67835 on: August 26, 2020, 12:57:32 pm »
It will be a lie, it always is, even when a correct declaration and correct value would attract no VAT or duty. I don't think I've ever had a CN1 from China that had an accurate product description or accurate price, let alone the two together.
« Reply #67836 on: August 26, 2020, 01:12:16 pm »
Well it's a good day for stuff today.
Firstly big thanks to Specmaster who sent me a replacement analogue board for my exploded F25. I just stuffed it in while eating my lunch and it works perfectly on all ranges now, not just volts, and appears to be spot on cal as well. Many thanks! :). This one's a keeper. I really like the fact that I can use it as a melee weapon at extremely short notice  :-DD
To do on this one is general clean up. New proper HRC fuse ordered for it as well now and the other two were good from the old one.
More to come as I get some time...
The following users thanked this post: BU508A, med6753, mnementh, Mortymore, tonyalbus
Online mnementh
« Reply #67837 on: August 26, 2020, 01:17:50 pm »
Yup. You can keep it handy leveling out that one wonky table leg; not like it'll notice.  :-DD
 :popcorn:
« Reply #67838 on: August 26, 2020, 01:21:46 pm »
Item number two. This was the £30 spectrum analyser gamble which appears to have paid off so far despite being 100% untested.
Very nicely constructed. This is a house clearance item so RIP to the engineer who this came from. It will be looked after and not bounced.
After doing some digging it appears to be a very faithful build of the Radcom 1989 simple spectrum analyser: http://archive.retro.co.za/archive/amateur/SimpleSpectrumAnalyser-Radcom-Nov1989.pdf
I am suspicious about the mains filter so will bring it up on a bench power supply when I get some time and check it out thoroughly.
« Reply #67839 on: August 26, 2020, 01:26:36 pm »
What is that missing IC7?
« Reply #67840 on: August 26, 2020, 01:29:18 pm »
Thats my point precisely, unless the customs decide to open up the parcel, they will never really know what it contains.  :-DD
« Reply #67841 on: August 26, 2020, 01:31:59 pm »
Glad to have helped out, it keeps another item out of land fill and doubles as a mallet if required so whats not to like  :-DD
Edit, Don't forget if you can get hold of a F27 case in good condition, the guts of the F25 will fit it and then you have the added benefit of the REL and the MIN/MAX functions as well.
« Last Edit: August 26, 2020, 01:34:54 pm by Specmaster »
The following users thanked this post: BU508A, mnementh, Mortymore, bd139
« Reply #67842 on: August 26, 2020, 01:33:56 pm »
Inverts the X axis output for scopes which have opposite X axis voltage/deflection. There were quite a few that did this. The thing has a "hameg settings" sticker on the back so I assume that didn't need inverted X.
« Reply #67843 on: August 26, 2020, 01:34:43 pm »
I've got some Ikea stuff arriving tomorrow. I was going to club in the wooden pegs with it  :-DD (only joking)
Thanks again :-+
Online mnementh
« Reply #67844 on: August 26, 2020, 01:36:44 pm »
I'd pay to see that.  >:D
*rummages in pocket for change*
Online mnementh
« Reply #67845 on: August 26, 2020, 01:37:38 pm »
Shocking to see it's another 741.  :-DD
 :P
« Last Edit: August 26, 2020, 01:39:15 pm by mnementh »
« Reply #67846 on: August 26, 2020, 02:00:36 pm »
 :P
Does the job here - fancy ramp generator  :-+
Final item. Examining the gouged out, still beating heart of the old Fluke 25. This is the only signal source I have that doesn't require digging in the cupboard for more than a few seconds at the moment.
Need a sit down after all this excitement :)
« Reply #67847 on: August 26, 2020, 02:14:37 pm »
Yeah will keep an eye out for that as well  :-+. One each of 25 and 27 would be nice for the bench ???  :-DD
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #67848 on: August 26, 2020, 04:11:19 pm »
Speaking of 3478A's, anyone got a 1QF7-0067 hybrid module they are willing to part with?
One of my meters doesn't seem to believe in AC, so I need a new module to get my AC ranges back...
« Reply #67849 on: August 26, 2020, 04:47:51 pm »
Speaking of melee weapons, the same is true of the Brymen 867 / 869 meters and it is interesting to note that they are almost identical in weight, feel, construction and size, the latter of which can be seen by the photo of my BM867 and F27 side by side. I would have perfect confidence in both of them surviving the abuse that the military inflict on their instruments.  :-+
