Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16755514 times)
powerflux and 40 Guests are viewing this topic.
« Reply #66375 on: August 10, 2020, 02:43:42 pm »
Does that warranty sticker say 3rd May 2031  :-//
No, 31 May 2003.
Of course it is, you Mericans put year first and date last, I should have realised, I blame the heat   :-DD
Offline Mr. Scram
  • Display aficionado
« Reply #66376 on: August 10, 2020, 02:46:51 pm »
I've never heard "the heat" being used as slang for "Americans" before.
« Reply #66377 on: August 10, 2020, 03:02:28 pm »
You numpty, I'm saying I blame the heat because I did not spot that it was the Merican date format, but I suspect that you knew that all along didn't you  ;)
« Reply #66378 on: August 10, 2020, 03:08:10 pm »
That actually isn't the typical American date format. We usually May 31, 2003 or 05/31/03.
And if you don't like it.....tuff.  :P :P :-DD
« Reply #66379 on: August 10, 2020, 03:10:33 pm »
The bedroom painting is done.  :-+  After dry remove edging tape and put the room back in order. Pix tomorrow after complete.
The following users thanked this post: Specmaster, Kosmic
Offline Mr. Scram
« Reply #66380 on: August 10, 2020, 03:21:58 pm »
I was obviously blaming the Americans for their backwards format. Quite literally backwards.
Offline 25 CPS
« Reply #66381 on: August 10, 2020, 03:22:32 pm »
Measure it with the rotisserie plugged in. Bet it's dropping more than that. ;)
*heeds Hypnos' siren call* :=\
You know, that made me realize something interesting:  At 7 watts, the rotisserie motor is rated to consume the same power as one of those C9 bulbs.
Does anyone remember when they shaved two watts off the C9 and C7 bulbs and lowered the power consumption down to 7 and 5 watts respectively?  I think it was in the late 80s or early 90s.  I remember reading about how it would save a lot of electricity but without a huge reduction in brightness when the change was made but I don't recall exactly when that took place.
1044340-0
I did get out the U1461A and tested conductor to conductor insulation strength on the chewed up damaged string I removed from the back yard the other day.  I guess I should go conductor to outside of the cable and see how strong the insulation is that way just out of curiosity.
« Reply #66382 on: August 10, 2020, 04:01:53 pm »
I would've guessed that motor at considerably more, even considering it's just a little pancake induction motor. Huh.
No idea as to when the above shaving took place. Sounds like they did it dry.   :-DD
>:D
« Reply #66383 on: August 10, 2020, 04:09:14 pm »
Backwards only in your mind.
Plus you drive on the wrong side of the road too.  >:D ;D
Offline tggzzz
« Reply #66384 on: August 10, 2020, 04:18:06 pm »
No, it is inside out.
I use yyyy-mm-dd everywhere (for its collation properties) unless an alternative is specified. If people complain I merely note that it is standard format as specified in ISO8601. So are all other formats, but they don't realise that and it is beside the point :).
« Last Edit: August 10, 2020, 04:21:56 pm by tggzzz »
The following users thanked this post: BU508A, mnementh, Specmaster, capt bullshot, Neomys Sapiens, mansaxel
Offline Saskia
« Reply #66385 on: August 10, 2020, 04:21:02 pm »
Offline Kosmic
« Reply #66386 on: August 10, 2020, 04:35:55 pm »
Crap I completely failed at setting a group bid correctly in Gixen.
Was first bidding on some unobtanium power sensor cables and then a lot for the power sensors. So I ended up loosing for the cables but then Gixen still bidded and won the lot for the probes  :palm:
« Reply #66387 on: August 10, 2020, 04:42:21 pm »
Anyone any experience with Scalextric? Got some track for the price of postage from an Autoshite forum member, now I keep buying bits...
Anyway, I'm after information on the motor ratings. They look like those little 1.5-4.5V jobbies, but seem to run at up to 15V.
I have to confess at being tempted to try and shoehorn a 380 motor in there.
Mainly because I'm fairly sure a 540 motor won't fit...
EDIT: Added pic
EDIT 2: 15 posts!
« Last Edit: August 10, 2020, 04:51:55 pm by AVGresponding »
« Reply #66388 on: August 10, 2020, 04:45:00 pm »
When I was a kid I used to run them up to 24V or so. Got very hot but survived. Also covered them in lighter fluid :-DD
Offline Mr. Scram
« Reply #66389 on: August 10, 2020, 05:22:27 pm »
YYYY-MM-DD and DD-MM-YYYY both make hierarchical sense, but MM-DD-YYYY or MM/DD/YYYY is just drunk belligerence from someone fed up with remembering how many furlongs go into a long barn owl.
You talk about sides of the road as if there's some sort of agreed side to drive on. That's obviously nonsense, you should see all the idiots honking and swerving all over the shop.
« Last Edit: August 10, 2020, 05:25:23 pm by Mr. Scram »
« Reply #66390 on: August 10, 2020, 05:25:48 pm »
Why do I find that completely unsurprising?  :)
The following users thanked this post: mnementh, Specmaster, bd139, tonyalbus
« Reply #66391 on: August 10, 2020, 05:30:01 pm »
... is just drunk belligerence from someone fed up with remembering how many furlongs go into a long barn owl.
Two groundhogs, or four pints of dry goods, as you ask.
Offline tonyalbus
    • My Channel
« Reply #66392 on: August 10, 2020, 05:36:38 pm »
For the guys who are sorry for me, i missed the TTi PSU on ebay.
far from a TTi, but i found a 20,- Trio a few weeks before, which was actually quite nice.
i youre were not, here is it anyway  :-DD
« Reply #66393 on: August 10, 2020, 05:42:34 pm »
That's OK, you Brits can fuss all you want.
Today's date is 08/10/20.
Only the UK and former colonies, plus the Japanese, have right hand drive.
I'm cool as cucumber in my A/C while you Brits bake.
 >:D ;D
Offline tggzzz
« Reply #66394 on: August 10, 2020, 05:44:14 pm »
Based on my experience, that means you live in India or Sicily :)
Offline Saskia
« Reply #66395 on: August 10, 2020, 05:48:22 pm »
lets not go into things that you can do with a cucumber.
When in Dublin last year I felt somewhat uncomfortable with the traffic on the wrong side of the road. Made crossing as a pedestrian a little bit awkward.
Add that to the reaction of the folks at the world religion center at DCU when I asked them about the True Gods. They obviously never heard of Odin, Thor, Freya, Heimdall, ...
@tggzz or anywhere in the arab states ...
Offline tggzzz
« Reply #66396 on: August 10, 2020, 05:49:16 pm »
12-14V
http://www.scalextric-car.co.uk/Catalogue/Articles/Article_Scalextric_Cars_and_Old_New_Track.htm
« Reply #66397 on: August 10, 2020, 05:52:47 pm »
 >:D ;D
Just came back from my free physio appointment. No copay, no insurance, no invoice.  :popcorn:
Oh and they had air con  :-DD
Offline Saskia
« Reply #66398 on: August 10, 2020, 06:01:35 pm »
beats con air  :-DD
The following users thanked this post: med6753, mnementh, Neomys Sapiens, bd139, FransW
« Reply #66399 on: August 10, 2020, 06:07:33 pm »
 >:D ;D
Well we tried to teach you how to drive on the left and become more civilized in general, including how dates work but all you did is drive us away, so we came back and left you red necks to your own devices but you blew it as always  >:D :-DD :-DD :-DD
