@TERRA Operative:
You are buying all this stuff on Yahoo! Japan, right?
Yep, practically all the old gear I buy online is from there. A little is bought in Akihabara but mostly Yahoo! Auctions.
all the Tek TM500 modules are popping up recently.
I've got that oscillator too. It's a really smooth device, and its tone is very, very good, plus I like that it's got a balanced output. In the same frame it is paired to a very sick distorsion analyser, an AA501A, but I'm suspecting its no more than aging pains.
What's the trick to get a module out of the frame if the handle is broken?
Edit: Found this thread and subsequently ordered a cable...
Oh cool, good to hear I picked a good one.
I'm not sure about removing modules with broken tabs, Maybe a bit of superglue on a toothpick to adhere to the broken stub to pull on the mechanism might get it free.
A little inward pressure while pulling the tab to reduce the force on the mechanism might help to release it too.
I'm currently designing my own plugin extender harness. Teaser pics below.
I didn't like the other designs I've seen where you have to reach into the enclosure to plug in, so I made the card larger with a handle shape for ease of use. It'll also get 3D printed guides attached to allow it to slide on the rails and align perfectly and easily.
