Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17634313 times)
Robert763 and 19 Guests are viewing this topic.
Offline tggzzz
« Reply #64825 on: July 29, 2020, 05:43:54 pm »
As for 10% more fuel, you need to be careful with simplistic assumptions.
Like I said, back of fag packet - I allowed for the change in momentum (i.e. v2) and rounded up, ignored the calculus of 'you have to carry that fuel', and qualified it with "at least".
Mommy, he said a bad word.  :o :P :-DD
Over here poor people bum fags so they can put them in their mouth.
Or beat fags on their bum.
Or like/dislike being fagged, depending on what caused them to be fagged.
« Reply #64826 on: July 29, 2020, 05:55:27 pm »
I still think it was "calculus" he was on about...  :-DD
*toddles off to recycle his gas grill*
Offline Saskia
« Reply #64827 on: July 29, 2020, 05:56:18 pm »
Offline Saskia
« Reply #64828 on: July 29, 2020, 05:59:46 pm »
Safer than what the German government is considering: launching space going rockets from oil rigs.  :palm:
What could possibly go wrong?
Another problem there: they don't have oil rigs. Which means they would have to either invade Norway or Scotland or the US.
What do the German Luftwaffe of 1945 and 2020 have in common ?
4 airworthy aircraft ...
:-DD :-DD :-DD :-DD
And now for something completely different:
https://youtu.be/5f8MinrUTpw
Offline Saskia
« Reply #64829 on: July 29, 2020, 06:08:36 pm »
waiting for that Tektronix auction to end ... a small Tek224 ...
will my bid be enough ? hmmmm
Offline Mr. Scram
  • Display aficionado
« Reply #64830 on: July 29, 2020, 06:16:04 pm »
Sea Launch is a thing. Not to be confused with sea lunch.
https://en.wikipedia.org/wiki/Sea_Launch
Offline Saskia
« Reply #64831 on: July 29, 2020, 06:23:41 pm »
I know that you can sea launch a rocket. I seriously doubt though, that German politicians meddling in these things can accomplish anything. The new Berlin airport has busted the original budget with how many billion euros sunk and how much delay ? Wasn't the philharmonic orchestra hall in Hamburg 2 - 3 times as expensive as planned ? What about Stuttgart train station ? Aren't they even able to build an effing train station ? The day dreaming about an aircraft carrier without even having the ships available to set up the escorts ? Or the planes to put onto the carrier ?
And then daydreaming about getting a rocket into space even though they never did it before ?
On an oil rig that they never built ?
Offline Mr. Scram
« Reply #64832 on: July 29, 2020, 06:30:32 pm »
Government projects which balloon to incredible costs, many times to original projection with disappointing or outright dysfunctional results? No! Which government is that? All of them you say? ;D
Offline Saskia
« Reply #64833 on: July 29, 2020, 06:33:00 pm »
Nope, it ain't. Not gonna raise my bid tho.
« Reply #64834 on: July 29, 2020, 06:46:46 pm »
Aaaand today it is TE on a field trip.
which of course is here if the image management still is b0rkened.
A UK MOD Avometer, in its protective case, doing some resistance measurements for electrical installations in my brother-in-laws cold, damp basement. Luckily enough, the instrument is tropicalised (for the already then nearly-nonexistant colonies, one supposes) and there is a niche in the wall allowing it to sit horizontally so it'll reach its stated accuracy.
I remember I defined "Overkill" as a synonym to "Appropriate", upthread, yep. This is to that spirit.
I also had the crank Megger out to test a buried cable between two buildings. Worked just fine, it did.
« Last Edit: July 29, 2020, 06:48:53 pm by mansaxel »
The following users thanked this post: BU508A, mnementh, bd139, Kosmic
« Reply #64835 on: July 29, 2020, 07:00:10 pm »
Today arrivals:
- a new keyboard from Logitech
- a new 4l ultrasonic cleaner from the EMMI AG near Walldorf (ordered @ Voelkner)
- some electron tubes (E90CC, EF80)
- empty boxes for electron tubes (the white one below the EF80)
- some 2mm mini banana plugs from Stäubli MultiContact
- some grabbers from Stäubli MultiContact to be connected with 2mm plugs
- some transistors for an upcoming project (MPSA 42 and MPSA 92)
- three USB chargers with an LED display. Was an offer @ Voelkner for around 7 Euro each (otherwise nearly 20 Euro)
- Some Pomona grabbers (3781-24-0 and -2)
I was surprised, how cheap the Pomonas and the Stäubli MultiContact Stuff is @ Voelkner. Couldn't resist.
This is the EMMI ultrasonic cleaner. The pcb in it is a standard one with 160 x 100mm²
Overview:
Details:
« Reply #64836 on: July 29, 2020, 07:04:56 pm »
Excellent  >:D :-DD
« Reply #64837 on: July 29, 2020, 07:05:40 pm »
There are a lot of Phillips users who think they're blissfully ignored JIS for many a year, but if they go and examine the screw heads on anything Japanese that they own, and have taken apart, the apprentice marks will be witness that it wasn't quite as blissful as they thought.
Ok, it's been in my watch list enough long. Here goes.
Done! Thanks for enabling me.
« Reply #64838 on: July 29, 2020, 07:26:04 pm »
This is genuinely one reason why you never see any Japanese kit in my place.
« Reply #64839 on: July 29, 2020, 07:27:15 pm »
At last !
My solartron 7150 functions nicely  :-DMM
Looks like the 4 LED's, 2 on each end of the display have given up, I'd recommend that you replace those and the mains input filter, (part of the mains socket) is replaced as round about it likely to be a pipe bomb waiting to go off with age. Otherwise, it looks to be a pretty good 6.5digit meter, well done.
The LEDs might not be dead; mine had one of the header pins bent, so I carefully bent it back into shape, and voila, working LEDs. Not very bright LEDs, but working ones.
I've always found the "you need to be on the equator to launch orbiting things" a bit specious. Yes, you get 1000 mph (0.4 km/s) for free, but that's a small part of the 7-8 kilometers per second that you need even for a low earth orbit (over 11 km/s for escape velocity). Sure, you use al least 10% more fuel (can't be bothered to work it out properly, it gets too calculusy for the back of a fag packet), or have a lower payload, but you gain convenience, launch from home territory (which has positive security implications) and you don't have to constantly ferry staff half way around the world.
And of course you can drop "When I was driving past the spaceport the other day" into conversation with the French - "Yes, I know you've got one in French Guiana, but that's hardly on the way to the shops is it? Here, have a glass of bubbly in consolation. Yes, it is good isn't it - from Kent don't ya know. [Sound of apoplectic choking in French]".  :)
For a given payload, it's going to be cheaper and easier to launch it from the equator. Given the enormous costs involved, that's not to be sneezed at. Especially these days as you'd have to self-isolate for two weeks afterwards.
The UK must still have plenty of remaining colonial era territories that could be used.
Nah, never going to happen, our economy cannot afford such luxury items. >:D |O
We're still the 5th or 6th biggest economy in the world. Everybody and his maiden uncle are doing it these days, I don't see why we can't, though I think the dropping out of the Galileo project is epic stupidity, and it seems we may be dropping out of ITER too, because BoJo the clown can't understand these are important things.
Fuck all politicians, if Jeremy Corbyn had got in (I voted Labour) we'd still have the same problems, as he'd have slashed funding for everything vaguely military, and his distrust for the EU would probably have led him down the same damn path.
All the colours you've ever wanted in one small drawer:
Maybe they're planning on getting additional thrust that way...
Online PA0PBZ
The following users thanked this post: edavid, tonyalbus
« Reply #64841 on: July 29, 2020, 07:38:38 pm »
:-DD :-DD :-DD :-DD
and now
« Reply #64842 on: July 29, 2020, 07:51:05 pm »
Today arrivals:
Overview:
Details:
Nice cleaner, I'm so jelly right now, mine has been returned for a refund as the selller was not prepared to exchange it for the one he used in his description  :rant:
« Reply #64843 on: July 29, 2020, 07:54:44 pm »
(Attachment Link)
Glad to be of service!
Tip for anyone who cares to know. Wera's small precision screwdrivers have a grind that makes them a proper fit both for Phillips and JIS. These ones:
1036218-0
The following users thanked this post: Specmaster, Mr. Scram, bd139, TorinoFermic, duckduck
« Reply #64844 on: July 29, 2020, 07:56:32 pm »
Ahha I have that set too. Very nice screwdrivers. Didn’t know they worked with JIS heads.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #64845 on: July 29, 2020, 07:58:57 pm »
As a heads up to any who may be interested, apparently someone on the bay of evil has stumbled onto a cache of those HP coffee mugs:
1036222-0
https://www.ebay.com/itm/114327183149?ul_noapp=true&shqty=2&isGTR=1#shId
There are allegedly more than ten available, and the price is not too insane compared to what I've seen them go for in the past.
-Pat
<edit to add picture from auction>
« Last Edit: July 29, 2020, 08:01:43 pm by Cubdriver »
The following users thanked this post: Zucca, BU508A, mnementh, Mr. Scram, bd139
Offline Mr. Scram
« Reply #64846 on: July 29, 2020, 08:01:50 pm »
-Pat
Shipping them here makes it very uninteresting, unfortunately.
« Reply #64847 on: July 29, 2020, 08:02:27 pm »
Damn I’d buy one buy £28 shipping plus charges on top.
« Reply #64848 on: July 29, 2020, 08:09:41 pm »
"$40.74 International Priority Shipping to Germany  via the Global Shipping Program"
"$68.02 for 2 International Priority Shipping to Germany  via the Global Shipping Program"
Arrrgh! This is insane! I'd like to have one, but this shipping is ridiculous.  :wtf:  :rant:
« Last Edit: July 29, 2020, 08:12:47 pm by BU508A »
« Reply #64849 on: July 29, 2020, 08:11:21 pm »
Wow that’s cheaper for us. That’s a first!
